tooling workflow [message #381374] |
Wed, 07 November 2007 14:25  |
Just to be sure I've got this right. Consider I have three projects:
EMF model project (plugin)
JET transformation project (plugin)
target project
Can't get the transformation to run without loading up the runtime
workspace because of the emf dependency and because I want to have the
artifact placed into the target project...or maybe just because of the EMF
model.
If I am working on getting the JET template the way I want it, I find I am
having to change the template (e.g. fix a line of template code), restart
runtime workbench, repeat. Each workbench startup takes about 30 seconds
or so which is feeling like a pretty slow iteration.
Is this just the way it is?
Re: tooling workflow [message #381766 is a reply to message #381383] |
Thu, 15 November 2007 08:30  |
Christian:
One thing I find with hot code replacement is that you have to be really
careful when modifying code that is on the stack. So, when I'm doing this
with JET templates, I try to make the modifications after the JET
transformation has completed.
Also, a third way. Copy the JET Transformation project into your runtime
workbench, and make sure it is NOT one of the plug-ins loaded in the runtime
workbench. (This is, it is NOT selected on the Plug-ins tab of the runtime
workbenches launch configuration. This way, when you run the JET
transformation, you can take advantage of JETs runtime loading capabilities.
Paul
"Christian Hall" <christian.hall@equifax.com> wrote in message
news:db47fc767a1f19a2f330d7e7909ad03f$1@www.eclipse.org...
>I actually tried both before I posted. I think I know why one didn't
>work...here are the details:
> - I installed the semi-stable model plug-in into the workbench, but I
> forgot to close the plug-in project...I suspect that is why that didn't
> work.
> - I tried running the runtime workbench in debug. I got one of two
> behaviors. Either I'd get an error that said runtime code modification was
> not allowed or I'd make the change and it just would not stick in the
> runtime workbench. Given this is supposed to work, I'll try to see if I
> can narrow down why things were not working.
> Thanks for the response.
Re: tooling workflow [message #601602 is a reply to message #381374] |
Wed, 07 November 2007 14:56  |
Christian,
It's best to ask on the M2T newsgroup, which I've added to the "to" list
of the reply. It doesn't sound quite right to me though...
> target project
> EMF model.
> I am having to change the template (e.g. fix a line of template code),
> restart runtime workbench, repeat. Each workbench startup takes about
> 30 seconds or so which is feeling like a pretty slow iteration.
Re: tooling workflow [message #601615 is a reply to message #381376] |
Mon, 12 November 2007 08:31  |
Also, if this is just the way it is, can someone suggest a way to minimize
startup time...I tried to strip down the workspace but by the time I added
everything it seemed like I needed to be able to see the run dialog and
execute the transformation, I pretty much have my original workspace
plugin list.
I have to believe that there is a way to get things to iterate faster.
Maybe folks are putting their models in the same plugin as the
transformation?
Re: tooling workflow [message #601627 is a reply to message #381380] |
Tue, 13 November 2007 07:53  |
Christian:
Sorry, I somehow missed this post earlier.
Some tips:
1) Start your runtime workbench using Debug, instead of Run. This way, hot
code replace can update the generated template methods in the runtime VM on
the fly. It is best to do such replacements when the transformation is not
running.
2) If your EMF model is stable, you could install it in your development
workbench. That way, you could run the JET transformation directly from the
development workbench.
Paul
news:9d7c8a48262e3a2a0a27aa148550d81f$1@www.eclipse.org...
> plugin list.
> transformation?
Re: tooling workflow [message #601633 is a reply to message #381382] |
Tue, 13 November 2007 08:21  |
work.
Re: tooling workflow [message #602375 is a reply to message #381383] |
Christian:
Paul
> work.
FUDForum. Page generated in 0.08011 seconds
