Home » Archived » GMT (Generative Modeling Technologies) » [Epsilon] ! Operator
[Epsilon] ! Operator [message #383627] Tue, 10 June 2008 12:02 Go to next message
In EOL I am trying to invoke an operation performing checks on the same
model element type for several models. The following code returns an error
when using the ! operator :
var tmp_model := ATMModel;
tmp_model.checkOp();
operation Any checkOp() {
self!Property.println();
-- returns: ' Undefined variable, type or model: 'self!Property' '
self.hasType('Property');
-- ok, has expected result
ATMModel!Property.println();
-- ok as well, but I don't want to hardcode ATMModel here
Is there a workaround for this?
Thank you in advance,
Anne
Re: [Epsilon] ! Operator [message #383888 is a reply to message #383627] Tue, 10 June 2008 13:26 Go to previous messageGo to next message
Hi Anne,
When you have multiple models of the same metamodel in an Epsilon
program you can use the "alias" feature. For example, if you have
UMLModel1 and UMLModel2, by setting their aliases (through the launch
configuration dialog) to UMLModel, you can then call
UMLModel!Class.allInstances() and this will return all the instances of
the Class metaclass both in UMLModel1 and UMLModel2.
Does this solve your problem?
Dimitrios
Anne Keller wrote:
> Hello,
> error when using the ! operator :
> self!Property.println(); -- returns: ' Undefined variable, type or
> self.hasType('Property'); -- ok, has expected result
> Anne
Re: [Epsilon] ! Operator [message #383889 is a reply to message #383888] Tue, 10 June 2008 16:46 Go to previous message
Dear Dimitrios,
thank you very much for your quick reply.
This works as a solution for now.
Anne
Re: [Epsilon] ! Operator [message #617737 is a reply to message #383627] Tue, 10 June 2008 13:26 Go to previous message
Hi Anne,
Dimitrios
Anne Keller wrote:
> Hello,
> Anne
Re: [Epsilon] ! Operator [message #617738 is a reply to message #383888] Tue, 10 June 2008 16:46 Go to previous message
Dear Dimitrios,
Anne
Previous Topic:[Epsilon] ! Operator
Next Topic:OAW - Type Casting with XTend
Current Time: Sat Jul 26 08:12:07 EDT 2025
Powered by FUDForum. Page generated in 0.12721 seconds
