[GMF|OAW] imcomplete gmfmap metamodel [message #381813] |
Mon, 18 February 2008 17:53  |
I am generating gmfmap models from an other model using oAW/xTend and the
EmfRegistryMetaModel. it is annoying to see that oaw doesn't find some
operations and properties for some gmfmap elements. these are at least:
mappings::CompartmentMapping::setCompartment(gmfgraph::Compa rtment)
mappings::CanvasMapping::setDiagramCanvas(gmfgraph::Canvas)
mappings::CanvasMapping::setPalette(tooldef::Palette)
mappings::LinkMapping::setTool(tooldef::CreationTool)
mappings::NodeMapping::setTool(tooldef::CreationTool)
mappings::LabelMapping::features
All of these are accessible when executing the oaw workflow but they are
marked as errors in editor. other features do work as expected (I havn't
tried all). I don't know if the error is in oaw or gmf.
Enrico
Re: [GMF|OAW] imcomplete gmfmap metamodel [message #381825 is a reply to message #381813] |
Fri, 22 February 2008 09:28  |
> Regards
> Enrico
Hi Enrico,
you could ask that on the openArchitectureWare forum, maybe they can
help you
http://www.openarchitectureware.org/forum
Regards, Stevy
Re: [GMF|OAW] imcomplete gmfmap metamodel [message #606534 is a reply to message #381813] |
Tue, 19 February 2008 06:43  |
hi enrico,
at least for the first 2 there's no such _method_ in the map metamodel.
There's a compartment _attribute_ in compartment mapping, so you might
want to try myCompartmentMapping.compartment = myCompartment.
does this help?
-stefan
> Regards
> Enrico
Re: [GMF|OAW] imcomplete gmfmap metamodel [message #606535 is a reply to message #381813] |
Tue, 19 February 2008 07:04  |
for some reason, my response isn't displayed- here again:
hi enrico,
does this help?
-stefan
> Regards
> Enrico
Re: [GMF|OAW] imcomplete gmfmap metamodel [message #606536 is a reply to message #381814] |
Tue, 19 February 2008 08:05  |
Hello Alex,
I am using an xtend model-to-model transformation to generate the
gmf-graph and gmf-map models out of my own model. the rest of the
gmf-workflow is the same.
I am using the following versions:
- GMF 1.0.100(20070912)/1.1.0(20070809)/2.0.1(20070921) all with build
id 2.0.1
- EMF 2.3.1(20070925)
- Eclipse Europa + all stable Updates
Enrico
Alex Shatalin schrieb:
> Hello Enrico,
> Are you using OAW code generator included into GMF or original version?
> Which GMF version do you use?
> Alex Shatalin
Re: [GMF|OAW] imcomplete gmfmap metamodel [message #606537 is a reply to message #381815] |
Tue, 19 February 2008 08:19  |
Hello Stefan,
the way to set a reference (and attributes too) in an emf-object in
xtend/oaw is by calling the setter for this attribute. but the reference
(for reading the value) itself does not exist either. so
myCompartmentMapping.compartment = myCompartment makes a error "no
viable alternative at input 'compartment'" and
myCompartmentMapping.compartment the error "Unknown
mappings::CompartmentMapping property, variable, type or enumeration
literal 'compartment'". the latter one does work in the runtime, but not
in the editor.
Enrico
SKuhn schrieb:
> hi enrico,
> does this help?
> -stefan
>> Regards
>> Enrico
Re: [GMF|OAW] imcomplete gmfmap metamodel [message #606541 is a reply to message #381818] |
Thu, 21 February 2008 09:01  |
has anyone an idea?
Enrico
> Hello Stefan,
> in the editor.
> Regards
> Enrico
> SKuhn schrieb:
>> hi enrico,
>> metamodel. There's a compartment _attribute_ in compartment mapping,
>> so you might want to try myCompartmentMapping.compartment =
>> myCompartment.
>> does this help?
>> -stefan
>>> the
>>> Regards
>>> Enrico
Re: [GMF|OAW] imcomplete gmfmap metamodel [message #606544 is a reply to message #381813] |
> Regards
> Enrico
Hi Enrico,
help you
Regards, Stevy
FUDForum. Page generated in 0.07279 seconds
