Home » Archived » GMT (Generative Modeling Technologies) » [EVL]exists and unset references
[EVL]exists and unset references [message #383058] Tue, 29 April 2008 06:14 Go to next message
If the "exists" operation tests a reference which has not been given a
value, will it return false?
Re: [Epsilon][EVL] exists and unset references [message #383059 is a reply to message #383058] Tue, 29 April 2008 08:24 Go to previous messageGo to next message
Hi Andrew,
Could you please give an example of what you are trying to do?
Dimitrios
Re: [EVL]exists and unset references [message #383073 is a reply to message #383058] Sat, 03 May 2008 11:45 Go to previous messageGo to next message
dear Andrew,
Could you avoid using the [EVL] prefix in your posts?
There is no such component in GMT.
This is creating confusion.
Jean
"Andrew Lawson" <andyplawson@googlemail.com> a
Re: [Epsilon] exists and unset references [message #383075 is a reply to message #383073] Mon, 05 May 2008 10:02 Go to previous message
Dear Jean,
Thanks a lot for the reminder. To pre-empt more such posts we've added a
note in http://www.eclipse.org/gmt/epsilon/ emphasizing that posts about
Epsilon should be tagged with [Epsilon] and not with the names of
individual languages.
Dimitrios
Jean.Bezivin wrote:
> dear Andrew,
> Best regards,
> Jean
> "Andrew Lawson" <andyplawson@googlemail.com> a écrit dans le message de
> news: fv6se7$rbs$1@build.eclipse.org...
Re: [Epsilon][EVL] exists and unset references [message #615799 is a reply to message #383058] Tue, 29 April 2008 08:24 Go to previous message
Hi Andrew,
Dimitrios
Re: [EVL]exists and unset references [message #617605 is a reply to message #383058] Sat, 03 May 2008 11:45 Go to previous message
dear Andrew,
Jean
Re: [Epsilon] exists and unset references [message #617606 is a reply to message #383073] Mon, 05 May 2008 10:02 Go to previous message
Dear Jean,
Dimitrios
Jean.Bezivin wrote:
> dear Andrew,
> Best regards,
> Jean
Previous Topic:[TCS] Problem with running TCS
Next Topic:[Epsilon] NoSuchMethodError running EOL from Java
Current Time: Sun Jul 27 22:59:58 EDT 2025
Powered by FUDForum. Page generated in 0.06985 seconds
