Home » Modeling » EMF » OCL Support In EMF?
OCL Support In EMF? [message #380102] Thu, 23 October 2003 18:26 Go to next message
Hi All:
Thanks in advance for your response.
EMF seems to be a very valuable toolkit. I posted something similar a few
months back asking about plans for adding validation support to EMF. Please
correct me if what I state below is overlooking current capabilities
available in EMF.
We recently exposed what seems to be a deficiency with this framework and
almost all frameworks of this type. We downloaded the WSDL 1.2 XSD, created
an Ecore model from that, and generated model, edit, and editor source code.
Very powerful! Unfortunately, in the process, we lost validation described
in the XSD during the generation process. I realize we can reactively
invoke validation checking on a populated resource. I'm interested in
proactive validation. I would like my generated EMF API to disallow the
creation of content that will ultimately be found to be invalid. I also
realize XSDs are only one source from which an Ecore model can be created. I
am curious, however, if anyone has given thought and/or if there are plans
to acknowledge the value of and address the need for this capability in EMF?
It seems to me there would be tremendous value leveraged by transferring
relevant validation content expressed within an XSD into the Ecore model.
For annotated Java interfaces adding annotations related to validation would
be very useful. For UML models capturing OCL constraints would be very
useful. I notice there is a meta-model in the works for UML Object
Constraint Language (OCL). Any thoughts on extending Ecore by adding the
OCL meta-model or some useful subset therein? Once the information is
captured in the Ecore model code generation can produce validation-oriented
methods that can be invoked proactively via the notification framework.
Proactive vs. reactive validation could be configurable.
I think EMF has nailed the meta-model for content and generation technology
that produces predictable and polished content management and editing APIs.
It seems one of the next steps is supporting the capture of behavioral
constraints and characteristics associated with modeled content in a
technology platform independent fashion and subsequently leveraging that
meta-data during technology platform generation activities.
Thanks for a great tool!
Chris Potter
Re: OCL Support In EMF? [message #380108 is a reply to message #380102] Fri, 24 October 2003 11:13 Go to previous messageGo to next message
Chris,
We are interested in adding the kind of validation support you describe,
although we have no committed plan stating how and when. We're imagining some
kind of ecore model annotations (EAnnotation), that would affect the code
generation - similar to what I believe you're suggesting. These annotations
could be produced from XML schema, Java annotations, or UML model constrains.
For constrains on simple types (e.g., the value of an int attribute is in the
range of 1..10), we can imagine generation of proactive checking, but for things
like the multiplicity of an association, we believe that the checking can only
be done when the user indicates that the model is consistent. Is that not how
you see it?
At any rate, we imagine EMF providing the ability to generate validation code,
based on constraints defined in the original model, at some point in time. A
prereq for this support is the more general requirement to make the EMF code
generator more customizable/extensible, which we will be working on soon.
Frank.
Chris Potter wrote:
> Hi All:
> available in EMF.
> Chris Potter
Re: OCL Support In EMF? [message #380137 is a reply to message #380108] Mon, 27 October 2003 10:46 Go to previous messageGo to next message
Thanks for your response Frank. I completely agree with the approach you
describe below. The one item I'm uncertain of, regarding implementation, is
the sufficiency of EAnnotations as the container for this information. It
seems there may be enough content/complexity to describing constraints that
a content model would be beneficial.
Chris Potter
"Frank Budinsky" <frankb@ca.ibm.com> wrote in message
news:3F99418E.A4F2A017@ca.ibm.com...
> Chris,
some
annotations
constrains.
the
things
only
how
> you see it?
code,
A
code
> Frank.
> Chris Potter wrote:
> > Hi All:
few
Please
> > available in EMF.
and
created
code.
described
created. I
plans
EMF?
model.
would
the
validation-oriented
technology
APIs.
> > Chris Potter
Re: OCL Support In EMF? [message #380138 is a reply to message #380137] Mon, 27 October 2003 11:10 Go to previous messageGo to next message
Chris,
Maybe you are interpreting Frank's comment as saying that we would use
EAnnotations to "model" the constraints. The point is more that
EAnnotation.contents can hold any EObject so using an annotation any other model
can be embedded directly into the Ecore model.
> Chris Potter
> > Chris,
> some
> annotations
> constrains.
> the
> things
> only
> how
> > you see it?
> code,
> A
> code
> > Frank.
> > Chris Potter wrote:
> > > Hi All:
> few
> Please
> > > available in EMF.
> and
> created
> code.
> described
> created. I
> plans
> EMF?
> model.
> would
> the
> validation-oriented
> technology
> APIs.
> > > Chris Potter
Annotations in EMF (was: OCL Support In EMF?) [message #380146 is a reply to message #380138] Mon, 27 October 2003 12:38 Go to previous messageGo to next message
Ed,
In a giant leap of faith... I'm thinking back to an earlier thread about
generalizing the model for representing XSD annotations in the EMF model
derived from a schema.
If you take the XML Schema for XHTML (probably the "basic" subset) and
generate an EMF model for it, could you use this to represent any XHTML
content as explicitly modeling EMF objects in an annotation? The same might
be useful for models other than XSD, where rich-formatted annotations are
represented as XHTML objects.
Is this feasible? Easy to do?
Dave Carlson
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:3F9D4392.5E5F1204@ca.ibm.com...
> Chris,
model
Re: Annotations in EMF (was: OCL Support In EMF?) [message #380156 is a reply to message #380146] Mon, 27 October 2003 15:33 Go to previous messageGo to next message
Dave,
I kind of doubt that the EMF model for the XHTML schema would be usable, but it
does seem feasible.
In EMF 2.0 we will be able to handle the XML Schema "anyType", which has mixed
content, and lax element and attribute wildcards. As such we will be able to
read in (and write back out) the equivalent of arbitrary unvalidated DOM...
Dave Carlson wrote:
> Ed,
> Cheers,
> Dave Carlson
> > Chris,
> model
Re: OCL Support In EMF? [message #380179 is a reply to message #380138] Tue, 28 October 2003 00:19 Go to previous messageGo to next message
Hi Ed:
Thanks for contributing to this thread. I think I'm following you and do
see how EAnnotations could be used as the vehicle for adding validation
"hooks" into Ecore models. It seems to me, however, validation would best
be represented within the EMF kernel or core meta-model. I think the type
of validation constructs supported within an Ecore meta-model would be
different for EAttributes, EReferences, and EClasses. Adding support for
validation by creating EAnnotation instances within an Ecore model wouldn't
constrain validation constructs to what would be appropriate for each of
these specialized EModelElements. I view EAnnotations as an excellent means
by which to annotate an Ecore model with functionality specific to a
particular EMF consumer (or in the case of XML Schema, model enrichment
unique to that meta-model source). I view the need to express validation
content within EAttributes, EReferences, and EClasses as important as
expressing that an EClass can have an association of EReferences.
I hope I'm not missing your point.
Chris Potter
> Chris,
model
you
implementation, is
It
that
> > Chris Potter
> > > Chris,
describe,
imagining
> > some
code
> > annotations
> > constrains.
in
> > the
for
> > things
can
> > only
not
> > how
> > > you see it?
validation
> > code,
time.
> > A
EMF
> > code
soon.
> > > Frank.
> > > Chris Potter wrote:
> > > > Hi All:
a
> > few
> > Please
> > > > available in EMF.
framework
> > and
> > created
source
> > code.
> > described
reactively
in
the
also
> > created. I
> > plans
in
> > EMF?
transferring
> > model.
validation
> > would
very
adding
> > the
is
> > validation-oriented
framework.
> > technology
editing
> > APIs.
behavioral
that
> > > > Chris Potter
Re: OCL Support In EMF? [message #380180 is a reply to message #380179] Tue, 28 October 2003 07:44 Go to previous message
Chris,
My concern with extending the Ecore model directly to express constraints is the
possibility or even likelihood that a constraint model would quickly dwarf the
core model itself; one need only look at XML Schema to get a sense for how
quickly complexity can grow beyond the grasp of mere mortals. So my initial
preference would be to ensure that the core can standalone and that additional
features act like layers on the onion that can be peeled away by those who only
need or want the core. I can imagine that embedding an EReferenceConstraint in
an EReference's annotation, and an EAttributeConstraint in a EAttribute's
annotation, would support the kind of specialized constraints you allude to
below.
Chris Potter wrote:
> Hi Ed:
> Chris Potter
> > Chris,
> model
> you
> implementation, is
> It
> that
> > > Chris Potter
> > > > Chris,
> describe,
> imagining
> > > some
> code
> > > annotations
> > > constrains.
> in
> > > the
> for
> > > things
> can
> > > only
> not
> > > how
> > > > you see it?
> validation
> > > code,
> time.
> > > A
> EMF
> > > code
> soon.
> > > > Frank.
> > > > Chris Potter wrote:
> > > > > Hi All:
> a
> > > few
> > > Please
> > > > > available in EMF.
> framework
> > > and
> > > created
> source
> > > code.
> > > described
> reactively
> in
> the
> also
> > > created. I
> > > plans
> in
> > > EMF?
> transferring
> > > model.
> validation
> > > would
> very
> adding
> > > the
> is
> > > validation-oriented
> framework.
> > > technology
> editing
> > > APIs.
> behavioral
> that
> > > > > Chris Potter
Previous Topic:EMF ecore-to-java customization
Next Topic:Dynamic Templates Property
Current Time: Sun Sep 07 04:29:15 EDT 2025
Powered by FUDForum. Page generated in 0.04865 seconds
