Home » Modeling » Modeling (top-level project) » What class implements the context menu for.genmodel file?
What class implements the context menu for.genmodel file? [message #378354] Thu, 31 August 2006 17:24 Go to next message
I have a project that includes code generated from a .genmodel file.
Currently, I am opening the .genmodel file in an editor, then right-click on
the root node and select the "Generate All" context menu which generates
additional projects based on the model. I would like to automate this step
of generating the sources from the .genmodel file, but I'm not able to find
the code I need to invoke.
I've been digging through the plug-in registry for a while now and cannot
find the EMF plugin that implements this menu item. I would like to invoke
the code using an ANT script, but will be happy if I can do it from a Java
application.
Can someone point me at the code I need for this. I'll continue to search
the plugin registry, and EMF documentation.
Michael Giroux
Re: What class implements the context menu for.genmodel file? [message #378355 is a reply to message #378354] Thu, 31 August 2006 17:30 Go to previous message
Michael,
This question should be posted to the EMF newsgroup. (If you search that
newsgroup you should also be able to find previous posts on this subject.)
Kenn
"Michael Giroux" <michael.giroux@bull.com> wrote in message
news:ed7k21$uoj$1@utils.eclipse.org...
>on the root node and select the "Generate All" context menu which generates
> invoke the code using an ANT script, but will be happy if I can do it from
> a Java application.
> Thanks
> Michael Giroux
Re: What class implements the context menu for.genmodel file? [message #579067 is a reply to message #378354] Thu, 31 August 2006 17:30 Go to previous message
Michael,
Kenn
> a Java application.
> Thanks
> Michael Giroux
Previous Topic:What class implements the context menu for.genmodel file?
Next Topic:Connect to the Resource
Current Time: Wed Jul 23 11:44:12 EDT 2025
Powered by FUDForum. Page generated in 0.04223 seconds
