Home » Archived » Test and Performance Tools Platform (TPTP) » Test automation
Test automation [message #37695] Wed, 26 October 2005 09:57 Go to next message
Originally posted by: aparasur.ugs.com
I have written JUnit test cases for my plug-ins. I want to be able to run
these tests on a nightly basis. I was looking at the "Build and Test
Automation for plug-ins and features" article
( http://www.eclipse.org/articles/Article-PDE-Automation/autom ation.html)
that describes how to build and test plug-ins.
Since TPTP provides additional features like profiling, I would like to
leverage TPTP to perform testing and profiling. Is it possible to invoke
TPTP tests and profiling from the command line? I can then schedule them
nightly using the Windows scheduler. I couldn't find any tutorials or guides
to do this in a non-interactive manner.
I am trying to figure out if it is possible to use the TPTP framework from
the command line or if I need to revert to following the "Build and Test
Automation for plug-ins and features" article.
Thanks in advance.
-Arvind
Re: Test automation [message #37802 is a reply to message #37695] Thu, 27 October 2005 11:09 Go to previous messageGo to next message
In TPTP4.1 a new feature was included to allow users to launch test suites
via light weight clients (such as ant scripts or shell scripts). This is
expalined under the following help content:
'TPTP Tester guide > JUnit testing with TPTP > Testing JUnit Plug-ins with
TPTP > Launching tests from scripts and applications".
If you also extract the following plugin from TPTP's cvs:
Platform/org.eclipse.hyades.execution you'll see an ant script example
under: src-automation-client\org.eclipse.hyades.automation.tests\te st.xml.
You can also run the profiling agent in stand alone mode using the extension
flag:
-XrunpiAgent:server=standalone. See the following help content:
"Monitoring and analyzing performance > Monitoring and analyzing application
performance > Profiling an application > Profiling an application in
stand-alone mode"
Hope that helps.
"Arvind Parasuram" <aparasur@ugs.com> wrote in message
news:djo201$han$1@news.eclipse.org...
guides
> Thanks in advance.
> -Arvind
Re: Test automation [message #37896 is a reply to message #37802] Thu, 27 October 2005 18:07 Go to previous messageGo to next message
Ali,
Thanks for replying. I downloaded the TPTP 4.1 version but I can't find the
help content that you are referring to. Am I missing something?
Thanks.
-Arvind
"Ali Mehregani" <amehrega@ca.ibm.com> wrote in message
news:djqqeq$46g$1@news.eclipse.org...
> under:
> extension
> flag:
> application
> stand-alone mode"
> Hope that helps.
>> Hi,
> guides
>> from
>> Thanks in advance.
>> -Arvind
Re: Test automation [message #37930 is a reply to message #37896] Thu, 27 October 2005 22:25 Go to previous message
The test automation document may not have made it in our 4.1 stable build.
You may have to go with a development build.
news:djrj2g$620$1@news.eclipse.org...
> Ali,
the
> Thanks.
> -Arvind
suites
is
with
> > under:
> > extension
> > flag:
> > application
> > stand-alone mode"
> > Hope that helps.
> >> Hi,
run
invoke
them
> > guides
> >> from
Test
> >> Thanks in advance.
> >> -Arvind
Previous Topic:Setting up a local site for Eclipse update
Next Topic:TRCAXMI FILE
Current Time: Fri Jul 18 16:44:29 EDT 2025
Powered by FUDForum. Page generated in 0.07185 seconds
