Home » Eclipse Projects » Subversive » trunk dir inside branch
trunk dir inside branch [message #37370] |
Thu, 13 November 2008 04:00  |
Previously I have been using Subclipse for connection to Subversion in
Eclipse, however to be honest I don't find it a very friendly or helpful
interface/tool. Therefore I decided to see what else was available and
came across Subversive, and I have to say it looks better, seems a little
faster, and generally nicer to user.
However, I have a problem.....
I removed Subclipse and installed Subversive, then checked out my project
afresh using the Find/Checkout As option to use the project wizard.
Everythings fine. However when I try and create a branch, everything
completes correctly, but if I view the repository, inside branch directory
is a directory with my branch name, but inside that rather than seeing
project, there is a directory called trunk, and the project is inside that.
Any ideas?
Re: trunk dir inside branch [message #37438 is a reply to message #37370] |
Thu, 13 November 2008 05:24   |
Hello Tom,
Could you please provide following info:
1. Your repository sctructure, e.g.
[Root]/
trunk/
branches/
foo-1/
foo-2/
trunk
[project]
where [project] is interesting project.
2. How do you call Branch action e.g. from Package Explorer, Synchronize
View, SVN Repositories View etc.?
3. What exactly do you fill in Branch field in "Create Branch" dialog, e.g.
"my_branch_1"?
> that.
> Any ideas?
Re: trunk dir inside branch [message #37784 is a reply to message #37370] |
Fri, 14 November 2008 03:02   |
> little faster, and generally nicer to user.
> project afresh using the Find/Checkout As option to use the project
> wizard. Everythings fine. However when I try and create a branch,
> everything completes correctly, but if I view the repository, inside
> branch directory is a directory with my branch name, but inside that
> rather than seeing project, there is a directory called trunk, and the
> Any ideas?
Might this be related to https://bugs.eclipse.org/246268? That bug is
about tags, but it is not difficult to imagine that the same goes for
branches as well
Jorrit
Re: trunk dir inside branch [message #37946 is a reply to message #37784] |
Mon, 17 November 2008 04:06  |
Hello Jorrit,
Thanks, you are right this problem relates to
>> Any ideas?
> branches as well
> Jorrit
Current Time: Sat Jul 26 08:44:43 EDT 2025
Powered by FUDForum. Page generated in 0.03642 seconds
