Home » Archived » GMT (Generative Modeling Technologies) » [AM3] Which version of ATL needed?
[AM3] Which version of ATL needed? [message #378196] Fri, 15 June 2007 16:43 Go to next message
I've installed ATL and AM3 from cvs. ATL works fine. However, I can't
inject a km3 into ecore. When I select the operation from the context
menu on any km3 file I get the attached exception.
My understanding in that the ebnf injector is part of ATL but the km3
parser is part of AM3. Is there a problem using the latest versions from
cvs together? Do I need a certain old version of ATL to run the km3
injector?
Lutz
java.lang.NoSuchMethodError:
org.atl.engine.injectors.ebnf.EBNFInjector2.create(Ljava/lan g/String;ZZ)Lorg/eclipse/m2m/atl/engine/vm/nativelib/ASMMode lElement;
at org.atl.engine.injectors.ebnf.KM3Parser.metamodel(Unknown Source)
at org.atl.engine.injectors.ebnf.KM3Parser.main(Unknown Source)
at org.atl.engine.injectors.ebnf.ANTLR2Wrapper.parse(ANTLR2Wrap per.java:70)
at
org.atl.engine.injectors.ebnf.EBNFInjector2.performImportati on(EBNFInjector2.java:150)
at
org.atl.engine.injectors.ebnf.EBNFInjector2.performImportati on(EBNFInjector2.java:120)
at
org.atl.engine.injectors.ebnf.EBNFInjector2.performImportati on(EBNFInjector2.java:116)
at
org.eclipse.gmt.am3.dsls.km3.KM3Projector.getEMFKM3FromFile( KM3Projector.java:224)
at org.eclipse.gmt.am3.dsls.km3.actions.KM32Ecore$1.run(KM32Eco re.java:58)
Re: [AM3] Which version of ATL needed? [message #378198 is a reply to message #378196] Sat, 16 June 2007 15:08 Go to previous messageGo to next message
We are currently working on the ATL and AM3 parsers. The current CVS
HEAD is not guaranteed to work at all time.
However, the KM3 plugin has been updated yesterday, and should now work.
Frédéric Jouault
> injector?
> Lutz
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Re: [AM3] Which version of ATL needed? [message #378265 is a reply to message #378198] Wed, 20 June 2007 09:19 Go to previous message
I've updated from cvs and it works now.
- Lutz
Frédéric Jouault wrote:
> Hello,
> Regards,
> Frédéric Jouault
>> from cvs together? Do I need a certain old version of ATL to run the
>> km3 injector?
>> Thanks,
>> Lutz
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
Re: [AM3] Which version of ATL needed? [message #602003 is a reply to message #378196] Sat, 16 June 2007 15:08 Go to previous message
Frédéric Jouault
> injector?
> Lutz
> at
> at
> at
> at
> at
> at
Re: [AM3] Which version of ATL needed? [message #602064 is a reply to message #378198] Wed, 20 June 2007 09:19 Go to previous message
- Lutz
> Hello,
> Regards,
> Frédéric Jouault
>> km3 injector?
>> Thanks,
>> Lutz
>> at
>> at
>> at
>> at
>> at
>> at
Previous Topic:[TCS] TGE: Support for own languages
Next Topic:[Epsilon] Performance
Current Time: Sun Jul 20 17:30:39 EDT 2025
Powered by FUDForum. Page generated in 0.04552 seconds
