Home » Archived » GMT (Generative Modeling Technologies) » [TCS]About NullPointerException
[TCS]About NullPointerException [message #378183] Fri, 15 June 2007 05:01 Go to next message
Originally posted by: quentin.glineur.obeo.fr
After a successful build of my TCS file, the parsing generates a
NullPointerException. I am wondering what it can be due to ?
(there is no indeterminism)
trace :
org.atl.engine.repositories.emf4atl.ASMEMFModelElement.asm2E MF(ASMEMFModelElement.java:303)
org.atl.engine.repositories.emf4atl.ASMEMFModelElement.set(A SMEMFModelElement.java:223)
org.atl.engine.injectors.ebnf.EBNFInjector2.set(EBNFInjector 2.java:903)
org.atl.engine.injectors.ebnf.EBNFInjector2.set(EBNFInjector 2.java:442)
at org.atl.engine.injectors.ebnf.vbParser.my_Parameter(Unknown Source)
at org.atl.engine.injectors.ebnf.vbParser.my_Function(Unknown Source)
Quentin
Re: [TCS]About NullPointerException [message #378184 is a reply to message #378183] Fri, 15 June 2007 05:35 Go to previous messageGo to next message
Are you sure there is no syntactic or lexical error before this NPE?
You might want to check all consoles and error logs ;-).
My guess is that my_Parameter tries to initialize a property with a null
value, but I cannot tell why without seeing both the metamodel and TCS.
Frédéric Jouault
Quentin Glineur wrote:
> trace :
> Quentin
Re: [TCS]About NullPointerException [message #378186 is a reply to message #378184] Fri, 15 June 2007 07:13 Go to previous messageGo to next message
--------------060902090406040602000705
Hello again and thanks for your interest,
I did not find any error on any console I know. Then, to complete my
question I am providing an excerpt of the MM and the TCS. (It seems that
the token stream runs until the My_Parameter name.)
Quentin
____________________________________________________________ _________
KM3 :
class My_Function extends My_Feature {
attribute hasVisibility : Boolean;
attribute visibility[0-1] : VisibilityEnum;
attribute name : String;
reference parameters[*] ordered container : My_Parameter;
attribute return : String;
reference statements[1-*] ordered container : My_Statement;
class My_Parameter extends My_Data {
attribute isOptional : Boolean;
attribute hasQualifier : Boolean;
attribute qualifier[0-1] : QualifierEnum;
attribute hasType : Boolean;
attribute type[0-1] : String;
attribute hasInitialValue : Boolean;
enumeration QualifierEnum {
literal byRef;
literal byVal;
TCS :
template My_Function :
(hasVisibility ? visibility)
"Function"
name
parameters{separator = ","}
"As"
return
statements
"End Function"
template My_Parameter :
(isOptional ? "Optional")
(hasQualifier ? qualifier)
name
(hasType ? "As" type)
enumerationTemplate QualifierEnum auto :
#byval = "ByVal",
#byref = "ByRef"
Compilation output :
JARGeneration:
[antlr] ANTLR Parser Generator Version 2.7.5 (20050128)
1989-2005 jGuru.com
[javac] Compiling 1 source file
[javac] ----------
[javac] 1. WARNING in
D:\workspaces\3.2\workspace\TCSSample\bridgeLight\TCS\org\at l\engine\injectors\ebnf\myParser.java
(at line 5)
[javac] import antlr.TokenStreamIOException;
[javac] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^
[javac] The import antlr.TokenStreamIOException is never used
[javac] ----------
[javac] 2. WARNING in
(at line 6)
[javac] import antlr.ANTLRException;
[javac] The import antlr.ANTLRException is never used
[javac] ----------
[javac] 3. WARNING in
(at line 7)
[javac] import antlr.LLkParser;
[javac] The import antlr.LLkParser is never used
[javac] ----------
[javac] 4. WARNING in
(at line 12)
[javac] import antlr.MismatchedTokenException;
[javac] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
[javac] The import antlr.MismatchedTokenException is never used
[javac] ----------
[javac] 5. WARNING in
(at line 13)
[javac] import antlr.SemanticException;
[javac] The import antlr.SemanticException is never used
[javac] ----------
[javac] 5 problems (5 warnings)
[jar] Building jar:
D:\workspaces\3.2\workspace\TCSSample\bridgeLight\TCS\my-imp orter.jar
BUILD SUCCESSFUL
Total time: 2 seconds
Parsing output :
Fr
Re: [TCS]About NullPointerException [message #378187 is a reply to message #378186] Fri, 15 June 2007 07:33 Go to previous messageGo to next message
I am not sure where the problem is.
However, I noticed that you use:
Why not use isDefined?
(isDefined(visibility) ? visibility)
(isDefined(qualifier) ? qualifier)
(isDefined(type) ? "As" type)
I do not think this is the cause of the problem, but you might want to
make this change anyway ;-).
Please, report back when this is done.
Frédéric Jouault
> Quentin
> KM3 :
> literal byRef;
> literal byVal;
> TCS :
> "Function"
> name
> "As"
> return
> statements
> "End Function"
> name
> #byval = "ByVal",
> #byref = "ByRef"
> JARGeneration:
> 1989-2005 jGuru.com
> [javac] ----------
> (at line 5)
> [javac] ----------
> (at line 6)
> [javac] ----------
> (at line 7)
> [javac] ----------
> (at line 12)
> [javac] ----------
> (at line 13)
> [javac] ----------
> [jar] Building jar:
> BUILD SUCCESSFUL
> Parsing output :
> Frédéric Jouault a écrit :
>> Hello,
>> null value, but I cannot tell why without seeing both the metamodel
>> and TCS.
>> Regards,
>> Frédéric Jouault
>>> Hi,
>>> trace :
>>> at org.atl.engine.injectors.ebnf.Parser.my_Parameter(Unknown Source)
>>> at org.atl.engine.injectors.ebnf.Parser.my_Function(Unknown Source)
>>> Quentin
> Buildfile: D:\workspaces\3.2\workspace\TCSSample\bridgeLight\Injection\ build.xml
> injection:
> [am3.loadModel] Loading of model MM
> [am3.loadModel] Warning: 1:21-1:35: could not set location of M!<unnamed>, disabling further location settings.
> [am3.loadModel] java.lang.NullPointerException
> [am3.loadModel] at org.atl.engine.repositories.emf4atl.ASMEMFModelElement.asm2E MF(ASMEMFModelElement.java:303)
> [am3.loadModel] at org.atl.engine.repositories.emf4atl.ASMEMFModelElement.set(A SMEMFModelElement.java:223)
> [am3.loadModel] at org.atl.engine.injectors.ebnf.EBNFInjector2.set(EBNFInjector 2.java:903)
> [am3.loadModel] at org.atl.engine.injectors.ebnf.EBNFInjector2.set(EBNFInjector 2.java:442)
> [am3.loadModel] at org.atl.engine.injectors.ebnf.vbParser.my_Parameter(Unknown Source)
> [am3.loadModel] at org.atl.engine.injectors.ebnf.vbParser.my_Function(Unknown Source)
> [am3.loadModel] at org.atl.engine.injectors.ebnf.vbParser.my_Feature(Unknown Source)
> [am3.loadModel] at org.atl.engine.injectors.ebnf.vbParser.my_ContentElement(Unk nown Source)
> [am3.loadModel] at org.atl.engine.injectors.ebnf.vbParser.my_Content(Unknown Source)
> [am3.loadModel] at org.atl.engine.injectors.ebnf.vbParser.main(Unknown Source)
> [am3.loadModel] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> [am3.loadModel] at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
> [am3.loadModel] at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
> [am3.loadModel] at java.lang.reflect.Method.invoke(Unknown Source)
> [am3.loadModel] at org.atl.engine.injectors.ebnf.EBNFInjector2$ANTLR2Wrapper.pa rse(EBNFInjector2.java:145)
> [am3.loadModel] at org.atl.engine.injectors.ebnf.EBNFInjector2.performImportati on(EBNFInjector2.java:273)
> [am3.loadModel] at org.atl.engine.injectors.ebnf.EBNFInjector2.performImportati on(EBNFInjector2.java:243)
> [am3.loadModel] at org.atl.engine.injectors.ebnf.EBNFInjector2.performImportati on(EBNFInjector2.java:223)
> [am3.loadModel] at org.atl.engine.injectors.ebnf.EBNFInjector2.performImportati on(EBNFInjector2.java:205)
> [am3.loadModel] at org.atl.engine.injectors.ebnf.EBNFInjector2.inject(EBNFInjec tor2.java:188)
> [am3.loadModel] at org.eclipse.gmt.am3.tools.ant.toolkit.AM3AntToolKit.ebnfInje ction(AM3AntToolKit.java:235)
> [am3.loadModel] at org.eclipse.gmt.am3.tools.ant.toolkit.AM3AntToolKit.ebnfInje ction(AM3AntToolKit.java:252)
> [am3.loadModel] at org.eclipse.gmt.am3.tools.ant.toolkit.AM3AntToolKit.inject(A M3AntToolKit.java:260)
> [am3.loadModel] at org.eclipse.gmt.am3.tools.ant.tasks.LoadModelTask.execute(Lo adModelTask.java:53)
> [am3.loadModel] at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:275)
> [am3.loadModel] at org.apache.tools.ant.Task.perform(Task.java:364)
> [am3.loadModel] at org.apache.tools.ant.Target.execute(Target.java:341)
> [am3.loadModel] at org.apache.tools.ant.Target.performTasks(Target.java:369)
> [am3.loadModel] at org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1216)
> [am3.loadModel] at org.apache.tools.ant.Project.executeTarget(Project.java:1185 )
> [am3.loadModel] at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:40)
> [am3.loadModel] at org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.exe cuteTargets(EclipseDefaultExecutor.java:32)
> [am3.loadModel] at org.apache.tools.ant.Project.executeTargets(Project.java:106 8)
> [am3.loadModel] at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:706)
> [am3.loadModel] at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:457)
> [am3.loadModel] at org.eclipse.ant.core.AntRunner.run(AntRunner.java:356)
> [am3.loadModel] at org.eclipse.ant.internal.ui.launchConfigurations.AntLaunchDe legate$1.run(AntLaunchDelegate.java:230)
> [am3.loadModel] at java.lang.Thread.run(Unknown Source)
> [am3.saveModel] Saving model M
> BUILD SUCCESSFUL
> Total time: 297 milliseconds
Re: [TCS]About NullPointerException [message #378190 is a reply to message #378187] Fri, 15 June 2007 09:51 Go to previous messageGo to next message
Ok, I have tried what you suggested but it did not bring any enhancement.
Though I have noticed that the tag for My_Function is outside the
My_Content tag (as it should) i.e :
<?xml version="1.0" encoding="ISO-8859-1"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="obeo"
xmlns:_1="expressions" xmlns:_2="features">
<My_Content>
</My_Content>
<_2:My_Function visibility="public" name="add"/>
<_2:My_Parameter/>
</xmi:XMI>
If it could help your diagnostic...
Quentin
> Hello,
> Regards,
> Frédéric Jouault
>> that the token stream runs until the My_Parameter name.)
>> Quentin
>> KM3 :
>> literal byRef;
>> literal byVal;
>> TCS :
>> "Function"
>> name
>> "As"
>> return
>> statements
>> "End Function"
>> name
>> #byval = "ByVal",
>> #byref = "ByRef"
>> JARGeneration:
>> 1989-2005 jGuru.com
>> [javac] ----------
>> (at line 5)
>> [javac] ----------
>> (at line 6)
>> [javac] ----------
>> (at line 7)
>> [javac] ----------
>> (at line 12)
>> [javac] ----------
>> (at line 13)
>> [javac] ----------
>> [jar] Building jar:
>> BUILD SUCCESSFUL
>> Parsing output :
>>> Hello,
>>> and TCS.
>>> Regards,
>>> Frédéric Jouault
>>>> Hi,
>>>> trace :
>>>> Quentin
>> Buildfile:
>> injection:
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> BUILD SUCCESSFUL
Re: [TCS]About NullPointerException [message #378191 is a reply to message #378190] Fri, 15 June 2007 09:59 Go to previous messageGo to next message
The enhancement is that you can remove unnecessary Boolean attributes ;-).
> <My_Content>
> </My_Content>
> <_2:My_Parameter/>
> </xmi:XMI>
This is probably caused by the error, of which it is therefore a
symptom, not a cause.
Is it possible for you to package your KM3 metamodel, TCS model, and at
least a sample and post it here, so that I can try to reproduce the problem?
Frédéric Jouault
Re: [TCS]About NullPointerException [message #378192 is a reply to message #378191] Fri, 15 June 2007 10:21 Go to previous messageGo to next message
--------------070902080003070704040908
Here it comes !
As a matter of fact, the KM3 and the TCS have been gotten by generation
hence their form.
The test file is adapted from one of the melon project.
Quentin
Fr
Re: [TCS]About NullPointerException [message #378195 is a reply to message #378192] Fri, 15 June 2007 14:57 Go to previous messageGo to next message
Your problem is that the byRef and byVal enumeration literals are
spelled byref and byval in the TCS. This is strange for a generated file
Checking for this kind of problem is already in the TODO list for the
TCS2Problem transformation.
Another problem I discovered: you should use "End" "Function" not "End
Function", because End and Function are two separate keywords.
You might also be interested in the VB zoo, which uses a VisualBasic
metamodel and TCS:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gmt/AM3 /org.eclipse.am3.zoos.atlanticVB/build/?root=Technology_Proj ect
Frédéric Jouault
> Here it comes !
> hence their form.
> Regards,
> Quentin
>> Hello,
>> enhancement.
>> > <My_Content>
>> > </My_Content>
>> > <_2:My_Parameter/>
>> > </xmi:XMI>
>> at least a sample and post it here, so that I can try to reproduce the
>> problem?
>> Regards,
>> Frédéric Jouault
> package PrimitiveTypes {
> datatype String;
> datatype Boolean;
> datatype Integer;
> package fr {
> package obeo {
> abstract class My_LangElement {
> attribute comment[0-1] : String;
> attribute endLineComment[0-1] : String;
> attribute naming[0-1] : String;
> attribute elementId[0-1] : String;
> attribute write : String;
> reference typing[0-1] : My_LangElement;
> reference crossReferences[*] ordered : My_LangElement;
> class My_Content extends My_LangElement {
> reference elements[*] ordered container : My_ContentElement;
> abstract class My_ContentElement extends My_LangElement {
> class My_FileAttribute extends My_ContentElement {
> reference initialValue[1-*] ordered container : My_Expression;
> class My_Option extends My_ContentElement {
> attribute hasEnablement : Boolean;
> attribute enablement[0-1] : EnablementEnum;
> abstract class My_Data {
> package features {
> abstract class My_Feature extends My_Data, My_ContentElement {
> -- attribute hasVisibility : Boolean;
> -- attribute hasQualifier : Boolean;
> -- attribute hasType : Boolean;
> package statements {
> abstract class My_Modifier extends My_LangElement {
> abstract class My_Statement extends My_Modifier {
> class My_RawBody extends My_Statement {
> attribute value[0-1] : String;
> package expressions {
> abstract class My_Expression extends My_LangElement {
> class My_NegativeExpression extends My_Expression {
> reference expression container : My_Expression;
> abstract class My_Value extends My_Expression {
> abstract class My_Literal extends My_Value {
> class My_Literal_Literal extends My_Literal {
> attribute value : String;
> class My_Literal_Number extends My_Literal {
> class My_Literal_Value extends My_Literal {
> package enumerations {
> enumeration EnablementEnum {
> literal Off;
> literal On;
> enumeration VisibilityEnum {
> literal private;
> literal protected;
> literal public;
> literal byRef;
> literal byVal;
> syntax vb {
> primitiveTemplate numberSymbol for String using NUMBER_PATTERN :
> value = "%token%";
> primitiveTemplate identifierSymbol for String default using IDENTIFIER_PATTERN :
> value = "%token%";
> primitiveTemplate literalSymbol for String using LITERAL_PATTERN :
> value = "%token%";
> primitiveTemplate valueSymbol for String using VALUE_PATTERN :
> value = "%token%";
> primitiveTemplate bodySymbol for String using BODY :
> value = "%token%";
> template My_Content main :
> elements
> template My_ContentElement abstract
> template My_FileAttribute :
> "Attribute"
> name
> initialValue{separator = ","}
> template My_Option :
> "Option"
> name
> (isDefined(enablement) ? enablement)
> template My_Feature abstract
> template My_Data abstract
> template My_RawBody :
> value{as = bodySymbol}
> "Function" name "(" parameters{separator = ","} ")" "As" return statements "End Function"
> name
> template My_Statement abstract
> template My_Expression abstract
> template My_Value abstract
> template My_Literal abstract
> template My_Literal_Literal :
> value{as = literalSymbol}
> enumerationTemplate EnablementEnum auto :
> #off = "Off",
> #on = "On"
> enumerationTemplate VisibilityEnum auto :
> #public = "Public",
> #protected = "Protected",
> #private = "Private"
> #byval = "ByVal",
> #byref = "ByRef"
> symbols {
> parenthesisBegin = "(";
> parenthesisEnd = ")";
> coma = ",";
> dot = ".";
> eq = "=";
> lexer = "
> class vbLexer extends Lexer;
> options {
> k = 5;
> charVocabulary = '\\0' .. '\\u00FF';
> testLiterals = false;
> protected Token makeToken(int t) {
> org.atl.engine.injectors.ebnf.LocationToken ret = null;
> tokenObjectClass = org.atl.engine.injectors.ebnf.LocationToken.class;
> ret = (org.atl.engine.injectors.ebnf.LocationToken)super.makeToken (t);
> ret.setEndLine(getLine());
> ret.setEndColumn(getColumn());
> return ret;
> protected
> NL
> : ( '\\r' '\\n'
> | '\\r'
> | '\\n'
> {newline();}
> WS
> | '\\t'
> | NL
> { $setType(Token.SKIP); }
> COMMENT
> (~( '\\r'|'\\n'))*
> NUMBER_PATTERN
> : (NUMBER_REGEX)
> IDENTIFIER_PATTERN options{testLiterals=true;}
> : (IDENTIFIER_REGEX)
> LITERAL_PATTERN
> : (LITERAL_REGEX)
> VALUE_PATTERN
> : ( EVAL_REGEX | DATE_REGEX)
> protected NUMBER_REGEX
> : ('0'..'9')+
> ('.' ('0'..'9')+)?
> {System.out.println(\"Number : \" + $getText);}
> protected ALPHA
> : 'a'..'z'
> | 'A'..'Z'
> //For Unicode compatibility (from 0000 to 00ff)
> | '\\u00C0' .. '\\u00D6'
> | '\\u00D8' .. '\\u00F6'
> | '\\u00F8' .. '\\u00FF'
> protected
> DIGIT
> : '0'..'9'
> protected IDENTIFIER_CHAR
> : ('_' | ALPHA | DIGIT | '&')
> protected UNDERSCORED_CHAR
> : '_' IDENTIFIER_CHAR
> protected IDENTIFIER_REGEX
> : (ALPHA | UNDERSCORED_CHAR)
> (IDENTIFIER_CHAR)*
> {System.out.println(\"Identifier : \" + $getText);}
> protected EVAL_REGEX
> : '&'(ALPHA)+('&')?
> protected DATE_REGEX
> : '#' (DIGIT '/')+ '#'
> protected LITERAL_REGEX
> {System.out.println(\"Literal : \" + $getText);}
> BODY
> : ('$'(options{greedy=false;}:('\\n' {newline();}| ~ '\\n'))* '$')
> {System.out.println(\"Body : \" + $getText);}
> Attribute VB_Name = "mMelonCtls_i"
> Option Explicit
> Public Function g_ControlSetValue(ByRef Control As MControl, ByVal Value As Long) As Boolean
> If (Control Is Nothing) Then _
> Exit Function
> Control.Value = Value
> g_ControlSetValue = True
> End Function
> Public Function g_ControlGetValue(ByRef Control As MControl, ByRef Value As Long) As Boolean
> Exit Function
> Value = Control.Value
> g_ControlGetValue = True
> End Function
> Public Function g_SliderInit(ByRef Slider As MControl, Optional ByVal Min As Long, Optional ByVal Max As Long, Optional ByVal Value As Long) As Boolean
> If (Slider Is Nothing) Then _
> Exit Function
> On Error Resume Next
> Dim ps As CSlider
> Err.Clear
> Set ps = Slider
> If Err.Number = 0 Then
> If Min <> -1 Then _
> ps.Min = Min
> If Max <> -1 Then _
> ps.Max = Max
> If Value <> -1 Then _
> ps.Value = Value
> g_SliderInit = True
> End If
> End Function
Re: [TCS]About NullPointerException [message #378260 is a reply to message #378195] Mon, 18 June 2007 04:24 Go to previous messageGo to next message
> Hello,
Yet, you are right, this is one of the only piece of my code that are
still handcrafted !
Great ! As a grain of sand, it has been jamming my work for quite long
time without being quickly identifiable: so thanks for your help !
Ok, this one is now fixed.
> metamodel and TCS:
Thanks a lot, I will use it as inspiration !
Quentin
> Best regards,
> Frédéric Jouault
>> Here it comes !
>> generation hence their form.
>> Regards,
>> Quentin
>>> Hello,
>>> enhancement.
>>> > <My_Content>
>>> > </My_Content>
>>> > <_2:My_Parameter/>
>>> > </xmi:XMI>
>>> the problem?
>>> Regards,
>>> Frédéric Jouault
>> datatype String;
>> datatype Boolean;
>> datatype Integer;
>> package fr {
>> package obeo {
>> package features {
>> literal Off;
>> literal On;
>> literal private;
>> literal protected;
>> literal public;
>> literal byRef;
>> literal byVal;
>> syntax vb {
>> value = "%token%";
>> value = "%token%";
>> value = "%token%";
>> value = "%token%";
>> value = "%token%";
>> elements
>> template My_ContentElement abstract ;
>> "Attribute"
>> name
>> "Option"
>> name
>> template My_Feature abstract ;
>> template My_Data abstract ;
>> (isDefined(qualifier) ? qualifier) name
>> template My_Statement abstract ;
>> template My_Value abstract ;
>> #off = "Off",
>> #on = "On"
>> #public = "Public",
>> #byval = "ByVal",
>> #byref = "ByRef"
>> symbols {
>> coma = ",";
>> dot = ".";
>> eq = "=";
>> lexer = "
>> options {
>> k = 5;
>> tokenObjectClass =
>> ret =
>> return ret;
>> protected
>> NL
>> : ( '\\r' '\\n'
>> | '\\r'
>> | '\\n'
>> {newline();}
>> WS
>> | '\\t'
>> | NL
>> COMMENT
>> (~( '\\r'|'\\n'))*
>> NUMBER_PATTERN
>> : (NUMBER_REGEX)
>> LITERAL_PATTERN
>> : (LITERAL_REGEX)
>> VALUE_PATTERN
>> : ('0'..'9')+
>> ('.' ('0'..'9')+)?
>> protected ALPHA
>> : 'a'..'z'
>> | 'A'..'Z'
>> protected
>> DIGIT
>> : '0'..'9'
>> (IDENTIFIER_CHAR)*
>> : '&'(ALPHA)+('&')?
>> BODY
>> Option Explicit
>> Exit Function
>> End Function
>> Exit Function
>> End Function
>> As Boolean
>> Exit Function
>> Dim ps As CSlider
>> Err.Clear
>> Set ps = Slider
>> If Min <> -1 Then _
>> ps.Min = Min
>> If Max <> -1 Then _
>> ps.Max = Max
>> ps.Value = Value
>> g_SliderInit = True
>> End If
>> End Function
Re: [TCS]About NullPointerException [message #378515 is a reply to message #378260] Thu, 19 July 2007 10:25 Go to previous messageGo to next message
Originally posted by: remi.viaux.mbda-systems.com
Hi Quentin,
Regenerate the ecore metamodel from you're km3 metamodel.
I had the same error that you Null pointer exception, and I had just
modified km3 file and forget to udate the ecore one.
After the regeneration, no more error appears
It's maybe another problem that you have, but just try ; it's easy to
check ^^
Remi Viaux
Re: [TCS]About NullPointerException [message #378517 is a reply to message #378515] Thu, 19 July 2007 11:13 Go to previous message
--------------080607090607080802030600
Hi Remi,
I am sorry but I do not understand your post :-/
If you are trying to get an injector from the files I have posted, be
sure to fix them the way Frederic told (i.e. correct the literal names
(byRef, byVal) either in KM3 or in TCS).
Quentin GLINEUR
Remi Viaux a
Re: [TCS]About NullPointerException [message #601879 is a reply to message #378183] Fri, 15 June 2007 05:35 Go to previous message
Frédéric Jouault
> trace :
> Quentin
Re: [TCS]About NullPointerException [message #601904 is a reply to message #378184] Fri, 15 June 2007 07:13 Go to previous message
Quentin
KM3 :
literal byRef;
literal byVal;
TCS :
"Function"
name
"As"
return
statements
"End Function"
name
#byval = "ByVal",
#byref = "ByRef"
JARGeneration:
1989-2005 jGuru.com
[javac] ----------
(at line 5)
[javac] ----------
(at line 6)
[javac] ----------
(at line 7)
[javac] ----------
(at line 12)
[javac] ----------
(at line 13)
[javac] ----------
[jar] Building jar:
BUILD SUCCESSFUL
Parsing output :
Fr
Re: [TCS]About NullPointerException [message #601910 is a reply to message #378186] Fri, 15 June 2007 07:33 Go to previous message
Frédéric Jouault
> Quentin
> KM3 :
> literal byRef;
> literal byVal;
> TCS :
> "Function"
> name
> "As"
> return
> statements
> "End Function"
> name
> #byval = "ByVal",
> #byref = "ByRef"
> JARGeneration:
> 1989-2005 jGuru.com
> [javac] ----------
> (at line 5)
> [javac] ----------
> (at line 6)
> [javac] ----------
> (at line 7)
> [javac] ----------
> (at line 12)
> [javac] ----------
> (at line 13)
> [javac] ----------
> [jar] Building jar:
> BUILD SUCCESSFUL
> Parsing output :
>> Hello,
>> and TCS.
>> Regards,
>> Frédéric Jouault
>>> Hi,
>>> trace :
>>> Quentin
> injection:
> BUILD SUCCESSFUL
Re: [TCS]About NullPointerException [message #601939 is a reply to message #378187] Fri, 15 June 2007 09:51 Go to previous message
<My_Content>
</My_Content>
<_2:My_Parameter/>
</xmi:XMI>
Quentin
> Hello,
> Regards,
> Frédéric Jouault
>> Quentin
>> KM3 :
>> literal byRef;
>> literal byVal;
>> TCS :
>> "Function"
>> name
>> "As"
>> return
>> statements
>> "End Function"
>> name
>> #byval = "ByVal",
>> #byref = "ByRef"
>> JARGeneration:
>> 1989-2005 jGuru.com
>> [javac] ----------
>> (at line 5)
>> [javac] ----------
>> (at line 6)
>> [javac] ----------
>> (at line 7)
>> [javac] ----------
>> (at line 12)
>> [javac] ----------
>> (at line 13)
>> [javac] ----------
>> [jar] Building jar:
>> BUILD SUCCESSFUL
>> Parsing output :
>>> Hello,
>>> and TCS.
>>> Regards,
>>> Frédéric Jouault
>>>> Hi,
>>>> trace :
>>>> Quentin
>> Buildfile:
>> injection:
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> BUILD SUCCESSFUL
Re: [TCS]About NullPointerException [message #601943 is a reply to message #378190] Fri, 15 June 2007 09:59 Go to previous message
> <My_Content>
> </My_Content>
> <_2:My_Parameter/>
> </xmi:XMI>
Frédéric Jouault
Re: [TCS]About NullPointerException [message #601954 is a reply to message #378191] Fri, 15 June 2007 10:21 Go to previous message
Here it comes !
hence their form.
Quentin
Fr
Re: [TCS]About NullPointerException [message #601980 is a reply to message #378192] Fri, 15 June 2007 14:57 Go to previous message
metamodel and TCS:
Frédéric Jouault
> Here it comes !
> hence their form.
> Regards,
> Quentin
>> Hello,
>> enhancement.
>> > <My_Content>
>> > </My_Content>
>> > <_2:My_Parameter/>
>> > </xmi:XMI>
>> problem?
>> Regards,
>> Frédéric Jouault
> datatype String;
> datatype Boolean;
> datatype Integer;
> package fr {
> package obeo {
> package features {
> literal Off;
> literal On;
> literal private;
> literal protected;
> literal public;
> literal byRef;
> literal byVal;
> syntax vb {
> value = "%token%";
> value = "%token%";
> value = "%token%";
> value = "%token%";
> value = "%token%";
> elements
> "Attribute"
> name
> "Option"
> name
> name
> #off = "Off",
> #on = "On"
> #public = "Public",
> #byval = "ByVal",
> #byref = "ByRef"
> symbols {
> coma = ",";
> dot = ".";
> eq = "=";
> lexer = "
> options {
> k = 5;
> return ret;
> protected
> NL
> : ( '\\r' '\\n'
> | '\\r'
> | '\\n'
> {newline();}
> WS
> | '\\t'
> | NL
> COMMENT
> (~( '\\r'|'\\n'))*
> NUMBER_PATTERN
> : (NUMBER_REGEX)
> LITERAL_PATTERN
> : (LITERAL_REGEX)
> VALUE_PATTERN
> : ('0'..'9')+
> ('.' ('0'..'9')+)?
> protected ALPHA
> : 'a'..'z'
> | 'A'..'Z'
> protected
> DIGIT
> : '0'..'9'
> (IDENTIFIER_CHAR)*
> : '&'(ALPHA)+('&')?
> BODY
> Option Explicit
> Exit Function
> End Function
> Exit Function
> End Function
> Exit Function
> Dim ps As CSlider
> Err.Clear
> Set ps = Slider
> If Min <> -1 Then _
> ps.Min = Min
> If Max <> -1 Then _
> ps.Max = Max
> ps.Value = Value
> g_SliderInit = True
> End If
> End Function
Re: [TCS]About NullPointerException [message #602020 is a reply to message #378195] Mon, 18 June 2007 04:24 Go to previous message
> Hello,
still handcrafted !
> metamodel and TCS:
Quentin
> Best regards,
> Frédéric Jouault
>> Here it comes !
>> Regards,
>> Quentin
>>> Hello,
>>> enhancement.
>>> > <My_Content>
>>> > </My_Content>
>>> > <_2:My_Parameter/>
>>> > </xmi:XMI>
>>> the problem?
>>> Regards,
>>> Frédéric Jouault
>> datatype String;
>> datatype Boolean;
>> datatype Integer;
>> package fr {
>> package obeo {
>> package features {
>> literal Off;
>> literal On;
>> literal private;
>> literal protected;
>> literal public;
>> literal byRef;
>> literal byVal;
>> syntax vb {
>> value = "%token%";
>> value = "%token%";
>> value = "%token%";
>> value = "%token%";
>> value = "%token%";
>> elements
>> "Attribute"
>> name
>> "Option"
>> name
>> #off = "Off",
>> #on = "On"
>> #public = "Public",
>> #byval = "ByVal",
>> #byref = "ByRef"
>> symbols {
>> coma = ",";
>> dot = ".";
>> eq = "=";
>> lexer = "
>> options {
>> k = 5;
>> tokenObjectClass =
>> ret =
>> return ret;
>> protected
>> NL
>> : ( '\\r' '\\n'
>> | '\\r'
>> | '\\n'
>> {newline();}
>> WS
>> | '\\t'
>> | NL
>> COMMENT
>> (~( '\\r'|'\\n'))*
>> NUMBER_PATTERN
>> : (NUMBER_REGEX)
>> LITERAL_PATTERN
>> : (LITERAL_REGEX)
>> VALUE_PATTERN
>> : ('0'..'9')+
>> ('.' ('0'..'9')+)?
>> protected ALPHA
>> : 'a'..'z'
>> | 'A'..'Z'
>> protected
>> DIGIT
>> : '0'..'9'
>> (IDENTIFIER_CHAR)*
>> : '&'(ALPHA)+('&')?
>> BODY
>> Option Explicit
>> Exit Function
>> End Function
>> Exit Function
>> End Function
>> As Boolean
>> Exit Function
>> Dim ps As CSlider
>> Err.Clear
>> Set ps = Slider
>> If Min <> -1 Then _
>> ps.Min = Min
>> If Max <> -1 Then _
>> ps.Max = Max
>> ps.Value = Value
>> g_SliderInit = True
>> End If
>> End Function
Re: [TCS]About NullPointerException [message #602715 is a reply to message #378260] Thu, 19 July 2007 10:25 Go to previous message
Hi Quentin,
check ^^
Remi Viaux
Re: [TCS]About NullPointerException [message #602721 is a reply to message #378515] Thu, 19 July 2007 11:13 Go to previous message
Hi Remi,
Quentin GLINEUR
Remi Viaux a
Previous Topic:[TCS] Keywords
Next Topic:[AM3] ATL projector - comments
Current Time: Thu Sep 04 10:18:46 EDT 2025
Powered by FUDForum. Page generated in 0.32130 seconds
