Home » Modeling » Modeling (top-level project) » simple ecore model editor crashes on Eclipse 3.3.x+EMF2.3@leopard
simple ecore model editor crashes on Eclipse 3.3.x+EMF2.3@leopard [message #381363] Fri, 02 November 2007 04:37 Go to next message
Originally posted by: htran.infosys.tuwien.ac.at
--------------040207040100070403020203
Dear all,
I'm using Europa 3.3.x and EMF 2.3 to develop some Ecore models in the
included Simple Ecore Model Editor. There is no issue in Windows XP SP2,
OSX 10.4 (Tiger), Ubuntu 7.x. A few days ago, I switched to Leopard and
faced with a strange issue. I describe in details as following:
For instance, there are two EClass A and B. I create an EReference of A,
called 'aRefToB'. Using mouse to manipulate on the Properties View, I
choose B as the EType of 'aRefToB', then I click immediately on any
other attribute row, for instance, EOpposite. It crashes. There is no
warning dialog after that, and no info from Error Log as well.
You can find some info from the (stripped down)-logs and the
configuration file attached here.
I really appreciate any of your comments.
Huy Tran
PS: I already submitted a bug report to Apple as well.
Content-Type: text/plain; x-mac-type="0"; x-mac-creator="0";
name="system.log"
Content-Disposition: inline;
filename="system.log"
Nov 2 09:33:16 yaja ReportCrash[217]: Formulating crash report for process eclipse[206]
Nov 2 09:33:17 yaja ReportCrash[217]: Saved crashreport to /Users/htran/Library/Logs/CrashReporter/eclipse_2007-11-02-0 93314_huy-trans-macbook.crash using uid: 501 gid: 20, euid: 501 egid: 20
Nov 2 09:33:17 yaja com.apple.launchd[72] ([0x0-0x27027].org.eclipse.eclipse[206]): Exited abnormally: Segmentation fault
Nov 2 09:34:43 yaja /usr/sbin/ocspd[229]: starting
Nov 2 09:34:44 yaja SubmitReport[226]: Submitted compressed crash report for eclipse
name="eclipse_2007-11-02-093314_huy-trans-macbook.crash"
filename="eclipse_2007-11-02-093314_huy-trans-macbook.crash "
Process: eclipse [206]
Path: /Users/htran/tool/programing/eclipse/Eclipse.app/Contents/Ma cOS/eclipse
Identifier: org.eclipse.eclipse
Version: 3.3 (3.3)
Code Type: X86 (Native)
Parent Process: launchd [72]
Date/Time: 2007-11-02 09:33:14.541 +0100
OS Version: Mac OS X 10.5 (9A581)
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000c00000f7
Crashed Thread: 0
Application Specific Information:
Java information:
Version: Java HotSpot(TM) Client VM (1.5.0_13-119 mixed mode)
Virtual Machine version: Java HotSpot(TM) Client VM (1.5.0_13-119) for macosx-x86, built on Sep 28 2007 23:59:21 by root with gcc 4.0.1 (Apple Inc. build 5465)
Exception type: Bus Error (0xa) at pc=0x90baa286
Current thread (0x11001570): JavaThread "main" [_thread_in_native, id=-1606267040]
Stack: [0xbf800000,0xc0000000)
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j org.eclipse.swt.internal.carbon.OS.CallNextEventHandler(II)I +0
j org.eclipse.swt.widgets.Tree.kEventMouseDown(III)I+29
j org.eclipse.swt.widgets.Widget.mouseProc(III)I+68
j org.eclipse.swt.widgets.Display.mouseProc(III)I+464
v ~StubRoutines::call_stub
j org.eclipse.swt.internal.carbon.OS.SendEventToEventTarget(II )I+0
j org.eclipse.swt.widgets.Display.readAndDispatch()Z+52
j org.eclipse.ui.internal.Workbench.runEventLoop(Lorg/eclipse/ jface/window/Window$IExceptionHandler;Lorg/eclipse/swt/widge ts/Display;)V+9
j org.eclipse.ui.internal.Workbench.runUI()I+336
j org.eclipse.ui.internal.Workbench.access$4(Lorg/eclipse/ui/i nternal/Workbench;)I+1
j org.eclipse.ui.internal.Workbench$4.run()V+23
j org.eclipse.core.databinding.observable.Realm.runWithDefault (Lorg/eclipse/core/databinding/observable/Realm;Ljava/lang/R unnable;)V+12
j org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg /eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/Wor kbenchAdvisor;)I+18
j org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse /swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAd visor;)I+2
j org.eclipse.ui.internal.ide.application.IDEApplication.start (Lorg/eclipse/equinox/app/IApplicationContext;)Ljava/lang/Ob ject;+81
j org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/ lang/Object;)Ljava/lang/Object;+102
j org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(Ljava/lang/Object;)Ljava/lang/Object;+103
j org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(Ljava/lang/Object;)Ljava/lang/Object;+29
j org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/la ng/Object;)Ljava/lang/Object;+149
j org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/l ang/String;Ljava/lang/Runnable;)Ljava/lang/Object;+183
j sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/refl ect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/ Object;+0
j sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Objec t;[Ljava/lang/Object;)Ljava/lang/Object;+87
j sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/O bject;[Ljava/lang/Object;)Ljava/lang/Object;+6
j java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lan g/Object;)Ljava/lang/Object;+111
j org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lan g/String;[Ljava/net/URL;)V+210
j org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/Strin g;)V+114
j org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+ 4
Java Threads: ( => current thread )
0x11051960 JavaThread "Worker-5" [_thread_blocked, id=16363520]
0x110447b0 JavaThread "Worker-4" [_thread_blocked, id=15481344]
0x11043bf0 JavaThread "Worker-3" [_thread_blocked, id=16322560]
0x11043060 JavaThread "Worker-2" [_thread_blocked, id=15477760]
0x11042820 JavaThread "Worker-1" [_thread_blocked, id=15638016]
0x11038760 JavaThread "Java indexing" daemon [_thread_blocked, id=15880192]
0x11029240 JavaThread "Worker-0" [_thread_blocked, id=15575040]
0x11014490 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=8981504]
0x11013fa0 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=8927232]
0x11013650 JavaThread "State Data Manager" daemon [_thread_blocked, id=8923648]
0x11009040 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=8509440]
0x11008610 JavaThread "CompilerThread0" daemon [_thread_blocked, id=8505856]
0x11008170 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=8502272]
0x11007810 JavaThread "Finalizer" daemon [_thread_blocked, id=8498688]
0x11007410 JavaThread "Reference Handler" daemon [_thread_blocked, id=8404480]
=>0x11001570 JavaThread "main" [_thread_in_native, id=-1606267040]
Other Threads:
0x11006b60 VMThread [id=8465408]
0x11009c40 WatcherThread [id=8513024]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 3200K, used 991K [0x15580000, 0x158f0000, 0x16930000)
eden space 2880K, 29% used [0x15580000, 0x15653068, 0x15850000)
from space 320K, 46% used [0x158a0000, 0x158c4da8, 0x158f0000)
to space 320K, 0% used [0x15850000, 0x15850000, 0x158a0000)
tenured generation total 41700K, used 25783K [0x16930000, 0x191e9000, 0x25580000)
the space 41700K, 61% used [0x16930000, 0x1825dc88, 0x1825de00, 0x191e9000)
compacting perm gen total 35584K, used 35484K [0x25580000, 0x27840000, 0x35580000)
the space 35584K, 99% used [0x25580000, 0x27827000, 0x27827000, 0x27840000)
No shared spaces configured.
Virtual Machine arguments:
JVM args: -Xdock:icon=../Resources/Eclipse.icns -XstartOnFirstThread -Xms40m -Xmx256m -XX:MaxPermSize=256m -Dorg.eclipse.swt.internal.carbon.smallFonts
Java command: <unknown>
launcher type: generic
Thread 0 Crashed:
0 com.apple.HIToolbox 0x90baa286 HIView::SendFocusPartChanged(short, short, unsigned long) + 100
1 com.apple.HIToolbox 0x90ba9914 HIView::SetFocusPart(short, unsigned char, unsigned char, unsigned long, FocusData*) + 518
2 com.apple.HIToolbox 0x90ba9663 HIViewSetFocus + 239
3 com.apple.HIToolbox 0x90ba956f SetKeyboardFocus + 33
4 com.apple.HIToolbox 0x90c24c66 HIView::ClickSelf(OpaqueEventRef*) + 322
5 com.apple.HIToolbox 0x90b66ab1 HIView::EventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 2391
6 com.apple.HIToolbox 0x90b58863 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1181
7 com.apple.HIToolbox 0x90b57c9d SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 405
8 com.apple.HIToolbox 0x90b7408e SendEventToEventTarget + 52
9 com.apple.HIToolbox 0x90c222af HIView::Click(OpaqueEventRef*) + 329
10 com.apple.HIToolbox 0x90c22111 HandleClickAsHIView(OpaqueWindowPtr*, OpaqueEventRef*) + 151
11 com.apple.HIToolbox 0x90c21a9d HandleWindowClick(OpaqueWindowPtr*, Point, short, unsigned long, OpaqueEventRef*) + 505
12 com.apple.HIToolbox 0x90c2188f HandleMouseEvent(OpaqueEventHandlerCallRef*, OpaqueEventRef*) + 791
13 com.apple.HIToolbox 0x90bdcfca StandardWindowEventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 96
14 com.apple.HIToolbox 0x90b58863 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1181
15 com.apple.HIToolbox 0x90b57c9d SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 405
16 com.apple.HIToolbox 0x90bc9df1 CallNextEventHandler + 95
17 libswt-pi-carbon-3347.jnilib 0x480f8e5d Java_org_eclipse_swt_internal_carbon_OS_CallNextEventHandler + 31
18 ??? 0x135859b1 0 + 324557233
19 ??? 0x1357fa7f 0 + 324532863
20 ??? 0x1357fa7f 0 + 324532863
21 ??? 0x1357fa7f 0 + 324532863
22 ??? 0x1357d227 0 + 324522535
23 libjvm.dylib 0x004d263a 0x3b9000 + 1152570
24 libjvm.dylib 0x004d2356 0x3b9000 + 1151830
25 libjvm.dylib 0x0045c68c 0x3b9000 + 669324
26 libjvm.dylib 0x005c848b JNI_CreateJavaVM_Impl + 101963
27 libswt-carbon-3347.jnilib 0x480eef5e callback + 794
28 ??? 0x480d4455 0 + 1208829013
29 com.apple.HIToolbox 0x90b58863 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1181
30 com.apple.HIToolbox 0x90b57c9d SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 405
31 com.apple.HIToolbox 0x90b7408e SendEventToEventTarget + 52
32 com.apple.HIToolbox 0x90b86b73 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1211
33 com.apple.HIToolbox 0x90b58c1c DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2134
34 com.apple.HIToolbox 0x90b57c9d SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 405
35 com.apple.HIToolbox 0x90b7408e SendEventToEventTarget + 52
36 libswt-pi-carbon-3347.jnilib 0x48109b3b Java_org_eclipse_swt_internal_carbon_OS_SendEventToEventTarg et + 31
37 ??? 0x135859b1 0 + 324557233
38 ??? 0x1357fa7f 0 + 324532863
39 ??? 0x1357fb2b 0 + 324533035
40 ??? 0x1357f9d3 0 + 324532691
41 ??? 0x1357fa7f 0 + 324532863
42 ??? 0x1357fa7f 0 + 324532863
43 ??? 0x1357fcd9 0 + 324533465
44 ??? 0x1357f9d3 0 + 324532691
45 ??? 0x1357fa7f 0 + 324532863
46 ??? 0x1357fa7f 0 + 324532863
47 ??? 0x1357fdb0 0 + 324533680
48 ??? 0x1357fdb0 0 + 324533680
49 ??? 0x1357faaa 0 + 324532906
50 ??? 0x1357faaa 0 + 324532906
51 ??? 0x1357faaa 0 + 324532906
52 ??? 0x1357d227 0 + 324522535
53 libjvm.dylib 0x004d263a 0x3b9000 + 1152570
54 libjvm.dylib 0x004d2356 0x3b9000 + 1151830
55 libjvm.dylib 0x004744b1 0x3b9000 + 767153
56 libjvm.dylib 0x00490e4f 0x3b9000 + 884303
57 libjvm.dylib 0x0060f78b JVM_InvokeMethod + 411
58 ??? 0x135859b1 0 + 324557233
59 ??? 0x1357faaa 0 + 324532906
60 ??? 0x1357faaa 0 + 324532906
61 ??? 0x1357fdb0 0 + 324533680
62 ??? 0x1357faaa 0 + 324532906
63 ??? 0x1357f9d3 0 + 324532691
64 ??? 0x1357f9d3 0 + 324532691
65 ??? 0x1357d227 0 + 324522535
66 libjvm.dylib 0x004d263a 0x3b9000 + 1152570
67 libjvm.dylib 0x004d2356 0x3b9000 + 1151830
68 libjvm.dylib 0x0045c68c 0x3b9000 + 669324
69 libjvm.dylib 0x005c824a JNI_CreateJavaVM_Impl + 101386
70 eclipse_1021.so 0x000198ff startJavaJNI + 454
71 eclipse_1021.so 0x0001884f startJavaVM + 50
72 eclipse_1021.so 0x0001626a run + 1113
73 org.eclipse.eclipse 0x00001f7b original_main + 821
74 org.eclipse.eclipse 0x000027fa main + 768
75 org.eclipse.eclipse 0x00001c2a _start + 216
76 org.eclipse.eclipse 0x00001b51 start + 41
Thread 1:
0 libSystem.B.dylib 0x928bd8e6 mach_msg_trap + 10
1 libSystem.B.dylib 0x928c50dc mach_msg + 72
2 libSystem.B.dylib 0x92932843 mach_msg_server + 491
3 libjvm.dylib 0x003c7ed5 0x3b9000 + 61141
4 libjvm.dylib 0x003c7c95 0x3b9000 + 60565
5 libjvm.dylib 0x0067dcc5 JVM_RaiseSignal + 441189
6 libSystem.B.dylib 0x929398cb _pthread_body + 27
Thread 2:
2 libjvm.dylib 0x004d1563 0x3b9000 + 1148259
3 libjvm.dylib 0x004d13fc 0x3b9000 + 1147900
4 libjvm.dylib 0x004161ed 0x3b9000 + 381421
5 libjvm.dylib 0x00415d57 0x3b9000 + 380247
6 libjvm.dylib 0x0067dcc5 JVM_RaiseSignal + 441189
7 libSystem.B.dylib 0x929398cb _pthread_body + 27
Thread 3:
2 libjvm.dylib 0x004d161a 0x3b9000 + 1148442
3 libjvm.dylib 0x0041728a 0x3b9000 + 385674
4 libjvm.dylib 0x00416875 0x3b9000 + 383093
5 libjvm.dylib 0x005f8201 JVM_MonitorWait + 465
6 ??? 0x135859b1 0 + 324557233
7 ??? 0x13baa248 0 + 330998344
8 ??? 0x135f8980 0 + 325028224
9 ??? 0x1357d227 0 + 324522535
10 libjvm.dylib 0x004d263a 0x3b9000 + 1152570
11 libjvm.dylib 0x00416763 0x3b9000 + 382819
12 libjvm.dylib 0x00416655 0x3b9000 + 382549
13 libjvm.dylib 0x00416595 0x3b9000 + 382357
14 libjvm.dylib 0x004164b8 0x3b9000 + 382136
15 libjvm.dylib 0x0067dcc5 JVM_RaiseSignal + 441189
16 libSystem.B.dylib 0x929398cb _pthread_body + 27
Thread 4:
7 ??? 0x1376a804 0 + 326543364
8 ??? 0x1376a5cc 0 + 326542796
9 ??? 0x135f1dc0 0 + 325000640
10 ??? 0x1357faaa 0 + 324532906
11 ??? 0x1357d227 0 + 324522535
12 libjvm.dylib 0x004d263a 0x3b9000 + 1152570
13 libjvm.dylib 0x00416763 0x3b9000 + 382819
14 libjvm.dylib 0x00416655 0x3b9000 + 382549
15 libjvm.dylib 0x00416595 0x3b9000 + 382357
16 libjvm.dylib 0x004164b8 0x3b9000 + 382136
17 libjvm.dylib 0x0067dcc5 JVM_RaiseSignal + 441189
18 libSystem.B.dylib 0x929398cb _pthread_body + 27
Thread 5:
0 libSystem.B.dylib 0x928bd922 semaphore_wait_trap + 10
1 libjvm.dylib 0x004179ae 0x3b9000 + 387502
2 libjvm.dylib 0x00417695 0x3b9000 + 386709
3 libjvm.dylib 0x004164b8 0x3b9000 + 382136
4 libjvm.dylib 0x0067dcc5 JVM_RaiseSignal + 441189
5 libSystem.B.dylib 0x929398cb _pthread_body + 27
Thread 6:
3 libjvm.dylib 0x004d12b9 0x3b9000 + 1147577
4 libjvm.dylib 0x00417fdb 0x3b9000 + 389083
5 libjvm.dylib 0x00417cb8 0x3b9000 + 388280
Thread 7:
4 libjvm.dylib 0x004180f0 0x3b9000 + 389360
5 libjvm.dylib 0x004164b8 0x3b9000 + 382136
Thread 8:
3 libjvm.dylib 0x0041890f 0x3b9000 + 391439
4 libjvm.dylib 0x0041845a 0x3b9000 + 390234
Thread 9:
3 libjvm.dylib 0x00418769 0x3b9000 + 391017
4 libjvm.dylib 0x006076c1 JVM_Sleep + 481
5 ??? 0x135859b1 0 + 324557233
6 ??? 0x1357f9d3 0 + 324532691
7 ??? 0x1357fcd9 0 + 324533465
8 ??? 0x1357d227 0 + 324522535
9 libjvm.dylib 0x004d263a 0x3b9000 + 1152570
10 libjvm.dylib 0x00416763 0x3b9000 + 382819
11 libjvm.dylib 0x00416655 0x3b9000 + 382549
12 libjvm.dylib 0x00416595 0x3b9000 + 382357
13 libjvm.dylib 0x004164b8 0x3b9000 + 382136
14 libjvm.dylib 0x0067dcc5 JVM_RaiseSignal + 441189
15 libSystem.B.dylib 0x929398cb _pthread_body + 27
Thread 10:
7 ??? 0x1357f9d3 0 + 324532691
8 ??? 0x1357f9d3 0 + 324532691
10 ??? 0x1357d227 0 + 324522535
11 libjvm.dylib 0x004d263a 0x3b9000 + 1152570
12 libjvm.dylib 0x00416763 0x3b9000 + 382819
13 libjvm.dylib 0x00416655 0x3b9000 + 382549
14 libjvm.dylib 0x00416595 0x3b9000 + 382357
15 libjvm.dylib 0x004164b8 0x3b9000 + 382136
16 libjvm.dylib 0x0067dcc5 JVM_RaiseSignal + 441189
17 libSystem.B.dylib 0x929398cb _pthread_body + 27
Thread 11:
Thread 12:
8 ??? 0x138af2fc 0 + 327873276
Thread 13:
9 ??? 0x1357fcd9 0 + 324533465
Thread 14:
2 com.apple.CoreFoundation 0x92aee0fe CFRunLoopRunSpecific + 1806
3 com.apple.CoreFoundation 0x92aeed38 CFRunLoopRunInMode + 88
4 com.apple.CFNetwork 0x959e67be CFURLCacheWorkerThread(void*) + 396
5 libSystem.B.dylib 0x928ee075 _pthread_start + 321
6 libSystem.B.dylib 0x928edf32 thread_start + 34
Thread 15:
Thread 16:
Thread 17:
Thread 18:
Thread 19:
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000005 ebx: 0x90ba9722 ecx: 0xffffffff edx: 0xc0000003
edi: 0x4b41a5d0 esi: 0x00000000 ebp: 0xbfffd5e8 esp: 0xbfffd590
ss: 0x0000001f efl: 0x00010246 eip: 0x90baa286 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0xc00000f7
Binary Images:
0x1000 - 0x3fff +org.eclipse.eclipse 3.3 (3.3) /Users/htran/tool/programing/eclipse/Eclipse.app/Contents/Ma cOS/eclipse
0x15000 - 0x1cfff +eclipse_1021.so ??? (???) /Users/htran/tool/programing/eclipse/plugins/org.eclipse.equ inox.launcher.carbon.macosx_1.0.2.R331_v20071019/eclipse_102 1.so
0x25000 - 0x2cffd com.apple.JavaVM 12.0.0 (12.0.0) <44b9536fe4d7c7fcb3506adb695a180f> /System/Library/Frameworks/JavaVM.framework/JavaVM
0x45000 - 0x4cfe0 libverify.dylib ??? (???) <7a69785e6278690ecba70a4ec32d732a> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/L ibraries/libverify.dylib
0x52000 - 0x6cfef libjava.jnilib ??? (???) <42b19094a14d6f296d7186946847ce86> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/L ibraries/libjava.jnilib
0x7a000 - 0x85ffb libzip.jnilib ??? (???) <8d58d4a6b64d83d08732a310918c7f5a> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/L ibraries/libzip.jnilib
0x3b9000 - 0x708ffb libjvm.dylib ??? (???) <5bd51fa3ce82d6e1bd1582f46b2b8bac> /System/Library/Frameworks/JavaVM.framework/Versions/Current JDK/Libraries/libjvm.dylib
0x37814000 - 0x37815ff3 ATSHI.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Ver sions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI. dylib
0x37bf3000 - 0x37bf5ffe com.apple.AutomatorCMM 1.1 (153) <1437bba93b42b020c74a4fd2574b53ea> /System/Library/Contextual Menu Items/AutomatorCMM.plugin/Contents/MacOS/AutomatorCMM
0x37d31000 - 0x37e17ff7 com.apple.RawCamera.bundle 2.0 (2.0) /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS /RawCamera
0x3bb19000 - 0x3bb24ffb libnet.jnilib ??? (???) <d6087c096127755a3769819c04fe6a19> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/L ibraries/libnet.jnilib
0x3bb2b000 - 0x3bb2effc libnio.jnilib ??? (???) <57a95ec155863e0a0e7b2636d7c461f2> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/L ibraries/libnio.jnilib
0x47521000 - 0x47522ffc com.apple.BluetoothMenu 2.0 (2.0f20) /System/Library/Contextual Menu Items/BluetoothContextualMenu.plugin/Contents/MacOS/Bluetoot hContextualMenu
0x480e0000 - 0x480e0fff +liblocalfile_1_0_0.jnilib ??? (???) /Users/htran/tool/programing/eclipse/configuration/org.eclip se.osgi/bundles/33/1/.cp/os/macosx/liblocalfile_1_0_0.jnilib
0x480ec000 - 0x480eeffd +libswt-carbon-3347.jnilib ??? (???) /Users/htran/tool/programing/eclipse/configuration/org.eclip se.osgi/bundles/113/1/.cp/libswt-carbon-3347.jnilib
0x480f2000 - 0x48124ff7 +libswt-pi-carbon-3347.jnilib ??? (???) /Users/htran/tool/programing/eclipse/configuration/org.eclip se.osgi/bundles/113/1/.cp/libswt-pi-carbon-3347.jnilib
0x48eff000 - 0x48f02fff +libswt-cocoa-carbon-3347.jnilib ??? (???) /Users/htran/tool/programing/eclipse/configuration/org.eclip se.osgi/bundles/113/1/.cp/libswt-cocoa-carbon-3347.jnilib
0x48f08000 - 0x48f09ffd libframeembedding.jnilib ??? (???) <0e8a627fe85b36429ae0359a93cd06ef> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/L ibraries/libframeembedding.jnilib
0x48f0f000 - 0x48f10fff com.apple.JavaFrameEmbedding 12.0.0 (12.0.0) <3f4d91a1bffeca4dbfe46a77b2359507> /System/Library/Frameworks/JavaFrameEmbedding.framework/Vers ions/A/JavaFrameEmbedding
0x48f97000 - 0x48f9dfcb +com.roxio.ToastItPlugin ToastIt 1.1.2 (build 17) (1.1.2) /Users/htran/Library/Contextual Menu Items/ToastIt.plugin/Contents/MacOS/ToastIt
0x48fd7000 - 0x48fdafff com.apple.BezelServicesFW 1.4.533 (1.4.533) /System/Library/PrivateFrameworks/BezelServices.framework/Ve rsions/A/BezelServices
0x49003000 - 0x49008fff com.apple.FolderActionsMenu 1.3.2 (1.3.2) <9ba69ef0bec96264a79fa28b3a5f058b> /System/Library/Contextual Menu Items/FolderActionsMenu.plugin/Contents/MacOS/FolderActionsM enu
0x4901a000 - 0x491b5fff libawt.jnilib ??? (???) <5a124edd404b53e9840c88c4c04f86b8> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/L ibraries/libawt.jnilib
0x49c52000 - 0x49cbfff7 com.apple.Bluetooth 2.0 (2.0f20) <3607252944b8cd29f3e9f5a00cc32247> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/ IOBluetooth
0x8fe00000 - 0x8fe2d883 dyld 95.3 (???) <81592e798780564b5d46b988f7ee1a6a> /usr/lib/dyld
0x90003000 - 0x9007dff8 com.apple.print.framework.PrintCore 5.5 (245) <9441d178f4b430cf92b67bf346646693> /System/Library/Frameworks/ApplicationServices.framework/Ver sions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x900cc000 - 0x900cffff com.apple.help 1.1 (36) <b507b08e484cb89033e9cf23062d77de> /System/Library/Frameworks/Carbon.framework/Versions/A/Frame works/Help.framework/Versions/A/Help
0x900d0000 - 0x901b4ffb com.apple.CoreData 100 (185) <a4e63784275e25e62f57e75e0af0b94d> /System/Library/Frameworks/CoreData.framework/Versions/A/Cor eData
0x90202000 - 0x902e3ff7 libxml2.2.dylib ??? (???) <450ec38b57fb46013847cce851001a2f> /usr/lib/libxml2.2.dylib
0x902e4000 - 0x9036bff7 libsqlite3.0.dylib ??? (???) <273efcb717e89c21207c851d7d33fda4> /usr/lib/libsqlite3.0.dylib
0x9036c000 - 0x903b1fef com.apple.Metadata 10.5.0 (398) <4fd74fba0062c2e08ec4b1c10b40ff63> /System/Library/Frameworks/CoreServices.framework/Versions/A /Frameworks/Metadata.framework/Versions/A/Metadata
0x903b2000 - 0x903beff5 libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libra ries/libGL.dylib
0x903bf000 - 0x903cfffc com.apple.LangAnalysis 1.6.4 (1.6.4) <cbeb17ab39f28351fe2ab5b82bf465bc> /System/Library/Frameworks/ApplicationServices.framework/Ver sions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAna lysis
0x903d0000 - 0x90482ffb libcrypto.0.9.7.dylib ??? (???) <330b0e48e67faffc8c22dfc069ca7a47> /usr/lib/libcrypto.0.9.7.dylib
0x90545000 - 0x908dafef com.apple.QuartzCore 1.5.0 (1.5.0) <363cc63c669523cc3fec577949bb1308> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Q uartzCore
0x90941000 - 0x909fcfe3 com.apple.WebKit 5523.10.3 (5523.10.3) <2741777559b3948d520a4d126330dbce> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKi t
0x909fd000 - 0x909fdff8 com.apple.ApplicationServices 34 (34) <8f910fa65f01d401ad8d04cc933cf887> /System/Library/Frameworks/ApplicationServices.framework/Ver sions/A/ApplicationServices
0x909fe000 - 0x90b36ff7 libicucore.A.dylib ??? (???) <afcea652ff2ec36885b2c81c57d06d4c> /usr/lib/libicucore.A.dylib
0x90b37000 - 0x90b4ffff com.apple.openscripting 1.2.6 (???) <b8e553df643f2aec68fa968b3b459b2b> /System/Library/Frameworks/Carbon.framework/Versions/A/Frame works/OpenScripting.framework/Versions/A/OpenScripting
0x90b50000 - 0x90b50ffc com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/Au dioUnit
0x90b51000 - 0x90e57fff com.apple.HIToolbox 1.5.0 (???) <1b872a7151ee3f80c9c736a3e46d00d9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frame works/HIToolbox.framework/Versions/A/HIToolbox
0x90e58000 - 0x91324ffe libGLProgrammability.dylib ??? (???) <ebd2e6c99ec2662b4bdaa3212ab94aed> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libra ries/libGLProgrammability.dylib
0x91325000 - 0x9137efff libGLU.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libra ries/libGLU.dylib
0x92178000 - 0x92186ffd libz.1.dylib ??? (???) <5ddd8539ae2ebfd8e7cc1c57525385c7> /usr/lib/libz.1.dylib
0x9218f000 - 0x922b3fe3 com.apple.audio.toolbox.AudioToolbox 1.5 (1.5) /System/Library/Frameworks/AudioToolbox.framework/Versions/A /AudioToolbox
0x922c4000 - 0x922cdfff com.apple.speech.recognition.framework 3.7.24 (3.7.24) <d3180f9edbd9a5e6f283d6156aa3c602> /System/Library/Frameworks/Carbon.framework/Versions/A/Frame works/SpeechRecognition.framework/Versions/A/SpeechRecogniti on
0x922ce000 - 0x9235aff7 com.apple.LaunchServices 283 (283) <30168051779817916e04eb8e85fcc17f> /System/Library/Frameworks/CoreServices.framework/Versions/A /Frameworks/LaunchServices.framework/Versions/A/LaunchServic es
0x9235b000 - 0x923abff7 com.apple.HIServices 1.6.0 (???) <d74aa73e4cfd30a08fb169198a8d2539> /System/Library/Frameworks/ApplicationServices.framework/Ver sions/A/Frameworks/HIServices.framework/Versions/A/HIService s
0x926b1000 - 0x9270effb libstdc++.6.dylib ??? (???) <04b812dcec670daa8b7d2852ab14be60> /usr/lib/libstdc++.6.dylib
0x92733000 - 0x92733ff8 com.apple.Cocoa 6.5 (???) <e064f94d969ce25cb7de3cfb980c3249> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x92734000 - 0x927dbff7 com.apple.QD 3.11.49 (???) <ca01e72078d30d6b183aa5224344608b> /System/Library/Frameworks/ApplicationServices.framework/Ver sions/A/Frameworks/QD.framework/Versions/A/QD
0x927ec000 - 0x92800ff3 com.apple.ImageCapture 4.0 (5.0.0) /System/Library/Frameworks/Carbon.framework/Versions/A/Frame works/ImageCapture.framework/Versions/A/ImageCapture
0x92801000 - 0x92829ff7 com.apple.shortcut 1 (1.0) <057783867138902b52bc0941fedb74d1> /System/Library/PrivateFrameworks/Shortcut.framework/Version s/A/Shortcut
0x9282a000 - 0x9282affd com.apple.Accelerate.vecLib 3.4 (vecLib 3.4) /System/Library/Frameworks/Accelerate.framework/Versions/A/F rameworks/vecLib.framework/Versions/A/vecLib
0x92831000 - 0x9284ffff libresolv.9.dylib ??? (???) <54e6a08c2f108bdf5916fb483d51961b> /usr/lib/libresolv.9.dylib
0x928bd000 - 0x92a17fe3 libSystem.B.dylib ??? (???) <8ecc83dc0399be3946f7a46e88cf4bbb> /usr/lib/libSystem.B.dylib
0x92a7c000 - 0x92baefe7 com.apple.CoreFoundation 6.5 (476) <8bfebc0dbad6fc33bea0fa00a1b9ec37> /System/Library/Frameworks/CoreFoundation.framework/Versions /A/CoreFoundation
0x92bb0000 - 0x92bd7fff libcups.2.dylib ??? (???) <6b61eb99e6f5dd2d66cd224e9f82427d> /usr/lib/libcups.2.dylib
0x92bd8000 - 0x92fe8fef libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/F rameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x93168000 - 0x93192fef libauto.dylib ??? (???) <d468bc4a8a69343f1748c293db1b57fb> /usr/lib/libauto.dylib
0x93193000 - 0x9346cfe7 com.apple.CoreServices.CarbonCore 783 (783) <8370e664eeb25edc98d5c1f5405b06ae> /System/Library/Frameworks/CoreServices.framework/Versions/A /Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x9346d000 - 0x934aefe7 libRIP.A.dylib ??? (???) <bdc6d70bf4ed3dace321b4ff76a353b3> /System/Library/Frameworks/ApplicationServices.framework/Ver sions/A/Frameworks/CoreGraphics.framework/Versions/A/Resourc es/libRIP.A.dylib
0x934af000 - 0x934b1ff5 libRadiance.dylib ??? (???) <20eadb285da83df96c795c2c5fa20590> /System/Library/Frameworks/ApplicationServices.framework/Ver sions/A/Frameworks/ImageIO.framework/Versions/A/Resources/li bRadiance.dylib
0x934b2000 - 0x93cacfef com.apple.AppKit 6.5 (949) <f8d0f6d0bb5ac092f48f42ca684bdb54> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKi t
0x93cad000 - 0x93cadffa com.apple.CoreServices 32 (32) <2fcc8f3bd5bbfc000b476cad8e6a3dd2> /System/Library/Frameworks/CoreServices.framework/Versions/A /CoreServices
0x93cae000 - 0x93df3ff7 com.apple.ImageIO.framework 2.0.0 (2.0.0) <154d4d8cda2bd99518cbabc9f2d69833> /System/Library/Frameworks/ApplicationServices.framework/Ver sions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x93df4000 - 0x9448bfef com.apple.CoreGraphics 1.351.0 (???) <7a6f399039eed6dbe845c169f7d21a70> /System/Library/Frameworks/ApplicationServices.framework/Ver sions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGra phics
0x9448c000 - 0x9456bfff libobjc.A.dylib ??? (???) <5eda47fec2d0e7853b3506aa1fd2dafa> /usr/lib/libobjc.A.dylib
0x94572000 - 0x94576fff libGIF.dylib ??? (???) <d4234e6f5e5f530bdafb969157f1f17b> /System/Library/Frameworks/ApplicationServices.framework/Ver sions/A/Frameworks/ImageIO.framework/Versions/A/Resources/li bGIF.dylib
0x94583000 - 0x94584fef libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib
0x94936000 - 0x949dffff com.apple.JavaScriptCore 5523.10.3 (5523.10.3) <9e6719a7a0740f5c224099a7b853e45b> /System/Library/Frameworks/JavaScriptCore.framework/Versions /A/JavaScriptCore
0x949e0000 - 0x949e7ff7 libCGATS.A.dylib ??? (???) <9b29a5500efe01cc3adea67bbc42568e> /System/Library/Frameworks/ApplicationServices.framework/Ver sions/A/Frameworks/CoreGraphics.framework/Versions/A/Resourc es/libCGATS.A.dylib
0x949e8000 - 0x94a03ffb libPng.dylib ??? (???) <b6abcac36ec7654ff3e1cfa786b0117b> /System/Library/Frameworks/ApplicationServices.framework/Ver sions/A/Frameworks/ImageIO.framework/Versions/A/Resources/li bPng.dylib
0x94a04000 - 0x94a23ffa libJPEG.dylib ??? (???) <0cfb80109d624beb9ceb3c43b6c5ec10> /System/Library/Frameworks/ApplicationServices.framework/Ver sions/A/Frameworks/ImageIO.framework/Versions/A/Resources/li bJPEG.dylib
0x94a24000 - 0x94ad4fff edu.mit.Kerberos 6.0.11 (6.0.11) <33c25789baedcd70a7e24881775dd9ad> /System/Library/Frameworks/Kerberos.framework/Versions/A/Ker beros
0x94ad5000 - 0x94adcfe9 libgcc_s.1.dylib ??? (???) <f53c808e87d1184c0f9df63aef53ce0b> /usr/lib/libgcc_s.1.dylib
0x94add000 - 0x94ae8ff9 com.apple.helpdata 1.0 (14) /System/Library/PrivateFrameworks/HelpData.framework/Version s/A/HelpData
0x94ae9000 - 0x94ea7fea libLAPACK.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/F rameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x9505a000 - 0x95066fe7 com.apple.opengl 1.5.4 (1.5.4) <98bccaa83ca5e7101e821b4569a6a2ee> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenG L
0x9506d000 - 0x95582fff com.apple.WebCore 5523.10.3 (5523.10.3) <89179acba0e5ae2163d4a75ad460cbdb> /System/Library/Frameworks/WebKit.framework/Versions/A/Frame works/WebCore.framework/Versions/A/WebCore
0x955b8000 - 0x95641fff com.apple.framework.IOKit 1.5.0 (???) <5d9b85c55183f9732eb9efc38d18ba53> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x95642000 - 0x956f8fe3 com.apple.CoreServices.OSServices 209 (209) <89296b20d2db6c180eee073b699e3484> /System/Library/Frameworks/CoreServices.framework/Versions/A /Frameworks/OSServices.framework/Versions/A/OSServices
0x956f9000 - 0x9571dfff libxslt.1.dylib ??? (???) <4933ddc7f6618743197aadc85b33b5ab> /usr/lib/libxslt.1.dylib
0x9588f000 - 0x95897fff com.apple.DiskArbitration 2.2 (2.2) <1551b2af557fdf6f368f93e093933852> /System/Library/Frameworks/DiskArbitration.framework/Version s/A/DiskArbitration
0x95898000 - 0x9592aff3 com.apple.ApplicationServices.ATS 3.0 (???) <fb5f572243dbc370a0ea5efc8e81ae11> /System/Library/Frameworks/ApplicationServices.framework/Ver sions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9592b000 - 0x959dafff com.apple.DesktopServices 1.4.2 (1.4.2) <ec69c4072b0df6f52ef3f48fadf4c4b8> /System/Library/PrivateFrameworks/DesktopServicesPriv.framew ork/Versions/A/DesktopServicesPriv
0x959db000 - 0x95a52fe3 com.apple.CFNetwork 217 (219) <f3c16ae4b2faeb134957ee96d90dc5ca> /System/Library/Frameworks/CoreServices.framework/Versions/A /Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x95b19000 - 0x95b1bfff com.apple.securityhi 3.0 (30817) <2b2854123fed609d1820d2779e2e0963> /System/Library/Frameworks/Carbon.framework/Versions/A/Frame works/SecurityHI.framework/Versions/A/SecurityHI
0x95b1c000 - 0x95b1cffd com.apple.Accelerate 1.4 (Accelerate 1.4) /System/Library/Frameworks/Accelerate.framework/Versions/A/A ccelerate
0x95b1d000 - 0x95b1dffb com.apple.installserver.framework 1.0 (8) /System/Library/PrivateFrameworks/InstallServer.framework/Ve rsions/A/InstallServer
0x95b3a000 - 0x95bb9ff5 com.apple.SearchKit 1.2.0 (1.2.0) <277b460da86bc222785159fe77e2e2ed> /System/Library/Frameworks/CoreServices.framework/Versions/A /Frameworks/SearchKit.framework/Versions/A/SearchKit
0x95bba000 - 0x95c2efef libvMisc.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/F rameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x95c2f000 - 0x95c34fff com.apple.CommonPanels 1.2.4 (85) <ea0665f57cd267609466ed8b2b20e893> /System/Library/Frameworks/Carbon.framework/Versions/A/Frame works/CommonPanels.framework/Versions/A/CommonPanels
0x95c35000 - 0x95dfefef com.apple.security 5.0 (31122) <0759867b3944f1e54ce3d9078bbdb867> /System/Library/Frameworks/Security.framework/Versions/A/Sec urity
0x95e4a000 - 0x95e4bffc libffi.dylib ??? (???) <a3b573eb950ca583290f7b2b4c486d09> /usr/lib/libffi.dylib
0x95e4c000 - 0x95f13ff2 com.apple.vImage 3.0 (3.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/F rameworks/vImage.framework/Versions/A/vImage
0x95f14000 - 0x95f56fef com.apple.NavigationServices 3.5 (160) <26d03493eac3e290fd1d0fd5ff311863> /System/Library/Frameworks/Carbon.framework/Versions/A/Frame works/NavigationServices.framework/Versions/A/NavigationServ ices
0x95f57000 - 0x95f5dfff com.apple.print.framework.Print 218 (220) <c35172175abbe554ddadd9b6401351fa> /System/Library/Frameworks/Carbon.framework/Versions/A/Frame works/Print.framework/Versions/A/Print
0x95faf000 - 0x95fe9ff7 com.apple.coreui 0.1 (60) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/ A/CoreUI
0x95fea000 - 0x960b5fff com.apple.ColorSync 4.5.0 (4.5.0) /System/Library/Frameworks/ApplicationServices.framework/Ver sions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x96123000 - 0x961b6fff com.apple.ink.framework 101.3 (86) <bf3fa8927b4b8baae92381a976fd2079> /System/Library/Frameworks/Carbon.framework/Versions/A/Frame works/Ink.framework/Versions/A/Ink
0x964de000 - 0x964e5ffe libbsm.dylib ??? (???) <d25c63378a5029648ffd4b4669be31bf> /usr/lib/libbsm.dylib
0x964e6000 - 0x9651cfff com.apple.SystemConfiguration 1.9.0 (1.9.0) <7919d9588c3b0d556646e555b7193f1f> /System/Library/Frameworks/SystemConfiguration.framework/Ver sions/A/SystemConfiguration
0x9658d000 - 0x96609feb com.apple.audio.CoreAudio 3.1.0 (3.1) <70bb7c657061631491029a61babe0b26> /System/Library/Frameworks/CoreAudio.framework/Versions/A/Co reAudio
0x9660a000 - 0x9660affd com.apple.vecLib 3.4 (vecLib 3.4) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLi b
0x9660e000 - 0x9664dfef libTIFF.dylib ??? (???) <6d0f80e9d4d81f3f64c876aca005bd53> /System/Library/Frameworks/ApplicationServices.framework/Ver sions/A/Frameworks/ImageIO.framework/Versions/A/Resources/li bTIFF.dylib
0x9664e000 - 0x96659fe7 libCSync.A.dylib ??? (???) <df82fc093e498a9eb5490761cb292218> /System/Library/Frameworks/ApplicationServices.framework/Ver sions/A/Frameworks/CoreGraphics.framework/Versions/A/Resourc es/libCSync.A.dylib
0x9666d000 - 0x966aaff7 libGLImage.dylib ??? (???) <2d5ec9fc8b04b7b33f1d40ec83d86bf3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libra ries/libGLImage.dylib
0x966ab000 - 0x96707ff7 com.apple.htmlrendering 68 (1.1.3) <fe87a9dede38db00e6c8949942c6bd4f> /System/Library/Frameworks/Carbon.framework/Versions/A/Frame works/HTMLRendering.framework/Versions/A/HTMLRendering
0x96727000 - 0x96737fff com.apple.speech.synthesis.framework 3.6.59 (3.6.59) <4ffef145fad3d4d787e0c33eab26b336> /System/Library/Frameworks/ApplicationServices.framework/Ver sions/A/Frameworks/SpeechSynthesis.framework/Versions/A/Spee chSynthesis
0x96769000 - 0x969e2fe7 com.apple.Foundation 6.5 (677) <d182b2cc21817f7e5b6c7a1b3f421a98> /System/Library/Frameworks/Foundation.framework/Versions/C/F oundation
0x969e3000 - 0x96a3dff7 com.apple.CoreText 2.0.0 (???) <7fa39cd5bc847615ec02e7c7a37c0508> /System/Library/Frameworks/ApplicationServices.framework/Ver sions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x96a3e000 - 0x96a54fff com.apple.DictionaryServices 1.0.0 (1.0.0) <ad0aa0252e3323d182e17f50defe56fc> /System/Library/Frameworks/CoreServices.framework/Versions/A /Frameworks/DictionaryServices.framework/Versions/A/Dictiona ryServices
0x96a55000 - 0x96a5ffeb com.apple.audio.SoundManager 3.9.2 (3.9.2) <0f2ba6e891d3761212cf5a5e6134d683> /System/Library/Frameworks/Carbon.framework/Versions/A/Frame works/CarbonSound.framework/Versions/A/CarbonSound
0x96b55000 - 0x96b55fff com.apple.Carbon 136 (136) <98a5e3bc0c4fa44bbb09713bb88707fe> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbo n
0x96b56000 - 0x96b6cfe7 com.apple.CoreVideo 1.5.0 (1.5.0) <bcc3dd0978bb626c26378227740e1e80> /System/Library/Frameworks/CoreVideo.framework/Versions/A/Co reVideo
0x96b6d000 - 0x96b9cfe3 com.apple.AE 402 (402) <994ba8e884aefe7bf1fc5987df099e7b> /System/Library/Frameworks/CoreServices.framework/Versions/A /Frameworks/AE.framework/Versions/A/AE
0x96b9d000 - 0x96bcafeb libvDSP.dylib ??? (???) <a26683d121ee0f96df9a9d0bfca36049> /System/Library/Frameworks/Accelerate.framework/Versions/A/F rameworks/vecLib.framework/Versions/A/libvDSP.dylib
0xfffe8000 - 0xfffebfff libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
0xffff0000 - 0xffff1780 libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
name="configuration.txt"
Content-Transfer-Encoding: quoted-printable
filename="configuration.txt"
*** Date: Friday, November 2, 2007 9:32:02 AM Austria
*** Platform Details:
*** System properties:
awt.nativeDoubleBuffering=3Dtrue
awt.toolkit=3Dapple.awt.CToolkit
eclipse.buildId=3DM20071023-1652
eclipse.commands=3D-os
macosx
-ws
carbon
-arch
x86
-showsplash
-launcher
-name
Eclipse
--launcher.library
/Users/htran/tool/programing/eclipse/Eclipse.app/Contents/Ma cOS/../../../=
plugins/org.eclipse.equinox.launcher.carbon.macosx_1.0.2.R33 1_v20071019/e=
clipse_1021.so
-startup
plugins/org.eclipse.equinox.launcher_1.0.1.R33x_v20070828.ja r
-keyring
/Users/htran/.eclipse_keyring
-consoleLog
-showlocation
-vm
eclipse.consoleLog=3Dtrue
eclipse.ee.install.verify=3Dfalse
eclipse.product=3Dorg.eclipse.sdk.ide
eclipse.startTime=3D1193992255470
eclipse.vm=3D/System/Library/Frameworks/JavaVM.framework
eclipse.vmargs=3D-Xdock:icon=3D../Resources/Eclipse.icns
-Xms40m
-Xmx256m
-XX:MaxPermSize=3D256m
-Djava.class.path=3D/Users/htran/tool/programing/eclipse/Ecl ipse.app/Cont=
ents/MacOS/../../../plugins/org.eclipse.equinox.launcher_1.0 .1.R33x_v2007=
0828.jar
eof=3Deof
file.encoding=3DMacRoman
file.encoding.pkg=3Dsun.io
file.separator=3D/
ftp.nonProxyHosts=3Dlocal|*.local|169.254/16|*.169.254/16
gopherProxySet=3Dfalse
java.awt.graphicsenv=3Dapple.awt.CGraphicsEnvironment
java.awt.printerjob=3Dapple.awt.CPrinterJob
java.class.path=3D/Users/htran/tool/programing/eclipse/Eclip se.app/Conten=
ts/MacOS/../../../plugins/org.eclipse.equinox.launcher_1.0.1 .R33x_v200708=
28.jar
java.class.version=3D49.0
java.endorsed.dirs=3D/System/Library/Frameworks/JavaVM.frame work/Versions=
/1.5.0/Home/lib/endorsed
java.ext.dirs=3D/Library/Java/Extensions:/System/Library/Jav a/Extensions:=
/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/H ome/lib/ext
java.home=3D/System/Library/Frameworks/JavaVM.framework/Vers ions/1.5.0/Ho=
me
java.io.tmpdir=3D/tmp
java.library.path=3D/Applications/muCommander.app/Contents/R esources/Java=
:/System/Library/PrivateFrameworks/JavaApplicationLauncher.f ramework/Reso=
urces:.:/Library/Java/Extensions:/System/Library/Java/Extens ions:/usr/lib=
/java
java.runtime.name=3DJava(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=3D1.5.0_13-b05-237
java.specification.name=3DJava Platform API Specification
java.specification.vendor=3DSun Microsystems Inc.
java.specification.version=3D1.5
java.vendor=3DApple Inc.
java.vendor.url=3Dhttp://www.apple.com/
java.vendor.url.bug=3Dhttp://bugreport.apple.com/
java.version=3D1.5.0_13
java.vm.info=3Dmixed mode
java.vm.name=3DJava HotSpot(TM) Client VM
java.vm.specification.name=3DJava Virtual Machine Specification
java.vm.specification.vendor=3DSun Microsystems Inc.
java.vm.specification.version=3D1.0
java.vm.vendor=3DApple Inc.
java.vm.version=3D1.5.0_13-119
line.separator=3D
mrj.version=3D1040.1.5.0_13-237
org.eclipse.equinox.launcher.splash.location=3D/Users/htran/ tool/programi=
ng/eclipse/plugins/org.eclipse.platform_3.3.2.R33x_v20071022 /splash.bmp
org.eclipse.swt.internal.carbon.smallFonts=3D
org.osgi.framework.executionenvironment=3DOSGi/Minimum-1.0,O SGi/Minimum-1=
=2E1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=3Den
org.osgi.framework.os.name=3DMacOSX
org.osgi.framework.os.version=3D10.5
org.osgi.framework.processor=3Di386
org.osgi.framework.system.packages=3Djavax.accessibility,jav ax.activity,j=
avax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax. imageio,javax=
=2Eimageio.event,javax.imageio.metadata,javax.imageio.plugin s.bmp,javax.i=
mageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,j avax.manageme=
nt,javax.management.loading,javax.management.modelmbean,java x.management.=
monitor,javax.management.openmbean,javax.management.relation ,javax.manage=
ment.remote,javax.management.remote.rmi,javax.management.tim er,javax.nami=
ng,javax.naming.directory,javax.naming.event,javax.naming.ld ap,javax.nami=
ng.spi,javax.net,javax.net.ssl,javax.print,javax.print.attri bute,javax.pr=
int.attribute.standard,javax.print.event,javax.rmi,javax.rmi .CORBA,javax.=
rmi.ssl,javax.security.auth,javax.security.auth.callback,jav ax.security.a=
uth.kerberos,javax.security.auth.login,javax.security.auth.s pi,javax.secu=
rity.auth.x500,javax.security.cert,javax.security.sasl,javax .sound.midi,j=
avax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled. spi,javax.sql=
,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.s pi,javax.swin=
g,javax.swing.border,javax.swing.colorchooser,javax.swing.ev ent,javax.swi=
ng.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax .swing.plaf.m=
etal,javax.swing.plaf.multi,javax.swing.plaf.synth,javax.swi ng.table,java=
x.swing.text,javax.swing.text.html,javax.swing.text.html.par ser,javax.swi=
ng.text.rtf,javax.swing.tree,javax.swing.undo,javax.transact ion,javax.tra=
nsaction.xa,javax.xml,javax.xml.datatype,javax.xml.namespace ,javax.xml.pa=
rsers,javax.xml.transform,javax.xml.transform.dom,javax.xml. transform.sax=
,javax.xml.transform.stream,javax.xml.validation,javax.xml.x path,org.ietf=
=2Ejgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.po rtable,org.om=
g.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA .portable,org=
=2Eomg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNa ming.NamingCo=
ntextExtPackage,org.omg.CosNaming.NamingContextPackage,org.o mg.Dynamic,or=
g.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org .omg.DynamicA=
ny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage ,org.omg.IOP.=
CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,o rg.omg.Portab=
leInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org. omg.PortableS=
erver.CurrentPackage,org.omg.PortableServer.POAManagerPackag e,org.omg.Por=
tableServer.POAPackage,org.omg.PortableServer.portable,org.o mg.PortableSe=
rver.ServantLocatorPackage,org.omg.SendingContext,org.omg.st ub.java.rmi,o=
rg.w3c.dom,org.w3c.dom.bootstrap,org.w3c
Re: simple ecore model editor crashes on Eclipse 3.3.x+EMF2.3@leopard [message #381366 is a reply to message #381363] Fri, 02 November 2007 05:21 Go to previous messageGo to next message
--------------020002050106020602030104
Huy,
It's best to use the EMF newsgroup for questions about EMF for any
future posts.
news://news.eclipse.org/eclipse.tools.emf
I've added it to the "to" list of the reply so you can continue to use
this thread for now.
When you say it crashes, you mean the whole VM just dies and Eclipse
goes away forcing a restart? That sounds like a bug in the JVM itself
or I suppose some native code like code in SWT could be at fault. I'm
not sure what I can suggest for that. I'm not sure it would be worth
while posting the information to the SWT newsgroup if folks there might
recognize if native code is involved in the issue. Perhaps if you just
hit enter rather then clicking on another property immediately you'll be
able to avoid whatever issue is crashing the JVM.
Huy Tran wrote:
> Dear all,
> SP2, OSX 10.4 (Tiger), Ubuntu 7.x. A few days ago, I switched to
> Leopard and faced with a strange issue. I describe in details as
> following:
> A, called 'aRefToB'. Using mouse to manipulate on the Properties
> View, I choose B as the EType of 'aRefToB', then I click immediately
> on any other attribute row, for instance, EOpposite. It crashes. There
> is no warning dialog after that, and no info from Error Log as well.
> Best regards,
> Huy Tran
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
<title></title>
</head>
Huy,<br>
<br>
future posts.&nbsp; <br>
<blockquote>&nbsp;<a href="news://news.eclipse.org/eclipse.tools.emf">news://news.eclipse.org/eclipse.tools.emf</a><br>
</blockquote>
this thread for now.<br>
<br>
goes away forcing a restart?&nbsp; That sounds like a bug in the JVM itself
or I suppose some native code like code in SWT could be at fault.&nbsp; I'm
not sure what I can suggest for that.&nbsp; I'm not sure it would be worth
recognize if native code is involved in the issue. &nbsp; Perhaps if you
just hit enter rather then clicking on another property immediately
you'll be able to avoid whatever issue is crashing the JVM.&nbsp; <br>
<br>
<br>
Huy Tran wrote:
<blockquote cite="mid:472AE1C8.8030502@infosys.tuwien.ac.at" type="cite">Dear
all,
<br>
<br>
Leopard and &nbsp;faced with a strange issue. I describe in details as
following:
<br>
<br>
A, &nbsp;called 'aRefToB'. Using mouse to manipulate on the Properties View,
I choose B as the EType of 'aRefToB', then I click immediately on any
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Huy Tran
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------020002050106020602030104--
Re: simple ecore model editor crashes on Eclipse 3.3.x+EMF2.3@leopard [message #381368 is a reply to message #381366] Fri, 02 November 2007 05:24 Go to previous messageGo to next message
--------------060204030702010406010709
Huy,
There are several articles on a problem that could be related. One is
http://dev.eclipse.org/newslists/news.eclipse.technology.equ inox/msg03803.html
HTH
/Eike
Ed Merks schrieb:
> Huy,
> future posts.
> might recognize if native code is involved in the issue. Perhaps if
> you just hit enter rather then clicking on another property
> immediately you'll be able to avoid whatever issue is crashing the JVM.
> Huy Tran wrote:
>> Dear all,
>> the included Simple Ecore Model Editor. There is no issue in Windows
>> XP SP2, OSX 10.4 (Tiger), Ubuntu 7.x. A few days ago, I switched to
>> following:
>> There is no warning dialog after that, and no info from Error Log as
>> well.
>> Best regards,
>> Huy Tran
<html>
<head>
</head>
Huy,<br>
<br>
<a class="moz-txt-link-freetext" href=" http://dev.eclipse.org/newslists/news.eclipse.technology.equ inox/msg03803.html"> http://dev.eclipse.org/newslists/news.eclipse.technology.equ inox/msg03803.html</a><br>
<br>
HTH<br>
/Eike<br>
<br>
<br>
<br>
Ed Merks schrieb:
<blockquote cite="mid:fgeq28$81v$1@build.eclipse.org" type="cite">
<title></title>
Huy,<br>
<br>
<blockquote>&nbsp;<a moz-do-not-send="true"
</blockquote>
<br>
<br>
<br>
type="cite">Dear
all, <br>
<br>
following: <br>
<br>
warning dialog after that, and no info from Error Log as well. <br>
<br>
configuration file attached here. <br>
<br>
I really appreciate any of your comments. <br>
<br>
Best regards, <br>
Huy Tran <br>
<br>
PS: I already submitted a bug report to Apple as well. <br>
<br>
<br>
</blockquote>
<br>
</blockquote>
</body>
</html>
--------------060204030702010406010709--
Re: simple ecore model editor crashes on Eclipse 3.3.x+EMF2.3@leopard [message #381370 is a reply to message #381366] Fri, 02 November 2007 06:10 Go to previous message
Ed Merks wrote:
> Huy,
> future posts.
Sorry for annoying and many thanks for your kind arrangment.
I mean the whole VM and Eclipse go away.
Just because I did not know the relationship between EMF and SWT. That's
why I thought it was an EMF-related issue ;)
Perhaps if you just
You're absolutely right. That is the way now I use to get rid of crashing
Huy
Re: simple ecore model editor crashes on Eclipse 3.3.x+EMF2.3@leopard [message #601566 is a reply to message #381363] Fri, 02 November 2007 05:21 Go to previous message
Huy,
future posts.
Huy Tran wrote:
> Dear all,
> following:
> Best regards,
> Huy Tran
<html>
<head>
<title></title>
</head>
Huy,<br>
<br>
</blockquote>
<br>
<br>
<br>
all,
<br>
<br>
following:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Huy Tran
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
Re: simple ecore model editor crashes on Eclipse 3.3.x+EMF2.3@leopard [message #601574 is a reply to message #381366] Fri, 02 November 2007 05:24 Go to previous message
Huy,
HTH
/Eike
Ed Merks schrieb:
> Huy,
> future posts.
> Huy Tran wrote:
>> Dear all,
>> following:
>> well.
>> Best regards,
>> Huy Tran
<html>
<head>
</head>
Huy,<br>
<br>
<br>
HTH<br>
/Eike<br>
<br>
<br>
<br>
<title></title>
Huy,<br>
<br>
</blockquote>
<br>
<br>
<br>
type="cite">Dear
all, <br>
<br>
following: <br>
<br>
<br>
<br>
<br>
Best regards, <br>
Huy Tran <br>
<br>
<br>
<br>
</blockquote>
<br>
</blockquote>
</body>
</html>
Re: simple ecore model editor crashes on Eclipse 3.3.x+EMF2.3@leopard [message #601582 is a reply to message #381366] Fri, 02 November 2007 06:10 Go to previous message
Ed Merks wrote:
> Huy,
> future posts.
Perhaps if you just
Huy
Previous Topic:simple ecore model editor crashes on Eclipse 3.3.x+EMF2.3@leopard
Next Topic:[Announce] The EclipseCon 2008 Submission Deadline is Rapidly Approaching.
Current Time: Wed Jul 23 08:00:57 EDT 2025
Powered by FUDForum. Page generated in 0.34278 seconds
