Can not include missing classes (packages) into java project [message #37900] |
Tue, 16 July 2002 10:57  |
Originally posted by: ptran.timeicr.com
I am facing with missing packages issue (i.e. The import Genesys....
cannot be resolved) when I tried to do "rebuild all" using eclipse for my
java project. I have tried to import these missing classes, generated from
the missing java files, in these packages (because I do not have java
codes for these packages) but eclipse does not include these classes into
my java project; Therefore it's not able to build for this error message.
I have no problem when I compile these java code in DOS window.
Please let me know what I should do to fix this.
Thanks in advance for any helps,
Phi-Di Tran
Re: Can not include missing classes (packages) into java project [message #38198 is a reply to message #38069] |
Wed, 17 July 2002 08:26  |
Thanks Rodolfo for your help. It works now.
PhiDi TranThi.
Rodolfo M. Raya wrote:
> Put all your .class files in one .jar file. Then you will be able to
> import the jar file into Eclipse.
> HTH,
> Rodolfo
> On Tue, 16 Jul 2002 11:57:49 -0300, PhiDi TranThi wrote:
> > Hi,
> > Phi-Di Tran
FUDForum. Page generated in 0.13990 seconds
