Home » Modeling » EMF » EMF in standalone applications
EMF in standalone applications [message #380769] Thu, 04 December 2003 11:42 Go to next message
The entry in the FAQ about whether EMF models can be used in standalone
applications at
http://dev.eclipse.org/viewcvs/indextools.cgi/~checkout~/emf -home/faq.html#dev_standalone
leaves several questions unanswered.
By 'EMF model' is it just talking about the generated java files in the
plugin project and not about the corresponding "edit" and "editor"
plugins projects? In particular how does the standalone application
invoke the plugin editor?Is it possible to use the generated "editor"
plugin in a standalone application? How does the main program
communicate with the editor (such as if it needs to pass the names of
files with which the editor is to start up)?
Is there some document which can give me the answers to these questions?
thanks for considering,
-rajesh
Re: EMF in standalone applications [message #380770 is a reply to message #380769] Thu, 04 December 2003 12:10 Go to previous messageGo to next message
The FAQ on the website does not mention the generated "editor" plugin
when it talks about standalone execution of the EMF model. Is there a
clean way to use the generated editor in a standalone application?
all comments/suggestions are greatly appreciated.
> applications at
> -rajesh
Re: EMF in standalone applications [message #380775 is a reply to message #380770] Thu, 04 December 2003 14:26 Go to previous messageGo to next message
Rajesh,
The .edit projects can be used standalone (although you'd need to put the plugin.properties and
icons into a resource jar), but the .editor projects are tightly integrated Eclipse components
that will only function within an Eclipse environment.
> > applications at
> > -rajesh
Re: EMF in standalone applications [message #380865 is a reply to message #380775] Mon, 08 December 2003 06:57 Go to previous messageGo to next message
I've used the .edit plugins in standalone applications. Works great!
Do you already have plans to get the .editor part working with the
forthcoming Rich Client Platform of Eclipse 3.0?
--knut
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:3FCF8A63.6CE6BC9D@ca.ibm.com...
> Rajesh,
standalone
> > > applications at
the
questions?
> > > -rajesh
Re: EMF in standalone applications [message #380866 is a reply to message #380865] Mon, 08 December 2003 07:35 Go to previous messageGo to next message
Knut,
Thanks for pointing out that the EMF.Edit support does work standalone. It's only the
integrated editors that require Eclipse. Unfortunately, I haven't looked at the rich client
stuff yet, so I'm not sure if there's anything we need to do to support it. What do you
think will be involved? (We are up and running with JDK 1.4 and Eclipse 3.0 M5 internally
now, so maybe that's all that's needed.)
> --knut
> > Rajesh,
> standalone
> > > > applications at
> the
> questions?
> > > > -rajesh
Re: EMF in standalone applications [message #380868 is a reply to message #380866] Mon, 08 December 2003 09:20 Go to previous messageGo to next message
Ed,
I'm not intimately familiar with all the dependencies of the generated
model, .edit, and .editor plugins with the forthcoming 3.0 compatible
driver. But if these don't depend on any plugins not provided by the RCP
(such as JDT plugins), then the editor should work just fine.
The developer will just have to provide a simple application plugin (or
extend the .editor plugin) to extend the extension points
org.eclipse.core.runtime.applications and org.eclipse.ui.perspectives (a
default perspetive is required) and provide a WorkbenchAdvisor
implementation. All this should be quite simple. Take a look at this
tutorial to get an idea:
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/platform -ui-home/rcp-proposal/rcp_tutorial/index.html.
Maybe this is even something that could be generated by EMF?
Hopefully you'll be able to get an 3.0 M5 compatible driver out this week
--knut
news:3FD4701E.F14779CA@ca.ibm.com...
> Knut,
It's only the
at the rich client
it. What do you
3.0 M5 internally
> > --knut
> > > Rajesh,
the
plugin
a
> > standalone
> > > > > applications at
in
> > the
application
"editor"
of
> > questions?
> > > > > -rajesh
Re: EMF in standalone applications [message #381510 is a reply to message #380769] Fri, 09 January 2004 23:45 Go to previous messageGo to next message
Originally posted by: lehrler.infoscience.otago.ac.nz
I used the FAQ to get my application working standalone.
I had to add the jars:
org.eclipse.emf.common.common.jar
org.eclipse.emf.ecore.ecore.jar
org.eclipse.emf.ecore.xmi.ecore.xmi.jar
- otherwise it would not compile. This is not mentioned in the FAQ. Did I do something wrong or is this a missing point
in the FAQ ?
(I don't want to use the edit-framework but only the generated model itself).
Lars
Re: EMF in standalone applications [message #381515 is a reply to message #381510] Mon, 12 January 2004 09:23 Go to previous message
Lars,
Yes, you need to add to the classpath all the jars for the plugins (and their dependent plugins) that you want to use
standalone. We didn't list them explicitly in the FAQ since the list is dependent on exactly what plugins you want to use
and is available by looking at the runtime libraries in their plugin.xml files.
Frank.
> in the FAQ ?
> Thanks
> Lars
Previous Topic:splitting a model into several packages, using EclipseUML or Model editor
Next Topic:Synchronization problems in generated code?
Current Time: Tue Oct 28 18:37:42 EDT 2025
Powered by FUDForum. Page generated in 0.21154 seconds
