Home » Eclipse Projects » EclipseLink » many table, one entity, annotation driven?
many table, one entity, annotation driven? [message #377454] Fri, 01 August 2008 07:02 Go to next message
Folks;
maybe an utterly stupid question, nevertheless I lack a few pointers /
insights on that: In our (legacy) system, we do have sort of O/R mapping to
an SQL backend done in a way like this, assuming a class and its superclass:
- all "superclass" attributes go to a table "superclass" for any class to
extend "superclass",
- all "class" specific attributes, given "class" extends "superclass", go to
a "class" table specific to this class.
- Both tables do have a common key field (OBJID), for each row in "class"
table there is a corresponding row in "superclass" as well.
What I need / want to do now is using the features provided by JPA /
EclipseLink together with our RDBMS to, at best using annotations, read data
from the both of these tables to objects of one entity, like this:
public class NewsLetter extends Common {
private long id;
// life in table "common"
private String objName;
private String objDocument;
// life in table "newsletter"
private Date newsLetterDate;
private String newsLetterHeader;
private String newsLetterBody;
So far I dealt with modeling various ways of doing joins in JPA but the best
I came up with so far was fetching the content of table "common" to an
attribute "Common" in the newsletter class which would work but seems more
difficult than it needs to be.
So, question: Is there a way to map a JPA entity to two tables? Can this,
especially, be done using annotations? Am I overlooking something rather
simple, or is my conception flawed?
Thanks for any inspirations, best regards.
Kristian
Kristian Rink * http://zimmer428.net * http://flickr.com/photos/z428/ jab:
kawazu@jabber.ccc.de * icq: 48874445 * fon: ++49 176 2447 2771 "One dreaming
alone, it will be only a dream; many dreaming together is the beginning of a
new reality." (Hundertwasser)
Re: many table, one entity, annotation driven? [message #377455 is a reply to message #377454] Fri, 01 August 2008 20:49 Go to previous messageGo to next message
use a discriminator column and joined inheritance strategy.
For example:
@Entity
@Table(name="COMMON")
@DiscriminatorColumn(name="CAT", discriminatorType=DiscriminatorType.STRING)
@Inheritance(strategy=InheritanceType.JOINED)
public abstract class Common {
@Id
@GeneratedValue
private Long id;
@Column
@Column
@Entity
@DiscriminatorValue("NEWSLETTER") // Use any name you like
@Table(name="NEWSLETTER")
public class Newsletter extends Common {
@Column
@Temporal(TemporalType.TIMESTAMP)
private Date newsletterDate;
@Column
private String newsletterHeader;
@Column
private String newsletterBody;
Michael
Re: many table, one entity, annotation driven? [message #377456 is a reply to message #377455] Mon, 04 August 2008 05:42 Go to previous messageGo to next message
Michael;
first off, thank you very much for pointing me here; seems a reasonable
solution after all and almost works in my environment, except for one
problem so far:
> @Id
> @GeneratedValue
> private Long id;
Thanks to the database schema in our backend system (which is pretty strange
at times yet hard to change), the column "ID", table "Common", is used to be
called "RefId" in any other table. Straightforward I tried adding an @Id
@Column(name="RefId") to the class extending "Common" which, yet, ending in
a query that fails due to "Id" not found in the "Newsletter" table. Is
there, talking about JOINED, any way to, in the extending class, state which
column is to be used for the join?
Anyway, thanks again and best regards,
Kristian
Re: many table, one entity, annotation driven? [message #378581 is a reply to message #377456] Mon, 04 August 2008 13:32 Go to previous messageGo to next message
this is no problem, just add the PrimaryKeyJoinColumn annotation to the
class Newsletter.
@Entity
@PrimaryKeyJoinColumn(name="IDREF")
In JPA there seems to be tinsel (ger: Lametta) for any kind of scary
database design. ;-)
Michael
"Kristian Rink" <kawazu@zimmer428.net> schrieb im Newsbeitrag
news:g76ium$l3k$1@build.eclipse.org...
> Michael;
> problem so far:
>> @Id
>> @GeneratedValue
>> private Long id;
> strange
> be
> in
> which
> Kristian
> dreaming
> a
Re: many table, one entity, annotation driven? [message #378583 is a reply to message #378581] Tue, 05 August 2008 02:17 Go to previous messageGo to next message
Hi Michael;
and, again, thanks for your input / information on that, much appreciated. :)
semi schrieb:
> @Entity
Hehe, pretty cool, tinsel to deal with questionable database design is right
what I am in dire need of, at the moment. Thanks bunches again for kicking
me the right direction. ;)
Cheerse & regds from DD/Germany,
Kristian
Re: many table, one entity, annotation driven? [message #378605 is a reply to message #378583] Wed, 06 August 2008 04:41 Go to previous messageGo to next message
Hi again;
speaking of "tinsel" and obscure database design:
Kristian Rink schrieb:
>> @Entity
While this approach (@DiscriminatorColumn / @DiscriminatorValue) does rather
well do in most situations (and, for that matters, makes migration of our DB
abstraction a rather pleasant procedure), I now have stumbled across a set
of situations in which this is not applicable, because, even though the
hierarchy is right the same (extending classes, common base class, separate
tables), there is no column usable as discriminator, leaving our backend
system obviously doing a simple join across the two tables using the common
ID, assuming the Discriminator is not required as "while the data is in the
'extending class' table, it per se must extend 'common' and thus have an
entry there". Which leaves me dealing with this... simply dumping the
@Discriminator* annotations, as supposed, broke my code again... Any way of
doing an inheritance hierarchy here without @Discriminator*? And, asides
that, any good books to be read on JPA dealing with these issues? Don't want
to steal anyones time...
Cheers & thanks for your patience,
Kristian
Re: many table, one entity, annotation driven? [message #378609 is a reply to message #378605] Wed, 06 August 2008 09:22 Go to previous messageGo to next message
Some solutions are discussed here,
http://en.wikibooks.org/wiki/Java_Persistence/Inheritance#No _class_discriminator_column_2
The book has lots of info on inheritance in general and other persistence
topics.
Essentially in EclipseLink you can do it using a ClassExtractor and a
DescriptorCustomizer.
-- James
Re: many table, one entity, annotation driven? [message #379020 is a reply to message #378605] Wed, 06 August 2008 10:31 Go to previous message
there are two possible solutions for your problem.
* MappedSuperclass
* Embedable
But it's not the same as using discriminator columns. In both cases you no
more can do queries like "select c from Common c"
1a) MappedSuperclass with one common table
@MappedSuperclass
@Id
@GeneratedValue
@Column
private Long id;
@Column
@Column
@Entity
@AttributeOverride(name="id", column=@Column(name="IDREF"))
@Column
@Column
@Column
1b) MappedSuperclass with the possibility to use different "base" tables
(see SecondaryTable annotation and AttributeOverrides)
@MappedSuperclass
@Id
@GeneratedValue
@Column
private Long id;
@Column
@Column
@Entity
@SecondaryTable(name="COMMON",
pkJoinColumns=@PrimaryKeyJoinColumn(name="ID"))
@AttributeOverrides({
@AttributeOverride(name="objName", column=@Column(name="OBJNAME",
table="COMMON"))
,@AttributeOverride(name="objDocument",
column=@Column(name="OBJDOCUMENT", table="COMMON"))
@Column
@Column
@Column
2) Embedable in a common table
public interface ObjectInfoProvider {
ObjectInfo getObjectInfo();
@Embeddable
public class ObjectInfo {
@Column
@Column
@Entity
public class Newsletter implements ObjectInfoProvider {
@Id
@GeneratedValue
private Long id;
@Column
@Column
@Column
@Embedded
table="COMMON"))
private ObjectInfo objectInfo;
One good book with explanation for all inheritance related issues is this
one
http://www.amazon.de/Pro-EJB-Persistence-Experts-Voice/dp/15 90596455
and maybe this one too, but the focus of this book is the hibernate JPA
implementation
http://www.amazon.de/Java-Persistence-with-Hibernate/dp/1932 394885
Hope it helps,
Michael
news:g7bo44$qd7$1@build.eclipse.org...
> Hi again;
>>> @Entity
> rather
> DB
> separate
> common
> the
> of
> want
> Kristian
> dreaming
> a
Previous Topic:Change tracking of many-to-many relationship broken?
Next Topic:DDL generation without database access
Current Time: Wed Jul 23 14:12:57 EDT 2025
Powered by FUDForum. Page generated in 0.03733 seconds
