Home » Modeling » Modeling (top-level project) » Generating code with stereotypes
Generating code with stereotypes [message #380830] Fri, 13 July 2007 10:42 Go to next message
How can I generate code with EMF from a UML Diagram that uses
stereotypes? With OCL? EAnnotation from EMF?
What have I to do for not lost the stereotypes and generate code correctly?
Thanks.
(Sorry for my English).
Re: Generating code with stereotypes [message #381126 is a reply to message #380830] Fri, 13 July 2007 11:21 Go to previous messageGo to next message
Jose,
Probably it's best to start with the UML newsgroup with this question,
so I've added that to the "to" list of my reply. I'm not sure what it
does with arbitrary stereotypes, but I think it throws them away. The
closest equivalent concept in Ecore would be an EAnnotation, so you
might need to use that.
Jose wrote:
> correctly?
> Thanks.
Re: Generating code with stereotypes [message #381131 is a reply to message #381126] Mon, 16 July 2007 09:18 Go to previous messageGo to next message
Hi Jose,
Information from arbitrary stereotypes is not used in the conversion from
uml to ecore.
There is some facility to generate code from OCL when it is used in the
original model but not when it is in an applied stereotype ( check out the
new and noteworthy section for some details. ).
UML also now has the means to use static profile definition ( also see new
and noteworthy ), but this might not be what you are interested in.
There does seem to be an outstanding defect that might be similar to what
you are looking for https://bugs.eclipse.org/bugs/show_bug.cgi?id=101404.
You might want to state your exact needs in a bugzilla or add to the one I
just mentioned and it will be looked into.
- James.
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:f785au$g6s$1@build.eclipse.org...
> Jose,
> Jose wrote:
> > Hi,
> > correctly?
> > Thanks.
Re: Generating code with stereotypes [message #381147 is a reply to message #381131] Fri, 20 July 2007 07:38 Go to previous messageGo to next message
Thanks James-Bruck,
But Omondo's group can generate code using UML2 and EMF, so that I could
not do it?
Excuse me if the question is very stupid.
Thanks.
James Bruck escribió:
> Hi Jose,
> uml to ecore.
> - James.
>> Jose,
>> Jose wrote:
>>> Hi,
>>> correctly?
>>> Thanks.
Re: Generating code with stereotypes [message #381149 is a reply to message #381147] Fri, 20 July 2007 10:16 Go to previous messageGo to next message
Hi Jose,
I'm not sure I'm interpreting your question correctly.
Are you saying that Omondo can generate code from applied stereotypes from
some specific profile?
or are you saying that Omondo can generate code from UML2 in general?
If it's the first case: I'm not familiar with Omondo but they might be
extending the uml to ecore converter in some way. The existing
UML2EcoreConverter does for example take the Ecore profile into account in
the conversion process. Perhaps Omondo does something special with another
profile?
If it's the second case: You can generate code using UML2 by converting to
ecore and then generating code from the ecore representation.
By adding a stereotype you are introducing a new item at the meta model
level. I'm not sure how the general uml to ecore converter can interpret
this new meta level property. Ultimately, code generation from uml happens
by first mapping the uml representation to an ecore representation and then
code generation occurrs from ecore. There would have to be some agreed
upon mapping from these newly introduced values within the stereotype to an
- James.
"Jose" <ja.navarro.a@alumnos.urjc.es> wrote in message
news:f7q6sj$d5s$1@build.eclipse.org...
> Thanks James-Bruck,
> not do it?
> Thanks.
> James Bruck escribi
Re: Generating code with stereotypes [message #381151 is a reply to message #381149] Fri, 20 July 2007 10:54 Go to previous message
Thank you very much, James
James Bruck wrote:
> Hi Jose,
> profile?
> - James.
>> Thanks James-Bruck,
>> not do it?
>> Thanks.
>> James Bruck wrote:
>>> Hi Jose,
> from
>>> uml to ecore.
> the
> new
> what
>>> you are looking for
> I
>>> - James.
>>>> Jose,
>>>> Jose wrote:
>>>>> Hi,
>>>>> correctly?
>>>>> Thanks.
Re: Generating code with stereotypes [message #596800 is a reply to message #380830] Fri, 13 July 2007 11:21 Go to previous message
Jose,
Jose wrote:
> correctly?
> Thanks.
Re: Generating code with stereotypes [message #596838 is a reply to message #381126] Mon, 16 July 2007 09:18 Go to previous message
Hi Jose,
uml to ecore.
- James.
> Jose,
> Jose wrote:
> > Hi,
> > correctly?
> > Thanks.
Re: Generating code with stereotypes [message #596945 is a reply to message #381131] Fri, 20 July 2007 07:38 Go to previous message
Thanks James-Bruck,
not do it?
Thanks.
> Hi Jose,
> uml to ecore.
> - James.
>> Jose,
>> Jose wrote:
>>> Hi,
>>> correctly?
>>> Thanks.
Re: Generating code with stereotypes [message #596959 is a reply to message #381147] Fri, 20 July 2007 10:16 Go to previous message
Hi Jose,
profile?
- James.
> Thanks James-Bruck,
> not do it?
> Thanks.
> James Bruck escribi
Re: Generating code with stereotypes [message #596979 is a reply to message #381149] Fri, 20 July 2007 10:54 Go to previous message
James Bruck wrote:
> Hi Jose,
> profile?
> - James.
>> Thanks James-Bruck,
>> not do it?
>> Thanks.
>> James Bruck wrote:
>>> Hi Jose,
> from
>>> uml to ecore.
> the
> new
> what
>>> you are looking for
> I
>>> - James.
>>>> Jose,
>>>> Jose wrote:
>>>>> Hi,
>>>>> correctly?
>>>>> Thanks.
Previous Topic:Why does the URI scheme disallow ':' ?
Next Topic:getting EODM to run
Current Time: Sun Jul 27 07:49:50 EDT 2025
Powered by FUDForum. Page generated in 0.40500 seconds
