Home » Eclipse Projects » DTP » "on delete cascade" results in syntax error (Derby)
"on delete cascade" results in syntax error (Derby) [message #37624] Fri, 26 October 2007 12:39 Go to next message
if I run the following SQL statement I receive in the SQL Result view the
message:Syntax error: Encountered ";" at line 183, column 2.
I used to use this statement to create the database in Derby. Can you tell
me what is wrong with the statement?
Best regards, Lars
create table sixsigma.rel_req_user(
req_id int not null,
user_id int not null,
primary key (req_id,user_id),
foreign key(req_id) references sixsigma.requirement(req_id) on delete
cascade,
foreign key(user_id) references sixsigma.users(id) on delete cascade
Re: "on delete cascade" results in syntax error (Derby) [message #37644 is a reply to message #37624] Fri, 26 October 2007 12:44 Go to previous messageGo to next message
I might add that I'm using Eclipse 3.3 with the latest dtp
"Lars Vogel" <Lars.Vogel@gmail.com> wrote in message
news:fft57f$7fd$1@build.eclipse.org...
> Best regards, Lars
> cascade,
Re: "on delete cascade" results in syntax error (Derby) [message #37661 is a reply to message #37644] Sun, 28 October 2007 21:19 Go to previous messageGo to next message
Originally posted by: hui.cao.sybase.ocm
Hi Lars,
There's nothing wrong with your statement. This is a bug which has been
logged in https://bugs.eclipse.org/bugs/show_bug.cgi?id=198719.
Best Regards!
Max (Hui) Cao
Sybase Shanghai RD
news:fft5h0$aa1$1@build.eclipse.org...
>> Hi,
>> tell me what is wrong with the statement?
>> Best regards, Lars
>> cascade,
Re: "on delete cascade" results in syntax error (Derby) [message #37773 is a reply to message #37661] Mon, 29 October 2007 16:39 Go to previous message
Hi Hui,
thank you. If I read the bug target correct it will be part of 1.5.2. Is it
already know then 1.5.2 is planned to be released? On
http://www.eclipse.org/datatools/ I did not find this information.
Best regards, Lars
"Hui Cao" <hui.cao@sybase.ocm> wrote in message
news:fg3ced$mhp$1@build.eclipse.org...
> Hi Lars,
> Best Regards!
> Max (Hui) Cao
> Sybase Shanghai RD
>>> Hi,
>>> the message:Syntax error: Encountered ";" at line 183, column 2.
>>> Best regards, Lars
>>> cascade,
Re: "on delete cascade" results in syntax error (Derby) [message #588299 is a reply to message #37624] Fri, 26 October 2007 12:44 Go to previous message
> Best regards, Lars
> cascade,
Re: "on delete cascade" results in syntax error (Derby) [message #588309 is a reply to message #37644] Sun, 28 October 2007 21:19 Go to previous message
Hi Lars,
Best Regards!
Max (Hui) Cao
Sybase Shanghai RD
>> Hi,
>> Best regards, Lars
>> cascade,
Re: "on delete cascade" results in syntax error (Derby) [message #588338 is a reply to message #37661] Mon, 29 October 2007 16:39 Go to previous message
Hi Hui,
Best regards, Lars
> Hi Lars,
> Best Regards!
> Max (Hui) Cao
> Sybase Shanghai RD
>>> Hi,
>>> Best regards, Lars
>>> cascade,
Previous Topic:"on delete cascade" results in syntax error (Derby)
Next Topic:Line number
Current Time: Wed Jul 23 05:21:39 EDT 2025
Powered by FUDForum. Page generated in 0.10495 seconds
