Home » Eclipse Projects » EclipseLink » CACHE_TYPE_DEFAULT
CACHE_TYPE_DEFAULT [message #383007] Wed, 05 November 2008 10:50 Go to next message
I'm probably missing some documentation where this is mentioned, but it's probably a simple question.
I have two applications running, when I do a "refresh" I clear the entitymanager and refetch the entities. If the BM runs with:
cfg.put(PersistenceUnitProperties.CACHE_TYPE_DEFAULT, CacheType.NONE);
Then the changes is the database are visible in the refetched entities. However if the BM runs with:
cfg.put(PersistenceUnitProperties.CACHE_TYPE_DEFAULT, CacheType.Soft);
I can refresh until Christmans but the changes never shows up. A different EM in the same JVM will get the updated values and the change has been written back to the database.
If I use the CACHE_TYPE_* how do I really force to read stuff from the database?
Tom
Re: CACHE_TYPE_DEFAULT [message #383012 is a reply to message #383007] Thu, 06 November 2008 09:17 Go to previous messageGo to next message
clear() only clears the transactional cache, not the shared cache. To
refresh an object in the shared cache you need to call
EntityManager.refresh() with the object.
You can also set the "eclipselink.refresh"="true" query hint on any query.
I would not recommend using CacheType.None, if you truly do not which to
cache, you can use an isolated cache using the persistence.xml property
"eclipselink.cache.shared.default"="false".
If you want to manually clear the shared cache use can get the EclipseLink
Session (getServerSession()) from the EclipseLink JpaEntityManager, and
get the IdentityMapAccessor (getIdentityMapAccessor()) from the Session.
The IdentityMapAccessor contains API to clear and invalidate the cache.
On a live system invalidation is safer than clearing, as the objects may
be in use (initializeIdentityMaps(), invalidateAll()).
James
http://www.nabble.com/EclipseLink---Users-f26658.html
Re: CACHE_TYPE_DEFAULT [message #383013 is a reply to message #383012] Mon, 10 November 2008 05:09 Go to previous messageGo to next message
Understood.
Ok. My application is a change-heavy application; orders are entered, articles get a different status, data is changed all the time. The users know that other users may also change data, but they really need to be certain that when a refresh is done, they really have the most current data. Caching is only ok during a session (that is: work done not inside a transaction). As soon as a transaction has run, and the changes have been committed, data needs to be refreshed.
I'm a bit amazed that the cache is this cachy; as in that one has to explicitly refresh stuff. This model seems to work for webapps (many EM but all running within one JVM) and not a simple 2 tier fat client (just a few EM per JVM but multiple JVMs).
Hmmm. Maybe I should consider a distributed cache. That would solve the "has been updated" issue.
> EclipseLink Session (getServerSession()) from the EclipseLink
> JpaEntityManager, and get the IdentityMapAccessor
> (getIdentityMapAccessor()) from the Session. The IdentityMapAccessor
> contains API to clear and invalidate the cache. On a live system
> invalidation is safer than clearing, as the objects may be in use
Thanks for the complete reply!
Tom
Re: CACHE_TYPE_DEFAULT [message #383015 is a reply to message #383013] Mon, 10 November 2008 09:01 Go to previous messageGo to next message
It sounds like you do not want a shared cache. You should set,
Re: CACHE_TYPE_DEFAULT [message #500957 is a reply to message #383015] Mon, 30 November 2009 08:18 Go to previous messageGo to next message
Revisting the caching because I'm running into some performance issues during data entry in my Swing application.
Is it very strange that I expect entities to be cached within an EM, until the EM is cleared?
	public static void main(String[] args)
		System.out.println( "java.vm.version=" + System.getProperty("java.vm.version"));
		com.informix.jdbc.Version.main(new String[]{});
		// entitymanagerfactory
		Map<String, Object> lOptions = new HashMap<String, Object>();
		lOptions.put(PersistenceUnitProperties.JDBC_DRIVER, ...);
		lOptions.put(PersistenceUnitProperties.JDBC_URL, ...);
		lOptions.put(PersistenceUnitProperties.JDBC_USER, "user");
		lOptions.put(PersistenceUnitProperties.JDBC_PASSWORD, "user");
		lOptions.put(PersistenceUnitProperties.TARGET_DATABASE, nl.reinders.jdbc.InformixPlatform.class.getName());
		lOptions.put(PersistenceUnitProperties.TARGET_SERVER, TargetServer.None);
		EntityManagerFactory lEntityManagerFactory = Persistence.createEntityManagerFactory("reinders", lOptions);
		// entitymanager
		EntityManager lEntityManager = lEntityManagerFactory.createEntityManager();
		// test
		lEntityManager.createQuery("select t from Relation t where t.iRelationnr=1").getSingleResult(); // expect: not cached
		lEntityManager.createQuery("select t from Relation t where t.iRelationnr=1").getSingleResult(); // expect: cached
		lEntityManager.clear();
		// close shop
		lEntityManager.close();
		lEntityManagerFactory.close();
Re: CACHE_TYPE_DEFAULT [message #500968 is a reply to message #383007] Mon, 30 November 2009 09:14 Go to previous messageGo to next message
Yes, all objects read through an EntityManager will be cached locally until the EntityManager is cleared, or until the end of a transaction if using a JTA container managed EntityManager.
However, by default only the find() operation will obtain a cache hit by primary key. A JPQL query will not obtain a cache hit by default, unless the query hint "eclipselink.cache-usage"="CheckCacheByPrimaryKey ", or "eclipselink.query-type"="ReadObject" are set.
JPQL queries will still get a cache hit after accessing the database, so the object and its relationships will not be rebuilt, and object identity will be preserved.
Re: CACHE_TYPE_DEFAULT [message #501063 is a reply to message #500968] Mon, 30 November 2009 15:23 Go to previous messageGo to next message
Understood. Will I run into trouble when I simply set these hints on all queries?
Tom
Re: CACHE_TYPE_DEFAULT [message #501720 is a reply to message #383007] Thu, 03 December 2009 10:29 Go to previous messageGo to next message
Setting the cache-usage property is fine for an Query that returns a single object (getSingleObject()). But will not work will queries that return multiple objects (getResultList()), as you would only get a single object.
Re: CACHE_TYPE_DEFAULT [message #501731 is a reply to message #501720] Thu, 03 December 2009 10:51 Go to previous message
In fact, specifying that hint on a non-ReadObject query results in an exception.
Previous Topic:How to set JDBC fetch size on JPA query?
Next Topic:Memory footprint RelationalDescriptor
Current Time: Sun Jul 27 02:09:04 EDT 2025
Powered by FUDForum. Page generated in 0.05915 seconds
