Home » Modeling » MDT (Model Development Tools) » Problem while re-generating UML2Tools clazz diagram
Problem while re-generating UML2Tools clazz diagram [message #378632] Wed, 06 August 2008 08:12 Go to next message
for our project I want to make a customized version of the UML2Tools class
diagram. To start, I want to re-generate the clazz diagram from the
org.eclipse.uml2.diagram.def project. What I did was:
- import plug-in org.eclipse.uml2.diagram.def as a source project.
- started the UML2Tools generation by selecting the 'Generate UML2Tools
Diagram' option from the context menu of 'classdiagram.gmfgen'
- I have ignored the fact that the validation of the generator model did
not pass.
After a while, I get the following error:
Problems while generating code
Exception (Couldn't find operation
'hasConformableSemanticChildren(GenDiagram)' for GenDiagram.:in
aspects::xpt::diagram::updater::containerBaseCanonicalMethod s on line 40
'hasConformableSemanticChildren(this)') while generating code
Couldn't find operation 'hasConformableSemanticChildren(GenDiagram)' for
GenDiagram.:in
Additional info:
- I am working with Eclipse 3.4
- Downloaded the newest UML2Tools & GMF this morning.
Can someone please help me with this problem?
Kind regards,
Niels Brouwers.
Re: Problem while re-generating UML2Tools clazz diagram [message #378635 is a reply to message #378632] Fri, 08 August 2008 18:06 Go to previous messageGo to next message
Niels,
This is a question for the UML2 Tools newsgroup (copied).
Kenn
"Niels Brouwers" <n.brouwers@gmail.com> wrote in message
news:a599e32901f7110148da7349d211631c$1@www.eclipse.org...
> not pass.
> GenDiagram.:in
> Additional info:
> Kind regards,
> Niels Brouwers.
Re: Problem while re-generating UML2Tools clazz diagram [message #378637 is a reply to message #378635] Mon, 11 August 2008 10:09 Go to previous message
Hi Kenn,
I was already confused about where I had left this message? Apparently, I
have posted it in the wrong news group, for which I apologize.
For others: the cause of the problem was already found as explained in one
of the previous posts.
Kind regards,
Niels Brouwers.
Re: Problem while re-generating UML2Tools clazz diagram [message #593721 is a reply to message #378632] Fri, 08 August 2008 18:06 Go to previous message
Niels,
Kenn
> not pass.
> GenDiagram.:in
> Additional info:
> Kind regards,
> Niels Brouwers.
Re: Problem while re-generating UML2Tools clazz diagram [message #593774 is a reply to message #378635] Mon, 11 August 2008 10:09 Go to previous message
Hi Kenn,
Kind regards,
Niels Brouwers.
Previous Topic:Problem while re-generating UML2Tools clazz diagram
Next Topic:[OCLTools] Re: downloading MDT-OCLTools
Current Time: Fri Jul 25 06:57:56 EDT 2025
Powered by FUDForum. Page generated in 1.06259 seconds
