Home » Eclipse Projects » EclipseLink » Please confirm Eclipelink logging "hardcoded" to DefaultSessionLog
Please confirm Eclipelink logging "hardcoded" to DefaultSessionLog [message #381284] |
Thu, 11 September 2008 18:55  |
I've spent a couple of days trying to implement a third party logger,
log4j 1.2.14
To use a third party logger write a class to implement SessionLog. Is
this right. The docmentation is spares and I couldn't find any examples.
public class MySessionLog implements SessionLog, java.lang.Cloneable,
Serializable {
While debugging MySessionLog class I ran into places where
DefaultSessionLog and AbstractSessionLog is called by Eclipselink, not
SessionLog.
Does this mean Eclipselink is hardcoded (for now) so only
DefaultSessionLog can be used?
The problem is that I get two log entries each time a log(something) is
called.
It appears that DefaultSessionLog also sneaks in because it is referenced
directly. or indirectly through AbstractSessionLog. in other parts of
Eclipselink.
While debugging I found that the code ran through
org.eclipse.persistence.internal.jpa.EntityManagerSetupIm
// The sessionLog instance should be different from the
singletonLog because they have
// different state.
SessionLog singletonLog = null, sessionLog = null;
if (loggerClassName != null) {
SessionLog currentLog = session.getSessionLog();
if(loggerClassName.equals(LoggerType.ServerLogger)){
ServerPlatform serverPlatform =
session.getServerPlatform();
/* 1 */ singletonLog = serverPlatform.getServerLog();
/* 1 */ sessionLog = serverPlatform.getServerLog();
} else if
(!currentLog.getClass().getName().equals(loggerClassName)) {
// Logger class was specified and it's not what's already
there.
Class sessionLogClass =
findClassForProperty(loggerClassName,
PersistenceUnitProperties.LOGGING_LOGGER, loader);
try {
singletonLog =
(SessionLog)sessionLogClass.newInstance();
sessionLog = (SessionLog)sessionLogClass.newInstance();
} catch (Exception ex) {
throw
EntityManagerSetupException.failedToInstantiateLogger(logger ClassName,
PersistenceUnitProperties.LOGGING_LOGGER, ex);
} else if (serverPlatformChanged) {
ServerPlatform serverPlatform = session.getServerPlatform();
// Don't change default loggers if the new loggers have not been
created.
if (singletonLog != null && sessionLog != null) {
/* 2 */ AbstractSessionLog.setLog(singletonLog);
session.setSessionLog(sessionLog);
} else if (sessionNameChanged) {
// In JavaLog this will result in logger name changes,
// but won't affect DefaultSessionLog.
// Note, that the session hasn't change, only its name.
session.getSessionLog().setSession(session);
// Bug5389828. Update the logging settings for the singleton
logger.
initOrUpdateLogging(persistenceProperties,
AbstractSessionLog.getLog());
session.getSessionLog());
/* 1 */ My log class gets instantiated (eclipselink.logging.logger set to
my class). Okay so far.
/* 2 */ The instance of my logger get stuffed into AbstractSessionLog. I
presume that creates an instance of AbstractSessionLog.
later on this code is execute
org.eclipse.persistence.internal.sessions.AbstractSession
public SessionLog getSessionLog() {
if (sessionLog == null) {
setSessionLog(new DefaultSessionLog());
return sessionLog;
Am I going about writing my own logger wrong. Should I be implementing my
own DefaultSessionLog? Extending AbstractSessionLog?
Briefly searching the other source in Eclipselink I ran into these
references to DefaultSessionLog which seem suspicious.
see
org.eclipse.persistence.sessions.DatabaseSession.DatabaseSes sion
... return new DefaultSessionLog()
org.eclipse.persistence.tools.weaving.jpa.StaticWeaveProcess or
org.eclipse.persistence.internal.weaving.StaticWeaveClassTra nsformer
... ((DefaultSessionLog)session.getSessionLog()).setWriter(logWr iter);
org.eclipse.persistence.internal.sessions.factories.Sessions Factory
protected SessionLog buildSessionLog(LogConfig logConfig,
AbstractSession session) {
if (logConfig instanceof JavaLogConfig) {
return buildJavaLogConfig((JavaLogConfig)logConfig, session);
} else if (logConfig instanceof DefaultSessionLogConfig) {
return
buildDefaultSessionLogConfig((DefaultSessionLogConfig)logCon fig);
} else if (logConfig instanceof ServerLogConfig) {
return buildServerLogConfig((ServerLogConfig)logConfig,
session);
} else {
return null;
I'd appreciate any guidance.
Bill Blalock
Re: Please confirm Eclipelink logging "hardcoded" to DefaultSessionLog [message #381385 is a reply to message #381284] |
Fri, 12 September 2008 15:06   |
Bill,
Hi, I took a quick look at implementing a custom logger and the minimum
steps required on top of adding the logger to the session - is to set the
level and override log(SessionLogEntry sessionLogEntry).
I decided not to use a logging framework like apache commons or Log4J
yet so that I could isolate EclipseLink behavior.
I added the following to a Java SE JPA app and the custom logger got
picked at the end of the deploy() after predeploy().
Before this you will encounter 6 instantiations of the DefaultSessionLog
implementation of the SessionLog interface.
In eclipseLink we use the following implementation - I recommend that you
also subclass AbstractSessionLog
DefaultSessionLog extends AbstractSessionLog - which implements SessionLog.
There is no need to override the other log() functions as they all
eventually call log(SessionLogEntry).
This is the custom logger code....
public class CustomAbstractSessionLog extends AbstractSessionLog
implements SessionLog {
/* (non-Javadoc)
* @see
org.eclipse.persistence.logging.AbstractSessionLog#log(org.e clipse.persistence.logging.SessionLogEntry)
public void log(SessionLogEntry sessionLogEntry) {
// TODO Auto-generated method stub
System.out.println("CUSTOM: " + sessionLogEntry.getMessage()); //
untranslated/undecoded message_id
This is the customizer to reference in persistence.xml....
public class JPAEclipseLinkSessionCustomizer implements SessionCustomizer {
public void customize(Session session) throws Exception {
// create a custom logger
SessionLog aCustomLogger = new CustomAbstractSessionLog();
aCustomLogger.setLevel(1); // finest
session.setSessionLog(aCustomLogger);
This is the propery that you want to add to persistence.xml
<property name="eclipselink.session.customizer"
value=" org.eclipse.persistence.example.unified.integration.JPAEclip seLinkSessionCustomizer "/>
Results:
I don't see double logs after the deploy() switchover to
The AbstractSession.getSessionLog() getter code you mention should only be
creating a new DefaultSessionLog if the sessionLog instance variable set
in the sessionCustomizer was not set.
Testing for secondary logs:
To test this, I disabled all breakpoints except on the DefaultSessionLog
constructor, DefaultSessionLog.log(SessionLogEntry), line 2079 and the one
that sets my custom logger
-->2079 setSessionLog(new DefaultSessionLog());
return sessionLog;
- i did not see any new instantiations of DefaultSessionLog after the 6
before deploy switchover.
Maybe we need to also test outside of JPA with a native ORM example to be
able to reproduce your issue.
I will add the setup results of this discussion to a example wiki shortly
at...
http://wiki.eclipse.org/EclipseLink/Examples/JPA/CustomLogge r
thank you
/michael
Logs:
[EL Finest]: 2008.09.12
13:59:36.330--ServerSession(6386542)--Thread(Thread[main,5,m ain])--property=eclipselink.jdbc.url;
value=jdbc:oracle:thin:@10.156.53.19:1521:orcl
13:59:36.330--ServerSession(6386542)--Thread(Thread[main,5,m ain])--property=eclipselink.session.customizer;
value=org.eclipse.persistence.example.unified.integration.JP AEclipseLinkSessionCustomizer
>>>Logger switchover
CUSTOM: topLink_version
CUSTOM: login_successful
CUSTOM: INSERT IGNORE INTO STAT_CLASS (ID, JDK_VERSION, MODIFIED, INTERNAL,
LINES, TEST, CLASS_TYPE_CODE, NAME, VERSION, CLASS_TYPE, LABEL,
CLASS_PACKAGE) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)
bind => [8627, null, 2008-07-04, null, 159, 0, null,
XMLPlatformException, concrete, null, 1626, 1366]
CUSTOM: execute_query
bind => [7573, null, 2008-07-04, null, 117, 0, null,
QueueableWeakCacheKey, concrete, null, 1626, 1242]
CUSTOM: commit_transaction
CUSTOM: end_unit_of_work_commit
CUSTOM: resume_unit_of_work
CUSTOM: release_unit_of_work
CUSTOM: client_released
CUSTOM: undeploy_begin
CUSTOM: sequencing_disconnected
CUSTOM: disconnect
CUSTOM: initialize_identitymaps
CUSTOM: logout_successful
CUSTOM: disconnect
CUSTOM: disconnect
CUSTOM: disconnect
CUSTOM: disconnect
CUSTOM: disconnect
CUSTOM: disconnect
CUSTOM: disconnect
CUSTOM: undeploy_end
Re: Please confirm Eclipelink logging "hardcoded" to DefaultSessionLog [message #381395 is a reply to message #381385] |
Mon, 22 September 2008 14:37   |
Michael:
Thanks for the help! I've reached another problem and I'd appreciate your
My Log4j logger class works file when it is loaded with the
persistenance.xml property eclispelink.logging.logger.
The problem is that it is not used in place of DefaultSessionLog when
loaded in the SessionCustomizer as you suggest. For example:
SessionLog aCustomLogger = new Log4jSessionLog();
aCustomLogger.setLevel( SessionLog.INFO );
I know the code is executed but the logging is still done by
DefaultSessionLog and written to stdout.
I am designing a JPA project which will be used in a server environment
(needs log4j) and a Eclipse RCP plugin. So if the project needs to use
log4j the class name of the custom logger will be passed to the
SessionCustomizer.
I am having trouble doing this. I tried to copy the way in which the
DefaultSessionLog class is loaded but that isn't working for me. No
error, just my log4j customer logger isn't being used.
if ( loggerClass != null ) {
Class sessionLogClass;
if (PrivilegedAccessHelper.shouldUsePrivilegedAccess()){
sessionLogClass = (Class)AccessController.doPrivileged(
new PrivilegedClassForName(
loggerClass, true, ClassLoader.getSystemClassLoader() ) );
} else {
sessionLogClass = PrivilegedAccessHelper.getClassForName(
loggerClass, true, ClassLoader.getSystemClassLoader() );
aCustomLogger.setLevel(SessionLog.INFO );
I borrowed for your example. No errors but it isn't working. That isn't
supprising since the simpler version above didn't work either.
Do you see where I have gone wrong?
Thanks!
Bill Blalock
Michael OBrien wrote:
> Bill,
> /* (non-Javadoc)
> * @see
> @Override
> Results:
> return sessionLog;
> at...
> thank you
> /michael
> Logs:
>>>>Logger switchover
> CUSTOM: disconnect
> CUSTOM: disconnect
> CUSTOM: disconnect
> CUSTOM: disconnect
> CUSTOM: disconnect
> CUSTOM: disconnect
> CUSTOM: disconnect
> CUSTOM: disconnect
Re: Please confirm Eclipelink logging "hardcoded" to DefaultSessionLog [message #381396 is a reply to message #381395] |
Mon, 22 September 2008 14:54  |
Michael and all:
Opps ... I understand what is going on now. I was wrong, my log4j
customer logger is loaded both way.
I would appreciate any comments on how it is loaded when given the class
name. Is that right?
The problem is that a bunch of warnings are issued about converts that are
used. For example:
[EL Warning]: 2008.09.22 13:43:20.984--ServerSession(22634321)--Ignoring
default serialization on element [private java.lang.Boolean
domain_model.Xfrctl00.dueHoliday] within entity class [class
domain_model.Xfrctl00] since a @Convert is specified.
default serialization on element [private java.lang.String
domain_model.Exftpclg00.operInfo] within entity class [class
domain_model.Exftpclg00] since a @Convert is specified.
[EL Warning]: 2008.09.22 13:43:21.093--ServerSession(20196260)--Ignoring
domain_model.Ftplog01.clientHost] within entity class [class
domain_model.Ftplog01] since a @Convert is specified.
When the log4j class is loaded by persistence.xml these go to log4j.
When the log4j class is loaded by the SessionCustomizer these go to the
console. Other messages go to log4j.
Apparently logable activity takes place before the SessionCustomizer is
processed.
If the SessionLog class is specified in the persistence.xml file then all
logable activity is processed with that SessionLog.
If the SessionLog class is specified in the SessionCustomizer anything
logable that happens before the SessionCustomizer kicks in goes to the
basic DefaultSessionLog.
I don't consider this a bug. Loggable activity has to go someplace before
the SessionCustomizer kicks in.
Bill Blalock
Current Time: Sat Jul 26 08:51:30 EDT 2025
Powered by FUDForum. Page generated in 0.04562 seconds
