Home » Eclipse Projects » EclipseLink » left side of the IN operator missing?
left side of the IN operator missing? [message #377457] Mon, 04 August 2008 10:20 Go to next message
I have a JPQL query that looks like this:
select sol from Sellorderline sol where sol.iArticle in (select a from License l inner join l.iLicenseArticlesWhereIAmLicense la inner join la.iArticle a where l = :license)
It tries to find Sellorderlines where the article that is sold is present in the specified license. The generated SQL looks like this (I've stripped some of the returned fields):
SELECT t1.sellorderlinenr, t1.articlenr, ...,t1.dwhby FROM article t0, sellorderline t1 WHERE ( IN (SELECT DISTINCT t2.articlenr, t2.articletypenr, t2.description, t2.sellingprice, t2.length, t2.width, t2.inserted, t2.std_reservation, t2.haslicenses, t2.minimalstock, t2.is_landscape, t2.actueel, t2.weight, t2.c, t2.f, t2.info, t2.rolinstellingenok, t2.rolkop, t2.tapper, t2.veer, t2.lazylock, t2.managestock, t2.seqnr, t2.keywords, t2.opweb, t2.dwhmodified, t2.dwhby, t2.ean, t2.opwebdate, t2.salestatus FROM license t4, license_article t3, article t2 WHERE ((? = t4.licensenr) AND ((t3.licensenr = t4.licensenr) AND (t2.articlenr = t3.articlenr)))) AND (t0.articlenr = t1.articlenr))
Note the "WHERE ( IN (SELECT"; the left side of the IN is not present! Am I doing something wrong?
Tom
Re: left side of the IN operator missing? [message #377459 is a reply to message #377457] Mon, 04 August 2008 10:40 Go to previous messageGo to next message
I solved it myself: you cannot do a entity-in-entity, you need to do attribute-in-attribute. The huge list of fields that the subquery returned was the clue.
not:
.... and sol.iArticle in (select a ...
but:
.... and sol.iArticle.iArticlenr in (select a.iArticlenr ...
Maybe an error message or something would be appropriate?
Tom
Re: left side of the IN operator missing? [message #378595 is a reply to message #377459] Tue, 05 August 2008 09:41 Go to previous messageGo to next message
Feel free to log an enhancement request. Instead of an error message, I
think it would be nice if it just worked, the IN sub-select could just
select the Id.
-- James
Re: left side of the IN operator missing? [message #378599 is a reply to message #378595] Tue, 05 August 2008 10:46 Go to previous message
> select the Id.
True. On the other hand, that won't work with composite keys, so it is not a 100% solution.
Previous Topic:unidirectional one-to-many mapping with join column
Next Topic:Change tracking of many-to-many relationship broken?
Current Time: Sat Jul 19 03:15:41 EDT 2025
Powered by FUDForum. Page generated in 0.04113 seconds
