[TCS] Keywords [message #378502] |
Tue, 17 July 2007 07:34  |
Originally posted by: remi.viaux.mbda-systems.com
My problem is that I want to identify two distincts entities which begin
with the same identifier.
Here is the code I want to parse :
typedef type name;
typedef struct { ... } name;
(it's the C declaration of type of course)
Is it possible to use a keyword composed by 2 words in the template ?
because something like this doesn't work :
template Typedef
: "typedef" type name
template Struct
: "typedef struct" -- or "typedef" "struct"
type name
Those templates always recognize a single typedef element.
Thanks for the help.
Remi Viaux
Re: [TCS] Keywords [message #378510 is a reply to message #378506] |
Wed, 18 July 2007 05:28  |
Hi Frédéric,
"typedef" "struct" works !
I don't have any ambiguity warning from ANTLR.
Thanks.
Remi Viaux
Frédéric Jouault wrote:
> Hello,
> "typedef struct" is not valid, but "typedef" "struct" is.
> If you get no ambiguity warning from ANTLR then it should work.
> Can you please check whether you have such messages or not?
> Regards,
> Frédéric Jouault
> Remi Viaux wrote:
>> Hi,
>> with the same identifier. Here is the code I want to parse :
>> typedef type name;
>> template Typedef
>> template Struct
>> type name
>> Remi Viaux
Re: [TCS] Keywords [message #602311 is a reply to message #378502] |
Wed, 18 July 2007 05:05  |
Frédéric Jouault
Remi Viaux wrote:
> typedef type name;
> template Typedef
> template Struct
> type name
> Remi Viaux
Re: [TCS] Keywords [message #602328 is a reply to message #378506] |
Hi Frédéric,
Thanks.
Remi Viaux
> Hello,
> Regards,
> Frédéric Jouault
> Remi Viaux wrote:
>> Hi,
>> typedef type name;
>> template Typedef
>> template Struct
>> type name
>> Remi Viaux
FUDForum. Page generated in 0.04020 seconds
