Home » Archived » OHF » OutOfMemoryError from Bridge
OutOfMemoryError from Bridge [message #37936] Tue, 04 December 2007 05:20 Go to next message
Hi everyone,
Today I built the latest Bridge, tested it and found that it returned
OutOfMemoryError while processing a response from
http://129.6.24.109:9080/axis2/services/xdsregistrya
My query was as below.
<query:AdhocQueryRequest
xmlns:query="urn:oasis:names:tc:ebxml-regrep:query:xsd:2.1" ><query:ResponseOption
returnComposedObjects="true" returnType="LeafClass"
/><query:SQLQuery>SELECT doc.id FROM ExtrinsicObject doc,
ExternalIdentifier patId WHERE doc.objectType =
'urn:uuid:7edca82f-054d-47f2-a032-9b2a5b5186c1' AND (patId.registryObject
= doc.id AND patId.identificationScheme =
'urn:uuid:58a6f841-87b3-4a3e-92fd-a8ffeff98427' AND patId.value =
('428db2e57eaf4aa^^^&amp;1.3.6.1.4.1.21367.2005.3.7& amp;ISO')) AND
(doc.status IN ('Approved', 'Deprecated'))
</query:SQLQuery></query:AdhocQueryRequest>
The log file shows the server returned tons of <ObjectRef>s and that might
have caused this problem. Can anyone try the same thing to see which
software is wrong - the server, the Bridge or my environment?
Takeo Satomi
Re: OutOfMemoryError from Bridge [message #38006 is a reply to message #37936] Tue, 04 December 2007 13:04 Go to previous message
Hi Takeo,
Thanks for the report. Yes, this is likely an OHF issue. If you would,
could you please post the full stack trace to the OutOfMemoryException
so we can see where it's happening - preferably in a bug report.
-Matt
Takeo Satomi wrote:
> Hi everyone,
> (patId.registryObject = doc.id AND patId.identificationScheme =
> might have caused this problem. Can anyone try the same thing to see
> which software is wrong - the server, the Bridge or my environment?
> Takeo Satomi
Re: OutOfMemoryError from Bridge [message #583491 is a reply to message #37936] Tue, 04 December 2007 13:04 Go to previous message
Hi Takeo,
-Matt
Takeo Satomi wrote:
> Hi everyone,
> Takeo Satomi
Previous Topic:Building a scenario in STEM
Next Topic:submissionset.uniqueId generation problem
Current Time: Thu Oct 16 01:04:04 EDT 2025
Powered by FUDForum. Page generated in 0.03613 seconds
