Re: [TCS] Case sensitive keywords [message #378124 is a reply to message #378122] |
Wed, 13 June 2007 06:28  |
>> By the way, the TCS extractor already supports case insensitive
>> keywords via its kwCheckIgnoreCase parameter.
> Is it a parameter for the ant file i guess ?
It is a parameter of the TCS extractor.
You can use it in an ant file, or programmatically.
> Does it works for an injector ?
It is a parameter of the TCS *extractor* ;-).
Frédéric Jouault
Re: [TCS] Case sensitive keywords [message #601795 is a reply to message #378112] |
Wed, 13 June 2007 05:57  |
I've add the option caseSensitive=false in the lexer option in the tcs
file.
The jar build works well but when parsing a file, it still remains error
if there is different case sensitivity.
I'll look closer to ANTLR to see how i can fix it.
Re: [TCS] Case sensitive keywords [message #601801 is a reply to message #378118] |
Wed, 13 June 2007 06:08  |
> file.
Ok.
By the way, the TCS extractor already supports case insensitive keywords
Frédéric Jouault
Re: [TCS] Case sensitive keywords [message #601813 is a reply to message #378122] |
Frédéric Jouault
FUDForum. Page generated in 0.04263 seconds
