extend [message #383949] |
Tue, 08 July 2008 16:19  |
Hello ...
I have an OAW extend file in a plugin called p1 ...
Is it possible to use the extend file from a 2nd plugins (p2) expand
file ? If so how do i referenece it?
<<EXTENSION ?? >>
Jim
Re: extend [message #383956 is a reply to message #383953] |
Wed, 09 July 2008 09:44  |
Thank you that worked ...
Jim
>> You will have to enter the classpath with "::" instead of "." or "/".
> Well, ehm, I should not answer questions after midnight... ;-)
> It is the resource-path to find the .ext file without the classpath-part.
> The oaw editors provide a completion if both projects are oaw projects.
> Enrico
Re: extend [message #618233 is a reply to message #383949] |
Tue, 08 July 2008 18:08  |
Hello Jim,
> <<EXTENSION ?? >>
You will have to enter the classpath with "::" instead of "." or "/". this
includes that p1 should be on the imported plugins and p1 should contain
the xtend file in a source folder.
Enrico Schnepel
Re: extend [message #618234 is a reply to message #383952] |
Wed, 09 July 2008 04:32  |
Enrico
Re: extend [message #618235 is a reply to message #383953] |
Jim
> Enrico
FUDForum. Page generated in 0.72550 seconds
