Yikes! ConcurrentModificationException [message #384217] |
Thu, 04 December 2008 08:37  |
Can something in my code cause this???
java.util.ConcurrentModificationException
at java.util.AbstractList$Itr.checkForComodification(AbstractLi st.java:372)
at java.util.AbstractList$Itr.next(AbstractList.java:343)
at org.eclipse.persistence.indirection.IndirectList$1.next(Indi rectList.java:546)
at org.eclipse.persistence.internal.queries.InterfaceContainerP olicy.next(InterfaceContainerPolicy.java:226)
at org.eclipse.persistence.internal.queries.ContainerPolicy.nex t(ContainerPolicy.java:701)
at org.eclipse.persistence.mappings.CollectionMapping.cascadeDi scoverAndPersistUnregisteredNewObjects(CollectionMapping.jav a:251)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.c ascadeDiscoverAndPersistUnregisteredNewObjects(ObjectBuilder .java:1489)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.dis coverAndPersistUnregisteredNewObjects(UnitOfWorkImpl.java:37 99)
at org.eclipse.persistence.internal.sessions.RepeatableWriteUni tOfWork.discoverUnregisteredNewObjects(RepeatableWriteUnitOf Work.java:181)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.cal culateChanges(UnitOfWorkImpl.java:584)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.com mitToDatabaseWithChangeSet(UnitOfWorkImpl.java:1320)
at org.eclipse.persistence.internal.sessions.RepeatableWriteUni tOfWork.commitRootUnitOfWork(RepeatableWriteUnitOfWork.java: 159)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.com mitAndResume(UnitOfWorkImpl.java:1002)
at org.eclipse.persistence.internal.jpa.transaction.EntityTrans actionImpl.commitInternal(EntityTransactionImpl.java:84)
at org.eclipse.persistence.internal.jpa.transaction.EntityTrans actionImpl.commit(EntityTransactionImpl.java:63)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.tbee.util.jpa.EntityTransactionExtender.invoke(EntityTra nsactionExtender.java:106)
at $Proxy36.commit(Unknown Source)
at org.tbee.swing.jpa.JpaObjectNavigatorModel.doSave(JpaObjectN avigatorModel.java:746)
at org.tbee.swing.jpa.JpaObjectNavigatorBar$3.actionPerformed(J paObjectNavigatorBar.java:125)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButto n.java:1995)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractB utton.java:2318)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultBu ttonModel.java:387)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel .java:242)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Bas icButtonListener.java:236)
at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticast er.java:272)
at java.awt.Component.processMouseEvent(Component.java:6134)
at javax.swing.JComponent.processMouseEvent(JComponent.java:326 5)
at java.awt.Component.processEvent(Component.java:5899)
at java.awt.Container.processEvent(Container.java:2023)
at java.awt.Component.dispatchEventImpl(Component.java:4501)
at java.awt.Container.dispatchEventImpl(Container.java:2081)
at java.awt.Component.dispatchEvent(Component.java:4331)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container. java:4301)
at java.awt.LightweightDispatcher.processMouseEvent(Container.j ava:3965)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java: 3895)
at java.awt.Container.dispatchEventImpl(Container.java:2067)
at java.awt.Window.dispatchEventImpl(Window.java:2458)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
at org.tbee.swing.EventQueue.dispatchEvent(EventQueue.java:83)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDis patchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispat chThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDis patchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread. java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread. java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:12 2)
Re: Yikes! ConcurrentModificationException [message #384229 is a reply to message #384227] |
Thu, 04 December 2008 10:12   |
Zooming in on Buyorder... The error is caused by this line:
public void setReindersRelation(nl.reinders.bm.Relation value)
if (value == iReindersRelation) return; // optimalisation and prevent looping
nl.reinders.bm.Relation lValue = iReindersRelation;
if (log4j.isDebugEnabled()) log4j.debug("setReindersRelation: " + lValue + " -> " + value);
fireVetoableChange(REINDERSRELATION_PROPERTY_ID, lValue, value);
if (lValue != null) lValue.removeBuyordersWhereIAmReindersRelation( (nl.reinders.bm.Buyorder)this );
iReindersRelation = value;
try {
if (value != null) value.addBuyordersWhereIAmReindersRelation( (nl.reinders.bm.Buyorder)this ); // <----------------------
} catch (RuntimeException e) { iReindersRelation = lValue; throw e; } // restore upon exception
firePropertyChange(REINDERSRELATION_PROPERTY_ID, lValue, value);
So, if a buyorder is created, it searches for a specific relation as a default value, sets it and because of the 1-N, that buyorder is also added to the relation's collection.
Zooming in again on Relation:
public void addBuyordersWhereIAmReindersRelation(nl.reinders.bm.Buyorder value)
if (value != null && !iBuyordersWhereIAmReindersRelation.contains(value))
java.util.List<nl.reinders.bm.Buyorder> lValue = new java.util.ArrayList<nl.reinders.bm.Buyorder>();
lValue.addAll(iBuyordersWhereIAmReindersRelation);
lValue.add(value);
fireVetoableChange(BUYORDERSWHEREIAMREINDERSRELATION_PROPERT Y_ID, java.util.Collections.unmodifiableList(iBuyordersWhereIAmRei ndersRelation), java.util.Collections.unmodifiableList(lValue));
boolean lWasAdded = iBuyordersWhereIAmReindersRelation.add(value); // <----------------------
lValue.remove(value);
firePropertyChange(BUYORDERSWHEREIAMREINDERSRELATION_PROPERT Y_ID, java.util.Collections.unmodifiableList(lValue), java.util.Collections.unmodifiableList(iBuyordersWhereIAmRei ndersRelation));
try {
value.setReindersRelation( (nl.reinders.bm.Relation)this);
} catch (RuntimeException e) { if (lWasAdded) {iBuyordersWhereIAmReindersRelation.remove(value);} throw e; } // restore upon exception
If the add is commented out, the error does not occur.
For the CME to occur, it must be processing the iBuyordersWhereIAmReindersRelation. In what way will processing the iBuyordersWhereIAmReindersRelation create a new Buyorder instance?
Re: Yikes! ConcurrentModificationException [message #384231 is a reply to message #384229] |
Thu, 04 December 2008 10:59  |
Here also I had to revoke to an application level event:
@Override public void postNew(Buyorder e)
e.ignoreChanges();
try
e.setReindersRelation(Relation.findReindersNetherlands());
finally
e.registerChanges();
I really really have to think about that AspectJ approach.
FUDForum. Page generated in 0.04204 seconds
