Home » Archived » Buckminster » Headless resolve and MSPEC files
Headless resolve and MSPEC files [message #378938] Wed, 30 July 2008 08:32 Go to next message
Hello again
Another quick question...
What is the headless equivalent of File->Import->Buckminster->"Materialize
from Buckminster MSPEC, CQUERY, or BOM"?
Doug
Re: Headless resolve and MSPEC files [message #378940 is a reply to message #378938] Wed, 30 July 2008 09:12 Go to previous messageGo to next message
Hi Doug,
that would be the "import" command. You can get a list of available commands
using the "lscmds" (or "listcommands") command. Usually, all commands
accept a "--help" parameter that explains what you can do with it.
HTH,
Achim
Douglas Palmer wrote:
> Hello again
> Regards
> Doug
Re: Headless resolve and MSPEC files [message #378944 is a reply to message #378940] Wed, 30 July 2008 09:50 Go to previous messageGo to next message
Thanks Achim
That works with an MSPEC which specifies a BOM in it's url. However, it
doesn't work if the url points to a CQUERY. The component meta data
language specification says that the url can point at a BOM or a CQUERY.
Do I need to do something different to use an MSPEC with a CQUERY?
Doug
Re: Headless resolve and MSPEC files [message #378946 is a reply to message #378944] Wed, 30 July 2008 10:16 Go to previous messageGo to next message
Hi Doug,
I haven't tried it with an MSPEC that points to a CQUERY, and I'm not
familiar enough with buckminster's details to say if this is a bug or a
feature ;-)
If you want to populate your workspace, you can use the "resolve" command,
which directly takes a CQUERY as an argument. If you want to do some other
materialization, like site mirroring or target platform materialization, I
guess you'll have use "import" and provide it with an MSPEC that points to
a BOM.
To produce a BOM in headless mode, you can use the following:
buckminster -N -B my.bom my.cquery
This does not populate the workspace and writes the bom to my.bom.
HTH,
Achim
> Thanks Achim
> Regards
> Doug
Re: Headless resolve and MSPEC files [message #378949 is a reply to message #378946] Wed, 30 July 2008 15:17 Go to previous messageGo to next message
Thanks again Achim
Creating a BOM first solves that problem. My only problem now is that
importing my MSPEC installs the features into buckminster rather than my
target platform. I guess that the targetPlatform materialiser doesn't use
the targetPlatformPath in the same way resolve does. Do you know how to
tell the targetPlatform materialiser where the target platform is wihout
hardcoding it into the MSPEC?
Doug
Achim Demelt wrote:
> Hi Doug,
> feature ;-)
> a BOM.
> HTH,
> Achim
Re: Headless resolve and MSPEC files [message #378950 is a reply to message #378949] Wed, 30 July 2008 16:56 Go to previous messageGo to next message
Hi Doug,
No, I 'm also specifying the target path directly in the MSPEC. Albeit, to
refrain from hardcoding an arbitrary path, I have a placeholder token in my
MSPEC and I use ant's "replace" task to insert the actual path in the
process of my build.
Achim
> Thanks again Achim
> Regards
> Doug
> Achim Demelt wrote:
>> Hi Doug,
>> feature ;-)
>> command, which directly takes a CQUERY as an argument. If you want to do
>> some other materialization, like site mirroring or target platform
>> materialization, I guess you'll have use "import" and provide it with an
>> MSPEC that points to a BOM.
>> HTH,
>> Achim
Re: Headless resolve and MSPEC files [message #378951 is a reply to message #378950] Wed, 30 July 2008 17:25 Go to previous messageGo to next message
Hi Achim
Property replacement seems to work with MSPEC files; you can set
installLocation="${myProp}" and then set the property
myProp=/location/of/target/platform. This would save the call to the ant
replace task.
Doug
Achim Demelt wrote:
> Hi Doug,
> Regards,
> Achim
Re: Headless resolve and MSPEC files [message #378953 is a reply to message #378951] Thu, 31 July 2008 01:38 Go to previous messageGo to next message
Great! Thanks for the tip!
Achim
> Hi Achim
> replace task.
> Regards
> Doug
> Achim Demelt wrote:
>> Hi Doug,
>> to refrain from hardcoding an arbitrary path, I have a placeholder token
>> in my MSPEC and I use ant's "replace" task to insert the actual path in
>> the process of my build.
>> Regards,
>> Achim
Bug submitted [message #378955 is a reply to message #378946] Thu, 31 July 2008 08:58 Go to previous messageGo to next message
I have created Bug 242669 for this issue.
"Achim Demelt" <a.demelt@exxcellent.de> wrote in message
news:g6pt3e$v0r$1@build.eclipse.org...
> Hi Doug,
> feature ;-)
Another bug submitted [message #378957 is a reply to message #378953] Thu, 31 July 2008 09:11 Go to previous messageGo to next message
Property replacement works for the installLocation attribute but not for the
url attribute. I have submitted another bug report for this. This one is
Bug 242712.
Doug
news:g6rj42$guq$1@build.eclipse.org...
> Regards,
> Achim
>> Hi Achim
>> replace task.
>> Regards
>> Doug
Patch submitted [message #378961 is a reply to message #378955] Fri, 01 August 2008 05:53 Go to previous message
I have added a patch that fixes this issue to Bug 242669.
Doug
Previous Topic:Buckminister vs Maven
Next Topic:Error retrieving "plugins/org.eclipse.update.core.win32_0.0.0.jar"
Current Time: Sun Jul 20 20:37:45 EDT 2025
Powered by FUDForum. Page generated in 0.05278 seconds
