[Mofscript] The context http://www.eclipse.org/uml2/2.0.0/UML is not found ... [message #378847] |
Sun, 12 August 2007 13:02  |
Hello everybody,
I would like to run Mofscript files from Java. I have no problem if I
execute the main Mofscript transformation (it imports other m2t files) with
the Mofscript interface but if I try to execute it from my java code I get
the errors:
Parsing result: 33 errors
: Error: MTTParseError: Illegal/unknown context: uml, line: 0, column: 0
: Error: MTTParseError: Cannot find import: guardas.m2t, line: 7, column: 7
I think that it does not find neither the context
http://www.eclipse.org/uml2/2.0.0/UML nor the imported m2t files. I am also
using the sentence parserUtil.setCompilePath(templatesDir); in my java file.
I am using Mofscript 1.2.4
Any idea?
Thank you very much in advance.
Bea
Re: [Mofscript] The context http://www.eclipse.org/uml2/2.0.0/UML is not found ... [message #378868 is a reply to message #378847] |
Fri, 17 August 2007 02:32   |
Hi again,
My configuration is Eclipse 3.3 and MOFScript 1.2.4 and perhaps the problem
is that configuration. Although I think that it is strange since if I run
the trnansformations directly, using MOFScript without using any Java file,
it works perfectly.
I also load explicity the UML metamodel in my java code adding;
ParserUtil parserUtil = new ParserUtil();
ExecutionManager execMgr = ExecutionManager.getExecutionManager();
execMgr.lookupAndAddSourceMetaModel("uml","http://www.eclipse.org/uml2/2.0.0/UML");
but It seems that that code does not anything. If I change the metamodel to
the Ecore metamodel it works, I mean, the metamodel is found.
Could anybody help me? Does anybody have try to execute MOFScript
transformations by using java files? What configuration are you using?
Bea
"bea" <beaperez@unizar.es> wrote in message
news:f9naul$tat$1@build.eclipse.org...
> Hello everybody,
> with the Mofscript interface but if I try to execute it from my java code
> I get the errors:
> 7
> also using the sentence parserUtil.setCompilePath(templatesDir); in my
> java file. I am using Mofscript 1.2.4
> Any idea?
> Bea
Re: [Mofscript] The context http://www.eclipse.org/uml2/2.0.0/UML is not found ... [message #378870 is a reply to message #378868] |
Fri, 17 August 2007 06:03   |
And what about the following context :
http://www.eclipse.org/uml2/2.1.0/UML ? Does it solve your problem ?
Bea a écrit :
> Hi again,
> it works perfectly.
> Bea
>> Hello everybody,
>> I get the errors:
>> 7
>> Any idea?
>> Bea
Re: [Mofscript] The context http://www.eclipse.org/uml2/2.0.0/UML is not found ... [message #606590 is a reply to message #378847] |
Hi again,
it works perfectly.
Bea
> Hello everybody,
> I get the errors:
> 7
> Any idea?
> Bea
Re: [Mofscript] The context http://www.eclipse.org/uml2/2.0.0/UML is not found ... [message #606591 is a reply to message #378868] |
Bea a écrit :
> Hi again,
> it works perfectly.
> Bea
>> Hello everybody,
>> I get the errors:
>> 7
>> Any idea?
>> Bea
FUDForum. Page generated in 0.06684 seconds
