Home » Modeling » OCL » VariableExp and "UMLVariable"
VariableExp and "UMLVariable" [message #36282] Thu, 30 August 2007 06:13 Go to next message
Originally posted by: krzysztof_kaczmarski.o2.pl
Hi All,
If I use OCL in UML Actions models is there any way to refer to UML
Variable from OCL expressions?
I can see that VariableExp accepts only OCL Variable...
Somehow strange if we consider those standards to be integrated.
Krzysztof
Re: VariableExp and "UMLVariable" [message #36668 is a reply to message #36282] Tue, 11 September 2007 16:19 Go to previous messageGo to next message
Hi, Krzysztof,
Right, this is one of those cases where these two standards are not
integrated.
I don't know of a way to access UML Variables; OCL only knows about
properties and operation parameters. The only part of OCL that addresses
behaviour models is the Transition guards in state machines, and variables
don't enter into it here.
Christian
Krzysztof Kaczmarski wrote:
> Hi All,
> Regards,
> Krzysztof
Re: VariableExp and "UMLVariable" [message #37779 is a reply to message #36668] Mon, 24 September 2007 06:40 Go to previous messageGo to next message
Hi Christian,
this is rather bad news for me.
If we use our imagination... is there any obstacle to integrate UML
variable with OCL variable in a single metaclass ?
Krzysztof
Christian W. Damus wrote:
> Hi, Krzysztof,
> integrated.
> Cheers,
> Christian
>> Hi All,
>> Regards,
>> Krzysztof
Re: VariableExp and "UMLVariable" [message #37874 is a reply to message #37779] Mon, 24 September 2007 09:53 Go to previous message
Hi, Krzysztof,
You can raise your issues with the OCL committee at the OMG. Other than
that, it would take a radical departure from the specification (and the
current API) to accomplish this.
I suppose you might try unifying the two metaclasses by implementing your
own variant of the org.eclipse.ocl.uml plug-in (using the same technique as
made the CollectionType extend Classifier, for example), but that probably
would require a lot of effort and I'm not sure of the feasibility. I don't
yet understand how you propose to use OCL in UML actions or activities.
AFAICT, the language simply isn't set up to work with Actions, unless there
are extensions in the Executable UML or something that I don't know about;
I'm not an expert.
Christian
> Hi Christian,
> Cheers,
> Krzysztof
>> Hi, Krzysztof,
>> integrated.
>> variables don't enter into it here.
>> Cheers,
>> Christian
>>> Hi All,
>>> Regards,
>>> Krzysztof
Previous Topic:[Announce] MDT OCL 1.2.0 I200709211125 is available
Next Topic:check an attribute
Current Time: Sat Jul 19 03:53:36 EDT 2025
Powered by FUDForum. Page generated in 0.24201 seconds
