Home » Modeling » Modeling (top-level project) » Ecore Model Error when Migrating
Ecore Model Error when Migrating [message #384789] Thu, 04 June 2009 04:38 Go to next message
I developed a ecore metamodel using the Ganymede distribution with
appropriate plugins, and now I installed the Eclipse Galileo distribution
with the same plugins, yet when i want to see the model from the workspace
I will get an error of the kind:
"Problems occurred when invoking code from plug-in: "org.eclipse.jface".
java.lang.NoClassDefFoundError:
org/eclipse/emf/transaction/Transaction$OptionMetadata
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.createEditingDomain(DiagramDocumentEdito r.java:1541)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.doSetInput(DiagramDocumentEditor.java:45 7)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.setInput(DiagramDocumentEditor.java:423)
at org.eclipse.gef.ui.parts.GraphicalEditor.init(GraphicalEdito r.java:318)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.init( DiagramEditor.java:653)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.init(DiagramDocumentEditor.java:127)
at
org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:798)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:644)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:462)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:286)
at
org.eclipse.ui.internal.EditorManager.findEditor(EditorManag er.java:403)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2799)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2762)
at
org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2754)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2705)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2701)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2685)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2676)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
at
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:361)
at
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:168)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:22 9)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:20 8)
at
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:274)
at
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:250)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:373)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 4.open(PackageExplorerPart.java:526)
at
org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener. open(OpenAndLinkWithEditorHelper.java:48)
at
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:842)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:840)
at
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1101)
at
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1205)
at
org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:264)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:258)
at
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:298)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
Caused by: java.lang.ClassNotFoundException:
org.eclipse.emf.transaction.Transaction$OptionMetadata
at
org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:489)
at
org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:405)
at
org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:393)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
... 66 more"
My question is, what is the easiest way to use this metamodel?
A related problem is that I have the option to create an ecore diagram
through a wizard (like in Ganymede), but when it comes to the last step,
the button "Finish" is clickable yet has absolutely no effect, thus I am
unable to create ecore diagrams through the wizard.
Possible reasons/solutions?
Thanks in advance,
Aurel
Re: Ecore Model Error when Migrating [message #384794 is a reply to message #384789] Thu, 04 June 2009 06:03 Go to previous message
--------------070907070107070109000505
Aurel,
It sounds like some plugins are missing. Did you get the modeling package?
http://www.eclipse.org/downloads/packages/release/galileo/rc 2
Aurel Ganga wrote:
> Hello,
> distribution with the same plugins, yet when i want to see the model
> from the workspace I will get an error of the kind:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> ... 66 more"
> step, the button "Finish" is clickable yet has absolutely no effect,
> thus I am unable to create ecore diagrams through the wizard.
> Thanks in advance,
> Aurel
<html>
<head>
http-equiv="Content-Type">
</head>
Aurel,<br>
<br>
Re: Ecore Model Error when Migrating [message #616719 is a reply to message #384789] Thu, 04 June 2009 06:03 Go to previous message
Aurel,
Aurel Ganga wrote:
> Hello,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 66 more"
> Thanks in advance,
> Aurel
<html>
<head>
</head>
Aurel,<br>
<br>
Previous Topic:Ecore Model Error when Migrating
Next Topic:UML Class Diagram
Current Time: Tue Jul 22 22:23:57 EDT 2025
Powered by FUDForum. Page generated in 0.06840 seconds
