Home » Modeling » Modeling (top-level project) » plugin for reverse engineering
plugin for reverse engineering [message #379669] Wed, 28 February 2007 10:40 Go to next message
Originally posted by: sandrine.nnomongali.atosorigin.com
hi,
Is there any plugin for reverse engineering from .class ?
thanks.
Re: plugin for reverse engineering [message #379671 is a reply to message #379669] Thu, 01 March 2007 09:41 Go to previous messageGo to next message
Sandrine,
Not that I know of, no.
sandrine wrote:
> hi,
> thanks.
Re: plugin for reverse engineering [message #379672 is a reply to message #379671] Thu, 01 March 2007 13:02 Go to previous messageGo to next message
Hi Sandrine, Ed,
I've written a small command-line tool that takes a jar file as input
and generates a UML file. I use it to generate UML models of the
different Java API versions.
It's still in a brainstorm stage, but you can take a look at the code to
get an example. The code (and some generated models) are available here:
http://ssel.vub.ac.be/viewcvs/viewcvs.py/PlatformKit/platfor mkit-java/
Dennis
Ed Merks schreef:
> Sandrine,
> sandrine wrote:
>> hi,
>> thanks.
Re: plugin for reverse engineering [message #379674 is a reply to message #379672] Thu, 01 March 2007 13:50 Go to previous messageGo to next message
Dennis,
Cool. Thanks for sharing that!
Dennis Wagelaar wrote:
> Hi Sandrine, Ed,
> to get an example. The code (and some generated models) are available
> here:
> Regards,
> Dennis
> Ed Merks schreef:
>> Sandrine,
>> sandrine wrote:
>>> hi,
>>> thanks.
Re: plugin for reverse engineering [message #379985 is a reply to message #379674] Fri, 23 March 2007 12:50 Go to previous messageGo to next message
Hi back!
Since there's been some outside interest, I've decided to make a plugin
out of the jar-to-UML code:
http://ssel.vub.ac.be/ssel/research:mdd:jar2uml
Hopefully it can be useful for you!
Dennis
Ed Merks schreef:
> Dennis,
>> Hi Sandrine, Ed,
>> here:
>> Regards,
>> Dennis
>> Ed Merks schreef:
>>> Sandrine,
>>> sandrine wrote:
>>>> hi,
>>>> thanks.
Re: plugin for reverse engineering [message #379987 is a reply to message #379985] Fri, 23 March 2007 13:31 Go to previous message
Dennis,
I saw that on the other newsgroups and was hoping to get a chance to
play with it some time. Since there is an Ecore importer for UML, this
indirectly provides a way to build an Ecore model...
> Hi back!
> plugin out of the jar-to-UML code:
> Regards,
> Dennis
> Ed Merks schreef:
>> Dennis,
>>> Hi Sandrine, Ed,
>>> input and generates a UML file. I use it to generate UML models of
>>> the different Java API versions.
>>> code to get an example. The code (and some generated models) are
>>> available here:
>>> Regards,
>>> Dennis
>>> Ed Merks schreef:
>>>> Sandrine,
>>>> sandrine wrote:
>>>>> hi,
>>>>> thanks.
Re: plugin for reverse engineering [message #586785 is a reply to message #379669] Thu, 01 March 2007 09:41 Go to previous message
Sandrine,
sandrine wrote:
> hi,
> thanks.
Re: plugin for reverse engineering [message #586791 is a reply to message #379671] Thu, 01 March 2007 13:02 Go to previous message
Hi Sandrine, Ed,
Dennis
Ed Merks schreef:
> Sandrine,
> sandrine wrote:
>> hi,
>> thanks.
Re: plugin for reverse engineering [message #586808 is a reply to message #379672] Thu, 01 March 2007 13:50 Go to previous message
Dennis,
> Hi Sandrine, Ed,
> here:
> Regards,
> Dennis
> Ed Merks schreef:
>> Sandrine,
>> sandrine wrote:
>>> hi,
>>> thanks.
Re: plugin for reverse engineering [message #590054 is a reply to message #379674] Fri, 23 March 2007 12:50 Go to previous message
Hi back!
Dennis
Ed Merks schreef:
> Dennis,
>> Hi Sandrine, Ed,
>> here:
>> Regards,
>> Dennis
>> Ed Merks schreef:
>>> Sandrine,
>>> sandrine wrote:
>>>> hi,
>>>> thanks.
Re: plugin for reverse engineering [message #590064 is a reply to message #379985] Fri, 23 March 2007 13:31 Go to previous message
Dennis,
> Hi back!
> Regards,
> Dennis
> Ed Merks schreef:
>> Dennis,
>>> Hi Sandrine, Ed,
>>> available here:
>>> Regards,
>>> Dennis
>>> Ed Merks schreef:
>>>> Sandrine,
>>>> sandrine wrote:
>>>>> hi,
>>>>> thanks.
Previous Topic:EMF genmodel properties documentation??
Next Topic:Override the palette generated by GMF
Current Time: Sat Jul 26 02:55:18 EDT 2025
Powered by FUDForum. Page generated in 0.05049 seconds
