Home » Language IDEs » ServerTools (WTP) » Creating a Web Service using WTP
Creating a Web Service using WTP [message #37729] Tue, 10 August 2004 01:30 Go to next message
Just playing with the WTP contributions...
Firstly followed instructions verbatim in the docs...
1. Set up Tomcat 4.1 (in preference to 5.0)
2. Created Convertor Project (Dynamic Web Project)
3. Selected Create Web Services
4. Selected the Tomcat 4.1 installation etc etc.
Then get an error
at
com.ibm.etools.webservice.axis.creation.ui.widgets.bean.Vali dateObjectSelectionCommand.execute(Va
lidateObjectSelectionCommand.java:93)
at
com.ibm.env.command.fragment.CommandFragmentEngine.runComman d(CommandFragmentEngine.j
ava:312)
at
com.ibm.env.command.fragment.CommandFragmentEngine.visitTop( CommandFragmentEngine.java:
278)
at
com.ibm.env.command.fragment.CommandFragmentEngine.moveForwa rdToNextStop(CommandFrag
mentEngine.java:198)
at
com.ibm.env.widgets.SimpleCommandEngineManager$4.run(SimpleC ommandEngineManager.java:
196)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:303)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:253)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 752)
at
com.ibm.env.widgets.SimpleCommandEngineManager.runForwardToN extStop(SimpleCommandEngine
Manager.java:165)
at
com.ibm.env.internal.widgets.WizardPageManager.runForwardToN extStop(WizardPageManager.java:
59)
at
com.ibm.env.internal.widgets.WizardPageManager.getNextPage(W izardPageManager.java:81)
at
com.ibm.env.internal.widgets.SimpleWizardPage.getNextPage(Si mpleWizardPage.java:113)
at
org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:674)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:300)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:506)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1196)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1220)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1205)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1 053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2865)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2535)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:668 )
at org.eclipse.jface.window.Window.open(Window.java:648)
at
com.ibm.env.widgets.popup.DynamicPopupWizard.run(DynamicPopu pWizard.java:112)
at
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:276)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:
915)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:866)
at
org.eclipse.jface.action.ActionContributionItem$7.handleEven t(ActionContributionItem.java:785)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
This is different from other posted problems (mainly due to Tomcat 5.0 and
arrangement of
directories.
Any ideas???
I will mention that the system is on a mac OS-X - latest version and
updates and uses 1.4.2 java
I use that mac as it is the only system that I do not have to reboot and
reload every 3 months!!!
Jeff
Re: Creating a Web Service using WTP [message #38120 is a reply to message #37729] Wed, 11 August 2004 11:59 Go to previous messageGo to next message
I believe you are trying to generate a Web service from a Java bean. Can you
double check that the Java bean you selected (in the 2nd page of the wizard)
is loadable from the service project you selected (in the 3rd page of the
wizard)?
For example, if you have a Web project called "wp" that contains a Java bean
called "test.MyBean", but you didn't pick "wp" as your service project, then
you may run into this error. In any event, there should be better error
handling, I'll submit a fix for it.
Jeff
"Jeff Lambourne" <jeffla@attglobal.net> wrote in message
news:cf9mih$l8b$1@eclipse.org...
> Hi
> Then get an error
> at
> at
tEngine.j
> ava:312)
> at
ngine.java:
> 278)
> at
mandFrag
> at
ger.java:
> 196)
> at
a:303)
> at
mmandEngine
> Manager.java:165)
> at
geManager.java:
> 59)
> at
..java:81)
> at
ava:113)
> at
> at
> at
> at
> at
> at
> at
> 915)
> at
tem.java:866)
> at
tionItem.java:785)
> at
> at
> at
> at
> at
java:335)
> at
> at
> at
> at
..java:25)
> arrangement of
> directories.
> Any ideas???
> Jeff
Re: Creating a Web Service using WTP [message #38279 is a reply to message #38120] Wed, 11 August 2004 22:39 Go to previous messageGo to next message
You were right, that was the problem
Works very well
A very important feature
Jeff
Jeff Liu wrote:
> wizard)?
> Jeff
> > Hi
> > Then get an error
> > at
> > at
> tEngine.j
> > ava:312)
> > at
> ngine.java:
> > 278)
> > at
> mandFrag
> > at
> ger.java:
> > 196)
> > at
> a:303)
> > at
> mmandEngine
> > Manager.java:165)
> > at
> geManager.java:
> > 59)
> > at
> ..java:81)
> > at
> ava:113)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > 915)
> > at
> tem.java:866)
> > at
> tionItem.java:785)
> > at
> > at
> > at
> > at
> > at
> java:335)
> > at
> > at
> > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> > at
> > at
> ..java:25)
> > arrangement of
> > directories.
> > Any ideas???
> > Jeff
Re: Creating a Web Service using WTP [message #52067 is a reply to message #37729] Fri, 05 November 2004 14:22 Go to previous messageGo to next message
Originally posted by: jbailo.vestcom.com
Jeff Lambourne wrote:
> Hi
Where are the docs?
I don't see them in the download.
Re: Creating a Web Service using WTP [message #53086 is a reply to message #52067] Wed, 10 November 2004 13:08 Go to previous messageGo to next message
"John Bailo" <jbailo@vestcom.com> wrote in message
news:cmgjte$lfd$1@eclipse.org...
> > Hi
> Where are the docs?
The URL is: http://www.eclipse.org/webtools/index.html.
Go to the bottom of the page and you'll see under the Initial Code
Contributions section, a file called ibm.zip and on the same line "Getting
Started Guide". Click on that link and you'll get to the documentation on
how to get started with the various components contributed by IBM.
Re: Creating a Web Service using WTP [message #53140 is a reply to message #53086] Thu, 11 November 2004 11:24 Go to previous message
The URL should be:
http://download.eclipse.org/webtools/downloads/
"Kathy Chan" <kathy@ca.ibm.com> wrote in message
news:cmtld9$ek1$1@eclipse.org...
> > > Hi
> > Where are the docs?
Previous Topic:WebServices Create client fails
Next Topic:Pollinate Status and Meeting Agenda 2004-11-11
Current Time: Wed Jun 04 20:10:34 EDT 2025
Powered by FUDForum. Page generated in 0.03585 seconds
