Home » Modeling » Modeling (top-level project) » Amalgamate Models
Amalgamate Models [message #382206] Fri, 23 May 2008 10:04 Go to next message
Originally posted by: zhengxie.ie.ibm.com
I have two uml models, model1 and model2. I need to add all the elements
in model2 into model1, so that the new model1 has all the elements of
model1 and model2. How can I do it?
Thanks.
Re: Amalgamate Models [message #382207 is a reply to message #382206] Fri, 23 May 2008 10:47 Go to previous messageGo to next message
> Thanks.
Basicly, what I did is:
find all the Packages in model2 and add them to model1's packagedElements.
The problem is:
The applied stereotypes are lost.
Re: Amalgamate Models [message #382208 is a reply to message #382207] Sat, 24 May 2008 09:33 Go to previous messageGo to next message
Zheng,
Please use the UML newsgroup, which I've added to the "to" list of the
reply, for questions about UML.
Zheng Xie wrote:
>> elements in model2 into model1, so that the new model1 has all the
>> elements of model1 and model2. How can I do it?
>> Thanks.
> packagedElements.
> The problem is:
Re: Amalgamate Models [message #382211 is a reply to message #382208] Wed, 28 May 2008 09:47 Go to previous message
Hi Zheng,
For a general "copy" method you can have a look at EcoreUtil.copy(EObject
eObject).
The UMLUtil PackageMerger uses this to copy elements.
Alternatively have a look UML2Util.getAllContents() to get the contents of
one object. A defensive copy of the contents can be made.
- James.
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:g195bt$ct7$1@build.eclipse.org...
> Zheng,
>>> Thanks.
>> packagedElements.
>> The problem is:
Re: Amalgamate Models [message #607531 is a reply to message #382206] Fri, 23 May 2008 10:47 Go to previous message
> Thanks.
The problem is:
Re: Amalgamate Models [message #607532 is a reply to message #382207] Sat, 24 May 2008 09:33 Go to previous message
Zheng,
>> Thanks.
> packagedElements.
> The problem is:
Re: Amalgamate Models [message #607535 is a reply to message #382208] Wed, 28 May 2008 09:47 Go to previous message
Hi Zheng,
eObject).
- James.
> Zheng,
>>> Thanks.
>> packagedElements.
>> The problem is:
Previous Topic:Add New Resource Storage Mechanism
Next Topic:missing tracing tab
Current Time: Sun Oct 26 10:08:06 EDT 2025
Powered by FUDForum. Page generated in 0.05822 seconds
