Home » Archived » GMT (Generative Modeling Technologies) » [TCS]:Create a Language project!!
[TCS]:Create a Language project!! [message #379850] Fri, 05 October 2007 10:54 Go to next message
Originally posted by: joseph.brooth.gmail.com
i have the problem with checked out the AMMAScripts and AMMACore.
is necessary to add CVS Repository ?
so yes I find how I can the configuration with this CVS(the host, the
standard connection.............)
thnx
Joseph
Re: [TCS]:Create a Language project!! [message #379856 is a reply to message #379850] Sat, 06 October 2007 12:48 Go to previous messageGo to next message
Please, see answer to your previous post.
Frédéric Jouault
> thnx
> Joseph
Re: [TCS]:Create a Language project!! [message #379903 is a reply to message #379856] Mon, 08 October 2007 06:41 Go to previous messageGo to next message
Originally posted by: joseph.Brooth.gmail.com
yes I added the All scripts in my workspace but I have remarks for the
following points:
******* build.properties (you can copy and paste
/SampleLanguage/build.properties and modify it).*******
for this file I recovered with one project of ZOO TCS because I did'nt
find "/SampleLanguage/build.properties" how to configure this file?
for me I notched "Custom build"!!
Es this that it is correct?.
******** In the "Targets" tab:--Set "During a Clean" to target "clean"
I dont arrive to fair this point because I found the zone "During a Clean"
desactivate and text posted inside "Builder is not set to run for this
build kind" same thing in the fields "After A clean" and "Auto build"
I tested with the button "Set Targets" but always this zone is desactivate?
how I should make to activate?
finaly for excute my TCS Projects(Model-To project -- Text) how I must
make? Thank you for your Helps.
Joseph
Re: [TCS]:Create a Language project!! [message #380367 is a reply to message #379903] Fri, 16 November 2007 11:49 Go to previous message
Please see answer in other thread.
Frédéric Jouault
joseph Brooth wrote:
> following points:
> Clean" desactivate and text posted inside "Builder is not set to run for
> this build kind" same thing in the fields "After A clean" and "Auto build"
> Joseph
Re: [TCS]:Create a Language project!! [message #608054 is a reply to message #379850] Sat, 06 October 2007 12:48 Go to previous message
Frédéric Jouault
> thnx
> Joseph
Re: [TCS]:Create a Language project!! [message #608064 is a reply to message #379856] Mon, 08 October 2007 06:41 Go to previous message
following points:
Joseph
Re: [TCS]:Create a Language project!! [message #608260 is a reply to message #379903] Fri, 16 November 2007 11:49 Go to previous message
Frédéric Jouault
> following points:
> Joseph
Previous Topic:[TCS]:beginning TCS with Eclipse
Next Topic:[TCS]:Creating a Language Project For Plugin Builder
Current Time: Sat Jul 26 11:57:53 EDT 2025
Powered by FUDForum. Page generated in 0.10132 seconds
