Home » Archived » GMT (Generative Modeling Technologies) » [Espilon][EWL] Wizard inheritance and call
[Espilon][EWL] Wizard inheritance and call [message #384439] |
Wed, 06 August 2008 09:46  |
I have some questions about EWL:
is there a way to make wizard inherits from another?
Is there a way to call wizard from another?
Example:
wizard A {
wizard B extends A {
do {
C.call / self.C / ??
wizard C {
Re: [Espilon][EWL] Wizard inheritance and call [message #384443 is a reply to message #384442] |
Wed, 06 August 2008 11:22   |
Dimitrios Kolovos a écrit :
> Hi Olivier,
> No worries about the previous messages. Could I ask you to please avoid
> prefixing your messages with the name of the individual language (e.g.
> EWL). Just [Epsilon] would suffice.
> EWL doesn't support wizard inheritance. However, you can still do what
> you need by splitting your functionality using operations. E.g.
> wizard A {
> do {self.a();}
> wizard B {
> do {self.a(); self.b();}
> operation YourContext a() {...}
> operation YourContext b() {...}
> If lack of inheritance seems to be creating a mess in your EWL code
> please consider adding a feature request to the bugzilla and we'll try
> to implement it in the next version of Epsilon.
> Cheers,
> Dimitrios
> Olivier PATRY wrote:
>> Hi,
>> Example:
>> wizard A {
>> do {
>> wizard C {
>> Thanks
Thanks for answering Dimitrios.
So, that's what I was thinking, using operation to factorize code.
I'll test this way and give you feedback if there is some lack.
I had another question, a double question!
I search for an EWL syntax reference, I get this pointer:
http://dev.eclipse.org/viewcvs/indextech.cgi/org.eclipse.gmt /epsilon/plugins/org.eclipse.epsilon.help/index.html
But nothing yet avaible for EWL. Is there anywhere a draft of EWL syntax
reference?
So the double-part of my question now, without syntax reference, I
didn't know if it is possible to prompt for "Type" with EWL.
Typically, I wish I could use something like that:
var a : MyType;
a := UserInput.promptType('Choose a type in the above list');
And, get a choose box with all instances of "MyType" (isKindOf(MyType),
not isTypeOf(MyType)
Thanks, very please with this amazing project ;)
Olivier Patry
p.s. okay for the [EWL] in subject ;) sorry
Re: [Espilon] Wizard inheritance and call [message #384451 is a reply to message #384443] |
Wed, 06 August 2008 12:44   |
Hi Olivier,
See comments inline
Thanks. Please let us know if this enhancement seems necessary.
> reference?
The reference for EWL is http://www.jot.fm/issues/issue_2007_10/paper3.pdf
Also bear in mind that EWL heavily reuses the core EOL language so many
of your questions should be answered by reading the Epsilon Object
Language section of the online docs. We are currently working on putting
together a complete reference of all Epsilon languages and it should be
available soon.
> var a : MyType;
There is the UserInput.choose(Collection) that allows you to choose one
of the objects in the collection (and also the chooseMany that allows
multiple selections). Could you please give more details about what
you'd like to do with this? (I suspect you need to create an instance of
a type which is determined at runtime).
Thanks for your kind words :)
> Olivier Patry
Thanks for your understanding.
Dimitrios
Re: [Espilon] Wizard inheritance and call [message #384454 is a reply to message #384451] |
Thu, 07 August 2008 05:03   |
> Hi Olivier,
> See comments inline
>> syntax reference?
> available soon.
>> var a : MyType;
>> (isKindOf(MyType), not isTypeOf(MyType)
>> Olivier Patry
> Cheers,
> Dimitrios
thanks for this detailled answer.
I already read the EWL document (jot.fm/*/paper3.pdf) but not complete
enough for learning the complete language (such as the existence of
choose/chooseMany (that will be help me to do what I want, I'll try)). I
notice some similarity with EOL (that's why I like the Epsilon project,
all is consistent!).
I discover Epsilon (and Eugenia that will help me too) luckily and
lately for my project, I hope your complete reference of epsilon
language will be ready at time for me! :)
I'll continue my tests and give you feedback/feature request if
necessary. I think the project is a bit young and need feedback, so if I
can, I'll do it!
Tnanks,
Olivier
Re: [Espilon] Wizard inheritance and call [message #384456 is a reply to message #384454] |
Thu, 07 August 2008 05:29   |
In fact they are a bit more than just similar :) EWL extends EOL which
means that *any* EOL statement is also a valid EWL statement (and the
same applies to all other languages : EVL, ETL etc.).
We'll try to have a first (rough and incomplete) version by the end of
next week.
> can, I'll do it!
You are right. Epsilon is one of the newest projects of this scope and
any feedback is highly appreciated ;)
> Tnanks,
> Olivier
Dimitrios
Re: [Espilon] Wizard inheritance and call [message #384648 is a reply to message #384460] |
Thu, 07 August 2008 10:13  |
> Hi Olivier,
>> next week.
> On an update to this I've uploaded the current version of the reference
> in
> http://epsilonlabs.svn.sourceforge.net/svnroot/epsilonlabs/o rg.eclipse.epsilon.book/EpsilonBook.pdf
> It is still a very rough version but we plan to further refine it until
> it starts making sense :)
> Cheers,
> Dimitrios
Thanks, it certainly will help me! I'll give you feedback on this
document (when I had finished to read it).
Olivier
Re: [Espilon][EWL] Wizard inheritance and call [message #618876 is a reply to message #384439] |
Wed, 06 August 2008 10:36  |
Hi Olivier,
wizard A {
do {self.a();}
wizard B {
Dimitrios
> Example:
> wizard A {
> do {
> wizard C {
> Thanks
Re: [Espilon][EWL] Wizard inheritance and call [message #618877 is a reply to message #384442] |
> Hi Olivier,
> wizard A {
> do {self.a();}
> wizard B {
> Cheers,
> Dimitrios
>> Hi,
>> Example:
>> wizard A {
>> do {
>> wizard C {
>> Thanks
reference?
var a : MyType;
Olivier Patry
Re: [Espilon] Wizard inheritance and call [message #618885 is a reply to message #384443] |
Hi Olivier,
See comments inline
> reference?
available soon.
> var a : MyType;
> Olivier Patry
Dimitrios
Re: [Espilon] Wizard inheritance and call [message #618889 is a reply to message #384451] |
> Hi Olivier,
> See comments inline
>> syntax reference?
> available soon.
>> var a : MyType;
>> Olivier Patry
> Cheers,
> Dimitrios
can, I'll do it!
Tnanks,
Olivier
Re: [Espilon] Wizard inheritance and call [message #618891 is a reply to message #384454] |
next week.
> can, I'll do it!
> Tnanks,
> Olivier
Dimitrios
Re: [Espilon] Wizard inheritance and call [message #618892 is a reply to message #384451] |
Thu, 07 August 2008 05:34  |
I try the choose method. If I understand correctly, I have to do:
wizard moveTo {
guard : self.isKindOf(MyType2)
title : 'move me to...'
do {
var myTargetElement : MyType;
myTargetElement := UserInput.choose(MyType.allInstances);
myTargetElement.mytypes2.add(self);
I get the error:
Method 'choose' not found (same error with chooseMany)
I expect that a window popup or something like that will appear listing
MyType.allInstances and permit to select (one for choose, some for
chooseMany) and then validate and affect the target var.
Re: [Espilon] Wizard inheritance and call [message #618894 is a reply to message #384457] |
Thu, 07 August 2008 05:47  |
Hi Olivier,
You also need to specify a string that acts as the selection dialog title:
myTargetElement := UserInput.choose('Where would you like to move me?' ,
The same applies to chooseMany
Dimitrios
>> one of the objects in the collection (and also the chooseMany that
>> allows multiple selections).
> wizard moveTo {
> do {
> I get the error:
> Thanks
Re: [Espilon] Wizard inheritance and call [message #618898 is a reply to message #384460] |
> Hi Olivier,
>> next week.
> in
> Cheers,
> Dimitrios
Olivier
Current Time: Sun Jul 27 03:43:10 EDT 2025
Powered by FUDForum. Page generated in 1.28904 seconds
