Home » Archived » GMT (Generative Modeling Technologies) » [TCS]:Problem to generate the Extractor.
[TCS]:Problem to generate the Extractor. [message #380178] Wed, 24 October 2007 17:26 Go to next message
Originally posted by: youssedek.gmail.com
I'm spirit to test the Program example of TCSZoo.
But I did'nt arrive to generate the good result.
It is always a empty model (AlarmClock.pgrm.xmi).
I reinstalled the eclipse(Europa 3.3,EMF 2.3, Atl 2.0, AMMA Script ....)
but always the same result how you me advised to solve this problem????
thank you
Youssef
Re: [TCS]:Problem to generate the Extractor. [message #380332 is a reply to message #380178] Thu, 08 November 2007 08:24 Go to previous messageGo to next message
Hi freddy
My Eclipse contains the task "Eclipse Specific Task" but I always have the
same problem ,my extractor generate a empty file. and here the result of
the generation of the extractor
Buildfile: /home/ydkiouak/workspace1/Program/Extraxteur_build.xml
extraction:
[echo] ==== Loading Models to serialize AlarmClock.xmi ==========
[am3.loadModel] INFO: Loading of model source
[am3.loadModel] INFO: Loading of model TCS
[am3.loadModel] INFO: Loading of model MyLanguage-TCS
[echo] ==== serializing AlarmClock.xmi ==========
[am3.saveModel] INFO: Saving model source
[am3.saveModel] Error: no root found.
BUILD SUCCESSFUL
Total time: 912 milliseconds
you can explain me the problem?
and how to solve it?
thank you
Youssef
Re: [TCS]:Problem to generate the Extractor. [message #380333 is a reply to message #380332] Thu, 08 November 2007 12:43 Go to previous messageGo to next message
check the contents of the model you want to extract. This error usually
happens when you have more than one root element, or no elements at all.
For instance, you should not have <xmi:XMI xmi:version="2.0"> element as
the root.
Marcos.
dkiouak youssef wrote:
> Hi freddy
> the same problem ,my extractor generate a empty file. and here the
> result of the generation of the extractor
> extraction:
> BUILD SUCCESSFUL
> thank you
> Youssef
Re: [TCS]:Problem to generate the Extractor. [message #380335 is a reply to message #380333] Mon, 12 November 2007 04:44 Go to previous messageGo to next message
Hi Marcos,
my model contains the element root
and here the extract of my model:
<PetriNetForText:Modele xmi:version="2.0"
xmlns:PetriNetForText="http://PetriNetForText">
<elements xsi:type="PetriNetForText:PetriNet" name="test"/>
</elements>
</PetriNetForText:Modele>
you can indicate me an example in TCS Zoo to which you tested (I'm
interested especially to the extraxtor??)
thanks you
Youssef
Re: [TCS]:Problem to generate the Extractor. [message #380339 is a reply to message #380335] Tue, 13 November 2007 03:39 Go to previous message
below there is an example of an Ant script that extracts a SQL-DDL
model. It is used in an AMW use case (KM32SQL -
http://www.eclipse.org/gmt/amw/usecases/modelgen/).
<echo message="Preparing SQL extraction.."/>
<am3.loadModel modelHandler="EMF" name="TCS" metamodel="MOF"
path="${path}/scripts/TCS.ecore" />
<am3.loadModel modelHandler="EMF" name="SQLDDL.tcs" metamodel="TCS"
path="${path}/scripts/SQLDDL-TCS.ecore"/>
<am3.saveModel model="SQL_MODEL" path="${path}/models/mantis-sql.sql">
<extractor name="ebnf">
<param name="format" value="SQLDDL.tcs"/>
</extractor>
</am3.saveModel>
Marcos.
Dkiouak youssef wrote:
> Hi Marcos,
> xmlns:xmi="http://www.omg.org/XMI"
> </elements>
> thanks you
> Youssef
Re: [TCS]:Problem to generate the Extractor. [message #608247 is a reply to message #380178] Thu, 08 November 2007 08:24 Go to previous message
Hi freddy
extraction:
BUILD SUCCESSFUL
thank you
Youssef
Re: [TCS]:Problem to generate the Extractor. [message #608248 is a reply to message #380332] Thu, 08 November 2007 12:43 Go to previous message
the root.
Marcos.
> Hi freddy
> extraction:
> BUILD SUCCESSFUL
> thank you
> Youssef
Re: [TCS]:Problem to generate the Extractor. [message #608250 is a reply to message #380333] Mon, 12 November 2007 04:44 Go to previous message
Hi Marcos,
</elements>
thanks you
Youssef
Re: [TCS]:Problem to generate the Extractor. [message #608253 is a reply to message #380335] Tue, 13 November 2007 03:39 Go to previous message
</extractor>
</am3.saveModel>
Marcos.
> Hi Marcos,
> </elements>
> thanks you
> Youssef
Previous Topic:[TCS]:Error with TCS Wizard
Next Topic:[Announce] The EclipseCon 2008 Submission Deadline is Rapidly Approaching.
Current Time: Wed Jul 23 17:36:02 EDT 2025
Powered by FUDForum. Page generated in 0.26791 seconds
