Home » Modeling » Modeling (top-level project) » UML Format
UML Format [message #376400] Wed, 17 May 2006 11:27 Go to next message
Originally posted by: mari.bgu.ac.il
Hi all,
I am researching the features of UML Class diagrams as well as consistency.
Therefore the model must exist in a format that can be examined. The problem
of XMI that it is too complicated and until now I did not find a good parser
which enables me to use it. Therefore I am interested in less complex format
which enables me to extract the relevant information about the class
diagram: Classes, the associations between them with the multiplicity, the
hierarchy and so on.
Since I did not have any experience in Eclipse (I just already began using
it), my question: is there any alternative format which Eclipse provides? Or
maybe a normal parser. Or maybe the tool enables to access modeler features
(script / plug-out) to extract the appropriate data.
I am not interested to generate any code, my purpose, in a given class
diagram, is to extract all the information about such class diagram in a
normal format. I will take such format and build a parser which extract the
information and transfer it to an analyzing tool. In the in the absence of
such format force me to take the XMI alternative.
I will appreciate any help.
Re: UML Format [message #376402 is a reply to message #376400] Wed, 17 May 2006 10:44 Go to previous messageGo to next message
--------------090007030503080602020101
Azzam,
I would imagine that you'd want to load the XMI serialization as an
instance of the UML2 model and then use the UML2 APIs to do all the
analysis.
http://www.eclipse.org/uml2/
Azzam wrote:
>Hi all,
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Azzam,<br>
<br>
analysis. <br>
<blockquote><a href="http://www.eclipse.org/uml2/">http://www.eclipse.org/uml2/</a><br>
</blockquote>
<br>
Azzam wrote:
<blockquote cite="mide4fbka$hh4$1@utils.eclipse.org" type="cite">
<pre wrap="">Hi all,
</pre>
</blockquote>
<br>
</body>
</html>
--------------090007030503080602020101--
Re: UML Format [message #376404 is a reply to message #376402] Wed, 17 May 2006 13:14 Go to previous messageGo to next message
Thank you about your answer. I will try such option (However the input is
the class diagram not the XMI).
At the end what I really want is to get a representation of UML design in a
normal format (e.g. table format) where it will be easy to parse it. The
information as I had mentioned should includes the classes with associations
and the mutability and so on. The XMI provides inherently such information
but it is too complicated and need a parser for it. It is seem that the API
will provide me an access to extract the appropriate data is not it? Or
maybe it is better to tackle the XMI format.
At all, the better is to use the modeler features (script / plug-out) to
extract the.
appropriate data.
Azzam
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:e4fcsb$m2c$1@utils.eclipse.org...
Azzam,
I would imagine that you'd want to load the XMI serialization as an instance
of the UML2 model and then use the UML2 APIs to do all the analysis.
Azzam wrote:
Hi all,
Re: UML Format [message #376405 is a reply to message #376404] Wed, 17 May 2006 13:14 Go to previous messageGo to next message
Azzam,
It seems you want to read a cryptic file format to produce a high level
representation and that's exactly what UML2 already does. You say you
have a class diagram, not XMI, but that doesn't give a hint of what
format a class diagram might be. I simply assumed it was XMI. I
certainly can't imagine you'd want to write your own parser and develop
your own UML2 model, which is what you'd need to do if you didn't reuse
UML2...
>extract the.
>appropriate data.
>Best regards,
>Azzam
>Azzam,
>Azzam wrote:
>Hi all,
Re: UML Format [message #376406 is a reply to message #376404] Wed, 17 May 2006 13:51 Go to previous messageGo to next message
Azzam,
Please see my response in the UML2 newsgroup.
Kenn
"Azzam" <mari@bgu.ac.il> wrote in message
news:e4fhsa$hj$1@utils.eclipse.org...
a
associations
API
> extract the.
> appropriate data.
> Best regards,
> Azzam
> Azzam,
instance
> Azzam wrote:
> Hi all,
consistency.
problem
parser
format
Or
features
the
Re: UML Format [message #376407 is a reply to message #376405] Wed, 17 May 2006 15:05 Go to previous message
Dear Marks,
Thank you very much for your prompt reply.
Azzam
news:e4fllf$hh9$1@utils.eclipse.org...
> Azzam,
> have a class diagram, not XMI, but that doesn't give a hint of what format
> a class diagram might be. I simply assumed it was XMI. I certainly can't
> imagine you'd want to write your own parser and develop your own UML2
> model, which is what you'd need to do if you didn't reuse UML2...
>>a normal format (e.g. table format) where it will be easy to parse it. The
>>associations and the mutability and so on. The XMI provides inherently
>>such information but it is too complicated and need a parser for it. It is
>>seem that the API will provide me an access to extract the appropriate
>>data is not it? Or maybe it is better to tackle the XMI format.
>>extract the.
>>appropriate data.
>>Best regards,
>>Azzam
>>Azzam,
>>analysis.
>>Azzam wrote:
>>Hi all,
>>consistency.
>>problem
>>parser
>>format
>>Or
>>features
>>the
Re: UML Format [message #564799 is a reply to message #376400] Wed, 17 May 2006 10:44 Go to previous message
Azzam,
analysis.
Azzam wrote:
>Hi all,
<html>
<head>
</head>
Azzam,<br>
<br>
analysis. <br>
</blockquote>
<br>
</pre>
</blockquote>
<br>
</body>
</html>
Re: UML Format [message #564885 is a reply to message #376402] Wed, 17 May 2006 13:14 Go to previous message
extract the.
appropriate data.
Azzam
Azzam,
Azzam wrote:
Hi all,
Re: UML Format [message #564910 is a reply to message #376404] Wed, 17 May 2006 13:14 Go to previous message
Azzam,
UML2...
>extract the.
>appropriate data.
>Best regards,
>Azzam
>Azzam,
>Azzam wrote:
>Hi all,
Re: UML Format [message #564942 is a reply to message #376404] Wed, 17 May 2006 13:51 Go to previous message
Azzam,
Kenn
a
associations
API
> extract the.
> appropriate data.
> Best regards,
> Azzam
> Azzam,
instance
> Azzam wrote:
> Hi all,
consistency.
problem
parser
format
Or
features
the
Re: UML Format [message #564960 is a reply to message #376405] Wed, 17 May 2006 15:05 Go to previous message
Dear Marks,
Azzam
> Azzam,
>>extract the.
>>appropriate data.
>>Best regards,
>>Azzam
>>Azzam,
>>analysis.
>>Azzam wrote:
>>Hi all,
>>consistency.
>>problem
>>parser
>>format
>>Or
>>features
>>the
Previous Topic:Interoperability between modelling IDE's based on eclipse
Next Topic:Textual Modelling Framework?
Current Time: Sat Jul 26 09:41:13 EDT 2025
Powered by FUDForum. Page generated in 0.06787 seconds
