[AM3] ATL transformation Ant Task [message #380326] |
Mon, 29 October 2007 06:13  |
Originally posted by: frederic.thomas.cea.fr
I would like to launch programmaticaly an ATL transformation on UML models
with the AM3 ant tasks. Hence, I wrote that ant script :
<am3.atl path="${transformationPath}/PD2APD.atl"
allowintermodelreferences="true">
<inModel name="UML2" model="UML2"/>
<inModel name="IN" model="PDS"/>
<inModel name="TraceaPro" model="TraceaPro"/>
<outModel name="OUT" model="${APD}" metamodel="UML2"/>
<library name="UML2Lib" path="${libraryPath}/UML2Lib.asm"/>
</am3.atl>
The corresponding models are succesfully load and saved with am3 task. The
transformation is executed without errors. Nevertheless the output model
is corrupted. Some XMI references are wrong.
I have tried to launch the same configuration with the GUI wizard and the
output model is healthy.
Does anybody deal with that problem ?
Re: [AM3] ATL transformation Ant Task [message #380327 is a reply to message #380326] |
Mon, 29 October 2007 18:04  |
Hi Frédéric,
You may need to use the "path" attribute in the outModel element:
<outModel name="OUT" model="${APD}" metamodel="UML2" path="xxx.uml" />
EMF will use this to determine the correct factory
(http://wiki.eclipse.org/AM3_Ant_Tasks#outModel).
Freddy.
frederic.thomas@cea.fr a écrit :
> models with the AM3 ant tasks. Hence, I wrote that ant script :
> </am3.atl>
> The transformation is executed without errors. Nevertheless the output
> model is corrupted. Some XMI references are wrong.
> the output model is healthy.
Re: [AM3] ATL transformation Ant Task [message #608243 is a reply to message #380326] |
Hi Frédéric,
Freddy.
> </am3.atl>
FUDForum. Page generated in 0.22747 seconds
