Home » Archived » GMT (Generative Modeling Technologies) » [TCS] Strange xsi:type tag value prefix
[TCS] Strange xsi:type tag value prefix [message #378073] Thu, 07 June 2007 07:20 Go to next message
Originally posted by: quentin.glineur.obeo.fr
When I do my TCS injection, I get a result file in which some tag have
their xsi:type attribute value prefixed with "_1", "_2" or any
underscored number.
example :
<elements xsi:type="Option" name="Explicit"/>
<elements xsi:type="_2:Function" hasVisibility="true"/>
<elements xsi:type="_2:Attribute" name="gm_newfont">
<elements xsi:type="_2:Attribute" name="Typeface" hasType="true">
<type xsi:type="_3:FullRef">
</type>
</elements>
Do anybody knows the reason and/or the way to fix it ?
Quentin
Re: [TCS] Strange xsi:type tag value prefix [message #378074 is a reply to message #378073] Thu, 07 June 2007 09:28 Go to previous messageGo to next message
> underscored number.
> example :
> </type>
> </elements>
The reason why you have the _1 and _2 prefixes is that EMF uses this
kind of prefix when no nsPrefix is defined for the Package containing a
given type.
Firstly, this is *not* a bug in TCS or EMF.
XMI is mostly about being able to read back a model that has been
previously written. This means that you rarely need to tune it. One
uncommon case in which you may need to tune it is when you want to make
it compatible with another XMI tool.
However, many users want to tune the XMI output even when it is not
necessary. Others believe their models are incorrect because they, in
fact, do not understand XMI (which is indeed sometimes confusing). For
these reasons, I wish the default format of Model Engineering was not
XML-based but some kind of binary format nobody would care to look into ;-D.
Sorry for repeating this again and again (I should definitely put this
in the FAQ). I do not mean to state that you do not have a reason (even
for cosmetics) to want to tune your XMI output. However, I would really
like everybody to understand that it is usually not necessary ;-).
If you need to have different prefixes, then you may consider that this
is a bug in your metamodel (i.e., lack of nsPrefix).
If you designed you metamodel with KM3, you may add the following
comment before the Package definition to set the nsPrefix:
-- @nsPrefix somePrefix
But, before doing this, you should consider whether you really need it
or not :-).
Frédéric Jouault
Re: [TCS] Strange xsi:type tag value prefix [message #378075 is a reply to message #378074] Thu, 07 June 2007 10:30 Go to previous message
Frédéric Jouault a écrit :
> Hello,
> > underscored number.
> > example :
> > </type>
> > </elements>
> given type.
OK, I had even not noticed the xmlns definition (shamefully)
Many thanks !
> ;-D.
In fact, as I am performing prototypes of TCS files, I use the result
checking as a test for conformity. So XML output is definitively a good
choice in there ;-D
Of course ;-D
> or not :-).
Definitively not !
> Best regards,
> Frédéric Jouault
Regards, Quentin
Re: [TCS] Strange xsi:type tag value prefix [message #601655 is a reply to message #378073] Thu, 07 June 2007 09:28 Go to previous message
> underscored number.
> example :
> </type>
> </elements>
given type.
or not :-).
Frédéric Jouault
Re: [TCS] Strange xsi:type tag value prefix [message #601663 is a reply to message #378074] Thu, 07 June 2007 10:30 Go to previous message
> Hello,
> > underscored number.
> > example :
> > </type>
> > </elements>
> given type.
Many thanks !
> ;-D.
choice in there ;-D
Of course ;-D
> or not :-).
Definitively not !
> Best regards,
> Frédéric Jouault
Regards, Quentin
Previous Topic:[TCS] Strange xsi:type tag value prefix
Next Topic:Connecting DSL-eCore w/ UML2
Current Time: Wed Jul 23 08:52:03 EDT 2025
Powered by FUDForum. Page generated in 0.05080 seconds
