Connect to the Resource [message #378356] |
Fri, 01 September 2006 03:36  |
Originally posted by: atoulme.intalio.com
I am trying to listen to the changes made to the sematic model behind
the GMF editor. I have noticed that the EMF resources can be listened,
and they can notify of the changes intervening in their elements when
isNotificationTrackerEnabled() is set to true.
Should I try to listen to the resource ? If so, where is the best place
to plug in ?
Maybe GMF provides a plugin extension point to do such things ?
Do you have any implementation of such a behaviour ?
Antoine Toulme
http://www.intalio.com
Re: Connect to the Resource [message #378358 is a reply to message #378357] |
Fri, 01 September 2006 11:08  |
Ed Merks wrote:
> Anoine,
> This is an EMF (or GMF question) so best to use that (those)
> newsgroup(s). The resource will only notify for direct changes to the
> getContents of that resource (or it's other direct features). You
> probably want to use something like an EContentAdapter, which you can
> attached to a resource, resource set, or EObject. It will listen to
> every object in the containment tree and will attach and removed itself
> as the content tree changes.
> Antoine Toulmé wrote:
>> Hi,
>> place to plug in ?
>> Regards
>> Antoine Toulme
ok moving to GMF. Sorry for the inconvenience.
Re: Connect to the Resource [message #579130 is a reply to message #378356] |
Fri, 01 September 2006 09:54  |
Anoine,
> place to plug in ?
> Regards
> Antoine Toulme
Re: Connect to the Resource [message #579166 is a reply to message #378357] |
Ed Merks wrote:
> Anoine,
>> Hi,
>> place to plug in ?
>> Regards
>> Antoine Toulme
FUDForum. Page generated in 0.03304 seconds
