error at topcased [message #378349] |
Fri, 18 August 2006 08:57  |
Originally posted by: erelender.gmail.com
I design my metamodel using ecore and create the plugin using .genmodel
file.
It successfully creates the plugin. I copy the plugin to eclipse/plugins
folder. When i try to create a model from my plugin i get an error:
The selected wizard could not be started.
Reason:
plugin myproject was unable to load class
org.topcased.myproject.presentationmyprojectModelWizard.
i check the file and everything seems to be ok.
Any help is welcome, thank you
Re: error at topcased [message #378351 is a reply to message #378349] |
Fri, 18 August 2006 09:45  |
--------------040606050603020706000906
Ender,
This is more of an EMF newsgroup question. Did launching a runtime
workspace and running it there work correctly. Did you run eclipse.exe
-clean after you copied the new plugins into the plugin folder to
refresh the configuration? Probably your MANIFEST.MF has
Bundle-ClassPath: .
which means it will look in the root of the plugin for the .class
files. But they are built into the bin directory, which the runtime
workspace will use. You need to export the plugin to jar it and use it
that way...
> .genmodel file.
> eclipse/plugins folder. When i try to create a model from my plugin i
> get an error:
> Reason:
<html>
<head>
http-equiv="Content-Type">
</head>
Ender,<br>
<br>
Re: error at topcased [message #578941 is a reply to message #378349] |
Fri, 18 August 2006 09:33  |
You need to export the generated plugin before deploying it instead of
just copy it to the eclipse/plugins folder.
To export your project :
Right Click on the project > Export > Deployable Plugins and Fragments >
Finish
PS : you should use the Topcased user mailing list :
http://gforge.enseeiht.fr/mail/?group_id=7
> file.
> Reason:
David SCIAMMA
Expert Eclipse / Eclipse Expert
ANYWARE TECHNOLOGIES
Tel : + 33 (0)5.61.00.73.44
Fax : + 33 (0)5.61.00.51.46
http://www.anyware-tech.com
Re: error at topcased [message #578957 is a reply to message #378349] |
Ender,
Bundle-ClassPath: .
that way...
> .genmodel file.
> get an error:
> Reason:
<html>
<head>
</head>
Ender,<br>
<br>
FUDForum. Page generated in 0.04861 seconds
