Home » Modeling » Modeling (top-level project) » help with existing meta data repository mapping
| help with existing meta data repository mapping [message #383876] |
Mon, 12 January 2009 05:26  |
Originally posted by: brian.silberbauer.gmail.com
Hi all
I'm new to the eclipse modelling world and there is a lot of new concepts
and libraries and plugins, so I hope I'm posting at the right place:
I have a client who has an existing application extracting meta
information from various sources and storing it in a propriety format in
a RDB and can view it through a custom built viewer.
We would like to be able to use the visualization tools and query tools
available on the existing meta data repository, what would you recommend
the best way to create this mapping?
Possibilities we've seen so far would be to map to EMF by either
exporting portions to XMI and importing that, generating the EMF code
directly from the repository or creating a custom CDO implementation.
Any help, comments would be appreciated, I'm in acronym overload.
Brian
| Re: help with existing meta data repository mapping [message #383878 is a reply to message #383876] |
Mon, 12 January 2009 20:08   |
Brian,
Comments below.
Brian Silberbauer wrote:
> Hi all
Modeling is usually not the right place, because it's just a general
catch-all for the top-level modeling project...
This is certainly a very general question, so it does seem reasonable to
ask it here...
Most of the Eclipse modeling stack of technology is built around Ecore
as the core meta model. So much of your question about mapping is how
to map whatever meta model/information you have to Ecore...
It's "something" -> XMI -> "instance of an Ecore model" sounds like a
level on indirection you shouldn't need. We can only read XMI because
there is an Ecore model onto which the elements and attributes map. So
if you can map "something" to XMI then you can map "something" directly
onto an instance (an EObject). Things like Teneo and CDO (and JCRM for
that matter) can help help bridge the gap between a repository and
EObject instances.
Yes, that sucks. But to give concrete advice, I think we need more
information than that you have a "format in RDB". After all that's
just an acronym to add to the soup. My knee jerk response would be to
say that Hibernate helps map RDB to Java objects and Teneo provides
integration with Hibernate and hence is the most obvious RDB to EObject
mapping solution...
> Brian
| Re: help with existing meta data repository mapping [message #383879 is a reply to message #383878] |
Tue, 13 January 2009 03:30   |
On Mon, 12 Jan 2009 20:08:20 -0500, Ed Merks wrote:
Thanks for the reply Ed, more comments below..
> Brian,
> Comments below.
OK, that clears that up nicely, what confuses me is that I thought ecore
was java specific, but it seems uml2 extends ecore??
> EObject instances.
The XMI route is one I wouldn't want to go down, so good to hear I
shouldn't have to.
> mapping solution...
>> Brian
Well, this is an old project that I'm taking over and I am bound by an
NDA, so I'm going to be cryptic with the information I give out and I
don't have direct access to the previous developers so there are still a
few black holes in my knowledge of the system.
We end up with node data stored in a single self referencing table in a
database. I'd like to be able to map this data into EMF and query it,
merge/compare it and visually manipulate it. I'm waiting for full
explanation of the columns, but it basically holds the node information
(with types etc) and the relationships between nodes. It also holds a
basic parent child relationship as well.
At this stage I'm hoping EMF can help me out, I've created some
structures pragmatically using the uml2 library , used draw2d to create
some diagrams and am looking into GEF which looks great and just started
reading up on ecore tools.
thanks again Ed.
| Re: help with existing meta data repository mapping [message #383881 is a reply to message #383879] |
Tue, 13 January 2009 06:48   |
--------------050107040101090709030006
Brian,
Comments below.
>> Brian,
>> Comments below.
Ecore is effectively isomorphic to the OMG's EMOF but it's fair to say
we've added some things to Ecore that aren't in EMOF and that are Java
specific. UML2 extending Ecore is an implementation artifact that has
no real semantic significance and has always annoyed me. It was done
simply to inherit the ability to use EAnnotations on all UML Elements,
rather than defining an analogous concept in UML itself.
>> EObject instances.
> shouldn't have to.
>> mapping solution...
>>> Brian
Oh joy. Hopefully you're well paid. :-)
It sounds slightly gross. :-P I suppose you're want to continue to read
and write exactly this format, rather than import from it and then
migrate to a perhaps nicer format?
There is certainly a wealth of technology available. If you're using
UML basically just for class diagrams to describe data structures,
probably Ecore along with Ecore Tools will be sufficient... Of course
there is two way mapping between UML and Ecore, so that's useful as well...
> thanks again Ed.
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Brian,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:gkhjet$bnq$1@build.eclipse.org" type="cite">
</pre>
<blockquote type="cite">
<pre wrap="">Brian,
Comments below.
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
rather than defining an analogous concept in UML itself.<br>
<pre wrap="">
</pre>
<pre wrap="">Possibilities we've seen so far would be to map to EMF by either
</pre>
</blockquote>
<pre wrap="">It's "something" -> XMI -> "instance of an Ecore model" sounds like a
EObject instances.
</pre>
</blockquote>
shouldn't have to.
</pre>
<pre wrap="">Any help, comments would be appreciated, I'm in acronym overload.
</pre>
</blockquote>
<pre wrap="">Yes, that sucks. But to give concrete advice, I think we need more
mapping solution...
</pre>
<pre wrap="">Brian
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
Oh joy. Hopefully you're well paid. :-)<br>
<pre wrap="">
</pre>
</blockquote>
read and write exactly this format, rather than import from it and then
migrate to a perhaps nicer format?<br>
<pre wrap="">
</pre>
</blockquote>
well...<br>
<pre wrap="">
thanks again Ed.
</pre>
</blockquote>
</body>
</html>
--------------050107040101090709030006--
| Re: help with existing meta data repository mapping [message #383882 is a reply to message #383881] |
Tue, 13 January 2009 08:37   |
Originally posted by: cdamus.zeligsoft.com
Hi, Ed, Brian,
-----8<-----
This is where, IMO, the dependency of UML2 on Ecore introduces more
significant problems. The UML-based code generation is an extension of
Ecore's code generation, which implies the need to map UML metamodels to
Ecore. Unfortunately, this is a lossy mapping because UML simply has
more capabilities than EMOF.
For example, in UML, data types can define attributes and operations,
whereas in EMOF (hence Ecore) they cannot. This results in UML
transforming DataTypes to EClasses, which gives them object semantics
that they aren't intended to have. OCL (the spec and the MDT
implementation) solves this problem by creating companion EClasses to
the EDataTypes, to own the attributes and operations for them. (ugh)
Generalization is another semantic disconnect: in UML, DataTypes can
define subtyping relationships, but DataTypes in EMOF (and, hence, Ecore
EDataTypes) cannot. OCL doesn't have an answer to that, and it's a
darned nuisance. :-(
I wonder what it would take to refactor the EMF code generation
framework (and UML2) to provide code generation and run-time support for
"native" UML metamodels, in addition to Ecore? ;-)
| Re: help with existing meta data repository mapping [message #383883 is a reply to message #383882] |
Tue, 13 January 2009 13:58   |
Christian,
I wouldn't hold my breath while waiting! :-P
Christian W. Damus wrote:
> Hi, Ed, Brian,
> -----8<-----
>> course there is two way mapping between UML and Ecore, so that's
>> useful as well...
> of Ecore's code generation, which implies the need to map UML
> metamodels to Ecore. Unfortunately, this is a lossy mapping because
> UML simply has more capabilities than EMOF.
> Ecore EDataTypes) cannot. OCL doesn't have an answer to that, and
> it's a darned nuisance. :-(
> for "native" UML metamodels, in addition to Ecore? ;-)
| Re: help with existing meta data repository mapping [message #383885 is a reply to message #383881] |
Wed, 14 January 2009 01:51   |
On Tue, 13 Jan 2009 06:48:10 -0500, Ed Merks wrote:
<snip>
>> a few black holes in my knowledge of the system.
by the hour :)
Did I mention the database was 20Gb? That aside, converting it to another
format is a possibility, might be the easiest way forward right now.
>> started reading up on ecore tools.
> well...
It all comes down to how customizable Ecore Tools is. Due to the size of
the meta data I would like to know whether Ecore Tools could load only
the data we are viewing, not the whole tree.
| Re: help with existing meta data repository mapping [message #383887 is a reply to message #383885] |
Wed, 14 January 2009 08:48  |
--------------030802080008080001010000
Brian,
Comments below.
> <snip>
> by the hour :)
Certainly keep it in mind... A representation not tuned for the way it
needs to be used will tend to be an ongoing source of problems...
>> well...
Given the bloated nature of UML, certainly an Ecore representation will
take a lot less space than a UML representation of the same information;
both use the same Notation model for the graphical representation. None
of the editors is terribly good at dealing with things smaller than a
single resource.
CDO is doing some interesting things in this regard though
http://thegordian.blogspot.com/2008/11/how-scalable-are-my-m odels.html
And we're working on improving the basic footprint, which will benefit
any model that chooses to use it (including Ecore, UML2, and the
Notation model):
https://bugs.eclipse.org/bugs/show_bug.cgi?id=252501
<html>
<head>
</head>
Brian,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:gkk223$b91$2@build.eclipse.org" type="cite">
<pre wrap="">On Tue, 13 Jan 2009 06:48:10 -0500, Ed Merks wrote:
<snip>
</pre>
<pre wrap="">Well, this is an old project that I'm taking over and I am bound by an
</pre>
</blockquote>
<pre wrap="">Oh joy. Hopefully you're well paid. :-)
</pre>
</blockquote>
by the hour :)
</pre>
<pre wrap="">We end up with node data stored in a single self referencing table in a
</pre>
</blockquote>
<pre wrap="">It sounds slightly gross. :-P I suppose you're want to continue to read
</pre>
</blockquote>
</pre>
</blockquote>
needs to be used will tend to be an ongoing source of problems...<br>
<pre wrap="">
</pre>
<pre wrap="">At this stage I'm hoping EMF can help me out, I've created some
</pre>
</blockquote>
<pre wrap="">There is certainly a wealth of technology available. If you're using
well...
</pre>
</blockquote>
</pre>
</blockquote>
information; both use the same Notation model for the graphical
representation. None of the editors is terribly good at dealing with
things smaller than a single resource. <br>
<br>
CDO is doing some interesting things in this regard though<br>
<blockquote><a
href=" http://thegordian.blogspot.com/2008/11/how-scalable-are-my-m odels.html"> http://thegordian.blogspot.com/2008/11/how-scalable-are-my-m odels.html</a><br>
</blockquote>
Notation model):<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=252501">https://bugs.eclipse.org/bugs/show_bug.cgi?id=252501</a><br>
</blockquote>
<br>
<pre wrap="">
</pre>
</blockquote>
</body>
</html>
--------------030802080008080001010000--
| Re: help with existing meta data repository mapping [message #613828 is a reply to message #383876] |
Brian,
Comments below.
> Hi all
ask it here...
EObject instances.
mapping solution...
> Brian
| Re: help with existing meta data repository mapping [message #613830 is a reply to message #383878] |
> Brian,
> Comments below.
> EObject instances.
shouldn't have to.
> mapping solution...
>> Brian
thanks again Ed.
| Re: help with existing meta data repository mapping [message #613834 is a reply to message #383879] |
Brian,
Comments below.
>> Brian,
>> Comments below.
>> EObject instances.
> shouldn't have to.
>> mapping solution...
>>> Brian
> thanks again Ed.
<html>
<head>
</head>
Brian,<br>
<br>
Comments below.<br>
<br>
</pre>
<pre wrap="">Brian,
Comments below.
</pre>
</blockquote>
</pre>
</blockquote>
<pre wrap="">
</pre>
</pre>
</blockquote>
EObject instances.
</pre>
</blockquote>
shouldn't have to.
</pre>
</pre>
</blockquote>
mapping solution...
</pre>
<pre wrap="">Brian
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
well...<br>
<pre wrap="">
thanks again Ed.
</pre>
</blockquote>
</body>
</html>
| Re: help with existing meta data repository mapping [message #613836 is a reply to message #383881] |
Hi, Ed, Brian,
-----8<-----
| Re: help with existing meta data repository mapping [message #613838 is a reply to message #383882] |
Christian,
> Hi, Ed, Brian,
> -----8<-----
>> useful as well...
| Re: help with existing meta data repository mapping [message #613840 is a reply to message #383880] |
Wed, 14 January 2009 01:42  |
Hi Vlad
Dali seems to be more database entity mapping related, I have some meta
data from a system stored in a database.
Thanks for the link anyway, looks interesting.
Brian
On Tue, 13 Jan 2009 11:32:03 +0000, Vlad Varnica wrote:
> Hi Brian,
> Did you try to use Dali ?
> This could import your databases inside Eclipse 3.4. I have written a
> short modeling documentation on this subject at:
> http://www.forum-omondo.com/documentation_eclipseuml_2008/
Eclipse_Database/Reverse_Existing_Database/index.html
> Please note that you can user dali without EclipseUML 2008. In this
> example EclipseUML is just used as UML Editor for JPA annotations. Dali
> is a great project and because it is an Eclipse plugin you can use any
> other Eclipse plugin to expand Dali as a beautifier :-)
> Vlad
> Omondo
| Re: help with existing meta data repository mapping [message #613842 is a reply to message #383881] |
<snip>
by the hour :)
> well...
| Re: help with existing meta data repository mapping [message #613844 is a reply to message #383884] |
Wed, 14 January 2009 04:51  |
Brian,
I think you have two possible solutions. I mean either import into EMF and
use all EMF and related plugins, or import it in your java code and then
reverse engineer your code in order to create a UML 2.2 model (directly
without EMF transformation).
I don't know if you can import all information using Dali but you should
try and even extend the current reverse mechanism which is open source.
What is important is to consider is the quality of the extracted
information and how to load it into an EMF model or into an UML 2.2 model.
Good luck for your project :-)
Vlad,
| Re: help with existing meta data repository mapping [message #613845 is a reply to message #383885] |
Brian,
Comments below.
> <snip>
> by the hour :)
>> well...
single resource.
Notation model):
<html>
<head>
</head>
Brian,<br>
<br>
Comments below.<br>
<br>
<snip>
</pre>
</pre>
</blockquote>
</pre>
</blockquote>
by the hour :)
</pre>
</pre>
</blockquote>
</pre>
</blockquote>
</pre>
</blockquote>
<pre wrap="">
</pre>
</pre>
</blockquote>
well...
</pre>
</blockquote>
</pre>
</blockquote>
<br>
<blockquote><a
</blockquote>
<blockquote><a
</blockquote>
<br>
<pre wrap="">
</pre>
</blockquote>
</body>
</html>
Current Time: Fri Nov 07 16:42:09 EST 2025
Powered by FUDForum. Page generated in 0.51363 seconds
