Home » Archived » BIRT » getting following error with report engine API
getting following error with report engine API [message #38110] Wed, 18 May 2005 09:53 Go to next message
Originally posted by: vijayanb.gmail.com
hi there,
getting following error with report engine API when executing the example
RunReport.java
please let me know what I am doing wrong..
thanks
vijay
May 18, 2005 9:26:05 AM org.eclipse.birt.data.engine.impl.DataEngineImpl
<init>INFO: Data Engine starts upMay 18, 2005 9:26:05 AM
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask runSEVERE:
Error.OutputFormatNotSupported
Report test.rptdesign run failed.
org.eclipse.birt.report.engine.api.EngineException: The output format html
is not supported.
Re: getting following error with report engine API [message #38373 is a reply to message #38110] Wed, 18 May 2005 15:20 Go to previous messageGo to next message
Very likely, you have a mismatch of file version. There was a recent
change to the plugin.xml files for the fo and html emitter plugins. Your
installed plugins may have the old plugin.xml, while your downloaded
sources may be assuming new plugin.xml files.
Stanley Wang
BIRT Lead
Re: getting following error with report engine API [message #38470 is a reply to message #38373] Wed, 18 May 2005 16:31 Go to previous messageGo to next message
hi wang,
thanks for the pointer...
I am using the the following plugin.xml for fo and html emitters..
BIRT 0.0.1 Nightly Build (Build N <20050501-1926>
is there a newer plugin than this..? Pl let me know..
thanks
vijay
"Stanley Wang" <swang@actuate.com> wrote in message
news:fb688899eda30241d3170372a46efe8a$1@www.eclipse.org...
> Stanley Wang
> BIRT Lead
Re: getting following error with report engine API [message #129909 is a reply to message #38110] Tue, 14 February 2006 02:46 Go to previous message
Originally posted by: huy.banh.gmail.com
Hi Vijay,
I am running into this problem, although I have set birt home correctly.
Did you solve this problem? Would you please tell me how did you solve it?
HB.
vijay wrote:
> hi there,
> RunReport.java
> thanks
> vijay
> is not supported.
Previous Topic:Partial solution for dynamic table sorting
Next Topic:Is BIRT_VIEWER_REPORT_ROOT working fine with BIRT 2.0.0?
Current Time: Fri Nov 21 11:15:21 EST 2025
Powered by FUDForum. Page generated in 0.04157 seconds
