Home » Archived » GMT (Generative Modeling Technologies) » [TCS] Best practices
[TCS] Best practices [message #378134] Thu, 14 June 2007 04:28 Go to next message
Originally posted by: quentin.glineur.obeo.fr
Working with a base metamodel, I am trying to express its concrete
syntax in TCS (using the TCSToolkit). As several classes in this
metamodel have their textual representation starting with the same
tokens, this leads to grammar ambiguity.
So I would like to know, according to you, what is the best way to lift
this ambiguity (adapting the metamodel by adding factoring classes ? or
whatever...)
Quentin
PS : to be sure to be up to date, I looked at my TCSToolkit version. (It
is said that TCS2ANTLR was last modified on February 26 2007 21:35:00)
Does it exist an updated version and/or a cvs repository for it ?
Re: [TCS] Best practices [message #378180 is a reply to message #378134] Thu, 14 June 2007 05:23 Go to previous message
> whatever...)
The simplest way, is to increase k (in LL(k)). However, this will only
work if the ambiguities can be lifted with a fixed lookahead.
syntax MyLanguage(k = <the value you want for k (3 is not specified)>) {
Then, you may use disambiguate = "..." to add syntactic predicates
(http://antlr2.org/doc/metalang.html#SyntacticPredicates), which enable
arbitrary lookahead.
template Test (disambiguate = "...")
A simple way to find a working predicate, although it is not minimal, is
to use the whole rule itself:
template Test (disambiguate = "test")
Another solution is to wait for the new version of TCS that will support
ANTLR 3.0 and the LL(*) algorithm, which enables arbitrary lookahead and
automatic backtracking ;-).
There is no newer version available yet.
Frédéric Jouault
Re: [TCS] Best practices [message #601851 is a reply to message #378134] Thu, 14 June 2007 05:23 Go to previous message
> whatever...)
Frédéric Jouault
Previous Topic:[TCS] Best practices
Next Topic:[oaw:xtend] Editor complains when using 2 stdlibextensions
Current Time: Wed Jul 23 00:46:52 EDT 2025
Powered by FUDForum. Page generated in 0.06145 seconds
