[TCS] Problem in injector TCS [message #380501] |
Thu, 13 December 2007 15:45  |
Originally posted by: analuisafdm.gmail.co.
I hope the some can help-me!!! IŽm starting to work with TCS.
IŽm trying executing this example:
http://www.eclipse.org/gmt/tcs/download/TCSSample.zip
When I had sucess in extractor. (I executed
SampleDSL_ExtractorCreation.xml). But when I tried executing, in this
example, transformationg text to model, the injector (I executed
SampleDSL_InjectorCreation.xml), and I obtained some problems. I read some
topics this forum and I tried doing download ATL and some file AM3 of the
CVS, but This not resolved my problems. That I am going trying to describe
it:
First Problem: when I executed SampleDSL_InjectorCreation.xml, in this
case appear:
TCS2ANTLR:
[am3.atl] INFO: Executing ATL transformation
../TCSToolkit/ATL/TCS2ANTLR/TCS2ANTLR.asm
[am3.saveModel] INFO: Saving model AddressBook.g
[am3.saveModel] Warning: could not get comments of OUT!AddressBook,
disabling further comments serialization
[am3.saveModel] org.atl.engine.extractors.ebnf.EBNFExtractionException:
cannot find mathing template for: SimpleSemanticAction
[am3.saveModel] at
org.atl.engine.extractors.ebnf.EBNFExtractor.serialize(EBNFE xtractor.java:241)
[am3.saveModel] at
org.atl.engine.extractors.ebnf.EBNFExtractor.serializeProper ty(EBNFExtractor.java:609)
[am3.saveModel] at
org.atl.engine.extractors.ebnf.EBNFExtractor.serializeProper ty(EBNFExtractor.java:592)
Second Problem: when I executed build.xml that I need to execute for
injector, in this case appear:
[am3.loadModel] INFO: Loading of model M
[am3.loadModel] java.lang.ClassNotFoundException:
org.atl.engine.injectors.ebnf.AddressBook_ANTLR3Lexer
[am3.loadModel] at
org.apache.tools.ant.AntClassLoader.findClassInComponents(An tClassLoader.java:1383)
[am3.loadModel] at
org.apache.tools.ant.AntClassLoader.findClass(AntClassLoader .java:1324)
[am3.loadModel] at
org.apache.tools.ant.AntClassLoader.loadClass(AntClassLoader .java:1072)
[am3.loadModel] at java.lang.ClassLoader.loadClass(Unknown Source)
[am3.loadModel] at java.lang.ClassLoader.loadClassInternal(Unknown Source)
Thanks!!
kisses!!!
Re: [TCS] Problem in injector TCS [message #380502 is a reply to message #380501] |
Thu, 13 December 2007 15:49   |
TCSSample.zip only works with older versions of ATL+AM3.
You should use the newer version. See the following wiki page for more
information:
http://wiki.eclipse.org/TCS/Language_Project
Note that I also updated the TCS wiki page to provide this information,
as you can see at:
http://wiki.eclipse.org/TCS#Sample_Projects
Thanks for reporting this glitch in the documentation :-).
Frédéric Jouault
Ana Luisa wrote:
> Hello,
> some topics this forum and I tried doing download ATL and some file AM3
> of the CVS, but This not resolved my problems. That I am going trying to
> describe it:
> case appear:
> TCS2ANTLR:
> [am3.saveModel] at
> [am3.saveModel] at
> [am3.saveModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> Source)
> Thanks!!
> kisses!!!
Re: [TCS] Problem in injector TCS [message #380579 is a reply to message #380578] |
Thu, 13 December 2007 23:17  |
Originally posted by: analuisafdm.gmail.com
Frederic,
You can discard previous messages about error in installation TCS plugin
I trying several times and now, I had sucess in installation in this
plugin. Again, I realize Checkout CVS ATL and AM3 and plugin was installed
with sucess.
But when I trying create project. New --> TCS Language Project ,
I find the problem following:
The select wizard could not be started.
Reason:
Pluging org.eclipse.gmt.tcs.wizard was enable to load a class
org.eclipse.gmt.tcs.wizard.TcsProjectWizard.
I observed that there is in this Forum a similar user message, but I didŽt
obtain sucess.
Could you help me?
Thanks!!!
Re: [TCS] Problem in injector TCS [message #611013 is a reply to message #380501] |
information:
as you can see at:
Frédéric Jouault
Ana Luisa wrote:
> Hello,
> describe it:
> case appear:
> TCS2ANTLR:
> [am3.saveModel] at
> [am3.saveModel] at
> [am3.saveModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> Source)
> Thanks!!
> kisses!!!
Re: [TCS] Problem in injector TCS [message #611015 is a reply to message #380502] |
Thu, 13 December 2007 20:37  |
Hi Frederic,
Thanks your help!!!
But how iŽm needing very much to validate an example with TCS I trying
this plugin TCS for Eclipse, but I realized the download files
org.eclipse.gmt.tcs.builder and org.eclipse.gmt.tcs.wizard, and I didn't
have sucess, this files has dependencies with Libraries. So Eclipse
installed in my pc didnŽt Recognize :(.
one more time, Thank your help!!
Ana Luisa
Re: [TCS] Problem in injector TCS [message #611018 is a reply to message #380503] |
Thu, 13 December 2007 20:46  |
Sorry Frederic!!!,
I forgot ask you a question.
Is there some site (link) that I can use in Eclipse through Software
Updates to realize download of the plugin TCS?
Thanks!!!
Ana Luisa
Re: [TCS] Problem in injector TCS [message #611019 is a reply to message #380578] |
Frederic,
with sucess.
Reason:
obtain sucess.
Could you help me?
Thanks!!!
FUDForum. Page generated in 1.15640 seconds
