Home » Archived » GMT (Generative Modeling Technologies) » [Epsilon] Error in Running Examples
[Epsilon] Error in Running Examples [message #377707] |
Mon, 14 May 2007 19:24  |
Originally posted by: b_zamani.encs.concordia.ca
Hi Everybody,
I've installed Epsilon on Eclipse 3.2.1 and downloaded examples and tried to
run them.
For ValidateOO.evl, I got the following error:
Cannot find meta-class 'NamedElement' in model ''
For BuildOOInstance.eol, I got the following error:
Line: 2, Column: 7, Reason: unexpected token: :=
Line: 12, Column: 24, Reason: expecting ';', found ':='
Line: 19, Column: 20, Reason: expecting ';', found ':='
Can anybody help me fixing this problem?
best,
Bahman
Re: [Epsilon] Error in Running Examples [message #377710 is a reply to message #377707] |
Tue, 15 May 2007 04:57   |
Hi Bahman,
From your description it seems that you may be using an outdated
version of the Epsilon plugins (I've just tried the two examples with
the bundle available at www.eclipse.org/gmt/epsilon/download.php and
they seem to work). Before going deeper into this could you please
confirm that you are using the latest version of the plugins atop Java
1.5 (or greater)?
Dimitrios
Bahman wrote:
> Hi Everybody,
> run them.
> best,
> Bahman
Re: [Epsilon] Error in Running Examples [message #377713 is a reply to message #377710] |
Tue, 15 May 2007 10:20   |
Hi Dimitrios,
Thanks for reply. I have already had Eclipse 3.2.1 and EMF 2.2.1 installed
atop Java 1.6; Therefore, I just downloaded Epsilon plug-in (2.8MB) from the
page that you referred to it. However, I thin I don't have MDR plug-in
installed. Is it mandatory? IMHO, both EMF and MDR are implementations of
MOF, so, one of them is sufficient.
Actually, I'm interested in running EWL examples in Eclipse, but it seems
that your plug-in does not include EWL yet, right? I have some questions in
this regard and will ask you in future.
best,
Bahman
"Dimitrios Kolovos" <dskolovos@gmail.com> wrote in message
news:f2bsmh$nbn$1@build.eclipse.org...
> Hi Bahman,
> From your description it seems that you may be using an outdated version
> of the Epsilon plugins (I've just tried the two examples with the bundle
> available at www.eclipse.org/gmt/epsilon/download.php and they seem to
> work). Before going deeper into this could you please confirm that you are
> using the latest version of the plugins atop Java 1.5 (or greater)?
> Cheers,
> Dimitrios
> Bahman wrote:
>> Hi Everybody,
>> to run them.
>> best,
>> Bahman
Re: [Epsilon] Error in Running Examples [message #377715 is a reply to message #377713] |
Tue, 15 May 2007 11:14   |
Hi Bahman,
Bahman wrote:
> Hi Dimitrios,
I've tried with the plugins on a clean Eclipse 3.2 and EMF 2.2.0
installation that I have but unfortunately I cannot reproduce the errors.
The reason I asked you about your version of Epsilon is that your EOL
errors are all related to
*var x : X := new X;*
and
*x := new X;*
statements, and this syntax was recently introduced in EOL (a few months
ago - before that only statements of type *var x : new X;* were
supported). In case you had downloaded/installed the Epsilon plugins
before the new syntax was introduced and re-installed now, Eclipse may
have cached the older versions. Have you tried the -clean switch?
For the EVL example that does not contain such statements I suspect that
you do not launch the EVL validation correctly (you don't specify the
input model). The safe way to go is to open the OOValidation.launch file
(stored launch configuration) by dbl-clicking it in the Navigator and
then locate and run the newly created OOValidation launch configuration.
No
The MDR plugin is needed if you need to access MOF1.4/XMI1.x models
(e.g. created from ArgoUML, older versions of Poseidon etc).
Unlike the rest of the languages in Epsilon - which are executed on the
serialized models (i.e. XMI) - EWL is executed on "live" models and
thus, supporting tools need to integrate tightly with the respective
visual editors (e.g. listen for selection changes, trigger updates on
the UI). We are planning to implement such support in the near future
for GMF-based visual editors. If you have any further
questions/suggestions I'm more than happy to answer them.
> best,
> Bahman
Dimitrios
>> Hi Bahman,
>> Cheers,
>> Dimitrios
>> Bahman wrote:
>>> Hi Everybody,
>>> to run them.
>>> best,
>>> Bahman
Re: [Epsilon] Error in Running Examples [message #377716 is a reply to message #377715] |
Tue, 15 May 2007 15:43   |
Hi again,
You're right, my Epsilon plug-in was outdated (installed on Apr. 30th)!
As a suggestion, it would be useful to include FAQ.txt file into all single
examples as well, it helped me a lot.
Now all examples work fine, except for validation example(ValidateOO.evl),
which after giving appropriate messages in validation tab, it remains in
LAUNCHING mode and makes cpu 100% busy, and it can't be stopped. The only
escape way is to exit Eclipse. I tried in on a completely new Eclipse by
downloading the complete bundle from Epsilon site, it is the same.
About EWL, I can't see too much difference between EVL (or ETL) and EWL,
except the point of interactivity in EWL. For instance, in wizards.ewl in
ArgoUML examples, you consider adding getters and setters as and example of
wizard, and in Eclipse examples we have it as a transformation.
best,
Bahman
news:f2cinr$6ni$1@build.eclipse.org...
> Hi Bahman,
> Bahman wrote:
>> Hi Dimitrios,
>> installed atop Java 1.6; Therefore, I just downloaded Epsilon plug-in
>> (2.8MB) from the page that you referred to it.
> and
> *x := new X;*
> (stored launch configuration) by dbl-clicking it in the Navigator and then
> No
> The MDR plugin is needed if you need to access MOF1.4/XMI1.x models (e.g.
>> in this regard and will ask you in future.
> serialized models (i.e. XMI) - EWL is executed on "live" models and thus,
> supporting tools need to integrate tightly with the respective visual
> editors (e.g. listen for selection changes, trigger updates on the UI). We
> are planning to implement such support in the near future for GMF-based
> visual editors. If you have any further questions/suggestions I'm more
>> best,
>> Bahman
> Regards,
> Dimitrios
>>> Hi Bahman,
>>> are using the latest version of the plugins atop Java 1.5 (or greater)?
>>> Cheers,
>>> Dimitrios
>>> Bahman wrote:
>>>> Hi Everybody,
>>>> tried to run them.
>>>> best,
>>>> Bahman
Re: [Epsilon] Error in Running Examples [message #377717 is a reply to message #377716] |
Tue, 15 May 2007 16:53   |
Hi Bahman,
Bahman wrote:
> Hi again,
Thanks a lot for your suggestion. I'll add the content of the FAQ.txt in
the Examples page or in the Eclipse Wiki soon.
After the constraints are evaluated, the EVL engine goes into a "fixing"
mode. In this mode you can right-click messages in the Validation view
and apply fixes to elements for which constraints have failed (if the
constraints define fix parts (e.g. the NameShouldStartWithUpperCase
constraint)). When you are done with reviewing failed constraints and/or
performing fixes you can click the arrow-shaped "Finish..." button in
the Validation view and the engine will terminate.
BTW If you are interested, I can send you a copy of the reference paper
for EVL that is currently under review.
The difference between EWL and the transformation in the examples is
that the prior is applied on specific attributes selected explicitly by
the user while the latter is applied on all the attributes in the model.
Therefore, proper EWL tool-support needs to be able to monitor the
editor so that it can capture element selection/deselection events
(similarly to what is done in the ArgoUML implementation).
This is certainly feasible in GMF but it will take some time to
implement :) However, if you need this feature urgently and/or decide to
implement it yourself, I'll be glad to help you and also share with you
the existing ArgoUML/EWL code.
Again, if you are interested in knowing more about EWL, I can send you a
preprint of a paper that discusses the language in detail (it will be
presented in TOOLS EUROPE 2007 in June).
> best,
> Bahman
>> Hi Bahman,
>> Bahman wrote:
>>> Hi Dimitrios,
>> and
>> *x := new X;*
>> No
>>> best,
>>> Bahman
>> Regards,
>> Dimitrios
>>>> Hi Bahman,
>>>> Cheers,
>>>> Dimitrios
>>>> Bahman wrote:
>>>>> Hi Everybody,
>>>>> tried to run them.
>>>>> best,
>>>>> Bahman
Dimitrios
Re: [Epsilon] Error in Running Examples [message #377718 is a reply to message #377717] |
Tue, 15 May 2007 17:17   |
Hi Dimitrios,
Thank you. Now all examples are working fine. DONE!
I've read two of the papers that are available in your web page ("EOL" and
"Eclipse Dev Tools for Epsilon"). If you send me more sources about EWL, I
appreciate that. (please email me)
I'm doing my research on V&V of Models and I think I have a long way to
finish!!
cheers,
Bahman
news:f2d6jk$aj9$1@build.eclipse.org...
> Hi Bahman,
> Bahman wrote:
>> Hi again,
>> single examples as well, it helped me a lot.
>> example(ValidateOO.evl), which after giving appropriate messages in
>> validation tab, it remains in LAUNCHING mode and makes cpu 100% busy, and
>> it can't be stopped. The only escape way is to exit Eclipse. I tried in
>> on a completely new Eclipse by downloading the complete bundle from
> mode. In this mode you can right-click messages in the Validation view and
> performing fixes you can click the arrow-shaped "Finish..." button in the
>> of wizard, and in Eclipse examples we have it as a transformation.
> The difference between EWL and the transformation in the examples is that
> the prior is applied on specific attributes selected explicitly by the
> Therefore, proper EWL tool-support needs to be able to monitor the editor
> so that it can capture element selection/deselection events (similarly to
> This is certainly feasible in GMF but it will take some time to implement
> :) However, if you need this feature urgently and/or decide to implement
> it yourself, I'll be glad to help you and also share with you the existing
> ArgoUML/EWL code.
>> best,
>> Bahman
>>> Hi Bahman,
>>> Bahman wrote:
>>>> Hi Dimitrios,
>>> errors.
>>> and
>>> *x := new X;*
>>> No
>>>> seems that your plug-in does not include EWL yet, right? I have some
>>>> questions in this regard and will ask you in future.
>>>> best,
>>>> Bahman
>>> Regards,
>>> Dimitrios
>>>>> Hi Bahman,
>>>>> 1.5 (or greater)?
>>>>> Cheers,
>>>>> Dimitrios
>>>>> Bahman wrote:
>>>>>> Hi Everybody,
>>>>>> tried to run them.
>>>>>> best,
>>>>>> Bahman
> Cheers,
> Dimitrios
Re: [Epsilon] Error in Running Examples [message #379045 is a reply to message #377715] |
Tue, 21 August 2007 18:57  |
Hi Bahman,
On an update to this thread, Epsilon now provides tool support for
executing interactive EWL wizards (i.e. scripts/macros) to automate
tasks in GMF-based editors (e.g. UML2 Tools editors, the GMF-based Ecore
editor etc). A relevant flash demo is available at
http://www.eclipse.org/gmt/epsilon/cinema/
Dimitrios
Dimitrios Kolovos wrote:
> Hi Bahman,
> Bahman wrote:
>> Hi Dimitrios,
> and
> *x := new X;*
> No
>> best,
>> Bahman
> Regards,
> Dimitrios
>>> Hi Bahman,
>>> Cheers,
>>> Dimitrios
>>> Bahman wrote:
>>>> Hi Everybody,
>>>> tried to run them.
>>>> best,
>>>> Bahman
Re: [Epsilon] Error in Running Examples [message #596833 is a reply to message #377707] |
Hi Bahman,
1.5 (or greater)?
Dimitrios
Bahman wrote:
> Hi Everybody,
> run them.
> best,
> Bahman
Re: [Epsilon] Error in Running Examples [message #596872 is a reply to message #377710] |
Hi Dimitrios,
best,
Bahman
> Hi Bahman,
> Cheers,
> Dimitrios
> Bahman wrote:
>> Hi Everybody,
>> to run them.
>> best,
>> Bahman
Re: [Epsilon] Error in Running Examples [message #596900 is a reply to message #377713] |
Hi Bahman,
Bahman wrote:
> Hi Dimitrios,
and
*x := new X;*
No
> best,
> Bahman
Dimitrios
>> Hi Bahman,
>> Cheers,
>> Dimitrios
>> Bahman wrote:
>>> Hi Everybody,
>>> to run them.
>>> best,
>>> Bahman
Re: [Epsilon] Error in Running Examples [message #596916 is a reply to message #377715] |
Hi again,
best,
Bahman
> Hi Bahman,
> Bahman wrote:
>> Hi Dimitrios,
> and
> *x := new X;*
> No
>> best,
>> Bahman
> Regards,
> Dimitrios
>>> Hi Bahman,
>>> Cheers,
>>> Dimitrios
>>> Bahman wrote:
>>>> Hi Everybody,
>>>> tried to run them.
>>>> best,
>>>> Bahman
Re: [Epsilon] Error in Running Examples [message #596923 is a reply to message #377716] |
Hi Bahman,
Bahman wrote:
> Hi again,
> best,
> Bahman
>> Hi Bahman,
>> Bahman wrote:
>>> Hi Dimitrios,
>> and
>> *x := new X;*
>> No
>>> best,
>>> Bahman
>> Regards,
>> Dimitrios
>>>> Hi Bahman,
>>>> Cheers,
>>>> Dimitrios
>>>> Bahman wrote:
>>>>> Hi Everybody,
>>>>> tried to run them.
>>>>> best,
>>>>> Bahman
Dimitrios
Re: [Epsilon] Error in Running Examples [message #596936 is a reply to message #377717] |
Hi Dimitrios,
finish!!
cheers,
Bahman
> Hi Bahman,
> Bahman wrote:
>> Hi again,
> ArgoUML/EWL code.
>> best,
>> Bahman
>>> Hi Bahman,
>>> Bahman wrote:
>>>> Hi Dimitrios,
>>> errors.
>>> and
>>> *x := new X;*
>>> No
>>>> best,
>>>> Bahman
>>> Regards,
>>> Dimitrios
>>>>> Hi Bahman,
>>>>> 1.5 (or greater)?
>>>>> Cheers,
>>>>> Dimitrios
>>>>> Bahman wrote:
>>>>>> Hi Everybody,
>>>>>> tried to run them.
>>>>>> best,
>>>>>> Bahman
> Cheers,
> Dimitrios
Re: [Epsilon] Error in Running Examples [message #606599 is a reply to message #377715] |
Hi Bahman,
Dimitrios
> Hi Bahman,
> Bahman wrote:
>> Hi Dimitrios,
> and
> *x := new X;*
> No
>> best,
>> Bahman
> Regards,
> Dimitrios
>>> Hi Bahman,
>>> Cheers,
>>> Dimitrios
>>> Bahman wrote:
>>>> Hi Everybody,
>>>> tried to run them.
>>>> best,
>>>> Bahman
Current Time: Sat Jul 26 10:58:29 EDT 2025
Powered by FUDForum. Page generated in 0.15176 seconds
