Home » Eclipse Projects » EclipseLink » Problem with persistence cache using JPA
Problem with persistence cache using JPA [message #376350] |
Tue, 15 July 2008 17:01  |
I'm having a problem with my J2EE application and after many hours of debugging
I have been able to distill the problem down into a small testable application.
My J2EE application consists of using the Command pattern and various Commands
can be strung together to accomplish a desired goal. These Commands when strung
together are executed within a Container Managed transaction and EntityManager.
This is the reason that the flow that I present below is done and I have no
easy way that I can change it.
Basically I have two entity classes: Parent and Child. Parent is created
with one Child automatically and other Child entities can be added. There
is a @OneToMany and @ManyToOne relationship between Parent and Child.
The problem that I am seeing is that I create a Parent, get another
handle to the parent using EntityManager.find, update the Parent,
create 3 more children for a total of 4, and commit. This commits fine
and the underlying database is correct. In a separate transaction, I find
the Parent and count the children which indicates that there are only
3 children instead of the 4 that are actually in the database.
From what I found, if I remove the @Version field on the parent, then
this problem goes away but then I cannot do optimistic locking.
Also in the code below, if I remove he "p1.setSerialNumber" invocation
the problem does not occur.
So I'm looking for some help into why this problem is occurring. I
think it has something to do with the @version and optimistic locking
but I don't know how to get around it.
Here is the main test application code. I build a small J2SE application
using user controlled transactions just for testing purposes and the
problem is still exhibited:
-- Main.java
package stest;
import javax.persistence.EntityManager;
import javax.persistence.EntityManagerFactory;
public class Main {
* @param args the command line arguments
Integer id = create();
getCount(id);
public static Integer create() {
Integer id = null;
EntityManagerFactory emf = javax.persistence.Persistence.createEntityManagerFactory("stestPU ");
EntityManager em = emf.createEntityManager();
em.getTransaction().begin();
try {
Parent p0 = new Parent(false);
em.persist(p0);
em.flush();
Parent p1 = em.find(Parent.class, p0.getId());
// VVVVVV
p1.setSerialNumber("12345678");
Child cs_1_1 = new Child();
p1.addChild(cs_1_1);
em.flush();
Child cs_1_2 = new Child();
p1.addChild(cs_1_2);
em.flush();
Parent chassis2 = em.find(Parent.class, p0.getId());
Child cs_2_1 = new Child();
chassis2.addChild(cs_2_1);
em.flush();
em.getTransaction().commit();
id = p1.getId();
} catch (Exception e) {
e.printStackTrace();
em.getTransaction().rollback();
} finally {
em.close();
return id;
public static void getCount(Integer id) {
try {
Parent chassis = em.find(Parent.class, id);
int count = chassis.getChildren().size();
System.out.println("config set count is " + count);
} finally {
em.close();
Here is the Parent Entity:
-- Parent.java
package stest;
import java.io.Serializable;
import java.util.ArrayList;
import java.util.List;
import javax.persistence.CascadeType;
import javax.persistence.Column;
import javax.persistence.Entity;
import javax.persistence.GeneratedValue;
import javax.persistence.GenerationType;
import javax.persistence.Id;
import javax.persistence.OneToMany;
import javax.persistence.Version;
@Entity
public class Parent implements Serializable {
@Id
@GeneratedValue(strategy = GenerationType.IDENTITY)
@Column
private Integer id;
protected Parent() {
public Parent(boolean template) {
Child child = new Child();
addChild(child);
public Integer getId() {
return this.id;
public void setId(Integer id) {
this.id = id;
@Version
@Column
private int version;
public int getVersion() {
return version;
@OneToMany(mappedBy = "parent", cascade = {CascadeType.ALL})
private List<Child> children = new ArrayList<Child>();
public List<Child> getChildren() {
return children;
public void setChildren(List<Child> children) {
this.children = children;
public void addChild(Child cs) {
cs.setParent(this);
this.children.add(cs);
@Column
private String serialNumber;
public String getSerialNumber() {
return this.serialNumber;
public void setSerialNumber(String serialNumber) {
this.serialNumber = serialNumber;
Here is the Child entity:
-- Child.java
package stest;
import java.util.Date;
import javax.persistence.ManyToOne;
import javax.persistence.Temporal;
import javax.persistence.TemporalType;
@Entity
public class Child implements Serializable {
@Id
@Column
private Integer id;
public Child() {
return this.id;
this.id = id;
@Version
@Column
return version;
@ManyToOne(cascade = {CascadeType.ALL})
private Parent parent;
public Parent getParent() {
return parent;
public void setParent(Parent parent) {
this.parent = parent;
@Temporal(TemporalType.TIMESTAMP)
@Column
private Date createdOn = new Date();
public Date getCreatedOn() {
return this.createdOn;
protected void setCreatedOn(Date createdOn) {
this.createdOn = createdOn;
Re: Problem with persistence cache using JPA [message #376361 is a reply to message #376354] |
Thu, 17 July 2008 08:12  |
All transactions are committed. In my real application I cannot remove the flush calls because I need the ID's that are going to be
assigned. I have also verified that "p0 == p1". I also watched the interaction via the debugger and see that when I update the
serial number that the same object pointed to by "p0" and "p1" shows the update so that is a second way that I verified that I don't
have distinct objects.
Here is the log when run. I added a little code to print out the children that are seen in the second transactions.
init:
deps-jar:
Copying 1 file to C:\src\stest\build\classes
compile:
run:
[EL Finest]: 2008.07.17 08:09:20.830--ServerSession(26435810)--Thread(Thread[main,5, main])--Begin predeploying Persistence Unit
stestPU; state Initial; factoryCount 0
[EL Finest]: 2008.07.17 08:09:20.877--ServerSession(26435810)--Thread(Thread[main,5, main])--property=eclipselink.weaving; value=false
08:09:20.877--ServerSession(26435810)--Thread(Thread[main,5, main])--property=eclipselink.orm.throw.exceptions; default value=true
[EL Finer]: 2008.07.17 08:09:20.877--ServerSession(26435810)--Thread(Thread[main,5, main])--Searching for default mapping file in
file:/C:/src/stest/build/classes/
[EL Config]: 2008.07.17 08:09:21.143--ServerSession(26435810)--Thread(Thread[main,5, main])--The alias name for the entity class
[class stest.Child] is being defaulted to: Child.
[EL Config]: 2008.07.17 08:09:21.143--ServerSession(26435810)--Thread(Thread[main,5, main])--The table name for entity [class
stest.Child] is being defaulted to: CHILD.
[EL Config]: 2008.07.17 08:09:21.205--ServerSession(26435810)--Thread(Thread[main,5, main])--The column name for element [private
java.lang.Integer stest.Child.id] is being defaulted to: ID.
java.lang.Integer stest.Child.version] is being defaulted to: VERSION.
[EL Config]: 2008.07.17 08:09:21.237--ServerSession(26435810)--Thread(Thread[main,5, main])--The column name for element [private
java.util.Date stest.Child.createdOn] is being defaulted to: CREATEDON.
[EL Config]: 2008.07.17 08:09:21.237--ServerSession(26435810)--Thread(Thread[main,5, main])--The alias name for the entity class
[class stest.Parent] is being defaulted to: Parent.
[EL Config]: 2008.07.17 08:09:21.237--ServerSession(26435810)--Thread(Thread[main,5, main])--The table name for entity [class
stest.Parent] is being defaulted to: PARENT.
java.lang.Integer stest.Parent.id] is being defaulted to: ID.
java.lang.Integer stest.Parent.version] is being defaulted to: VERSION.
[EL Config]: 2008.07.17 08:09:21.268--ServerSession(26435810)--Thread(Thread[main,5, main])--The column name for element [private
java.lang.String stest.Parent.serialNumber] is being defaulted to: SERIALNUMBER.
[EL Config]: 2008.07.17 08:09:21.268--ServerSession(26435810)--Thread(Thread[main,5, main])--The target entity (reference) class for
the many to one mapping element [private stest.Parent stest.Child.parent] is being defaulted to: class stest.Parent.
[EL Config]: 2008.07.17 08:09:21.299--ServerSession(26435810)--Thread(Thread[main,5, main])--The primary key column name for the
mapping element [private stest.Parent stest.Child.parent] is being defaulted to: ID.
[EL Config]: 2008.07.17 08:09:21.299--ServerSession(26435810)--Thread(Thread[main,5, main])--The foreign key column name for the
mapping element [private stest.Parent stest.Child.parent] is being defaulted to: PARENT_ID.
[EL Config]: 2008.07.17 08:09:21.299--ServerSession(26435810)--Thread(Thread[main,5, main])--The target entity (reference) class for
the one to many mapping element [private java.util.List stest.Parent.children] is being defaulted to: class stest.Child.
[EL Finest]: 2008.07.17 08:09:21.330--ServerSession(26435810)--Thread(Thread[main,5, main])--End predeploying Persistence Unit
stestPU; state Predeployed; factoryCount 0
[EL Finer]: 2008.07.17 08:09:21.330--Thread(Thread[main,5,main])--JavaSECMPInitiali zer - transformer is null.
[EL Finest]: 2008.07.17 08:09:21.330--ServerSession(26435810)--Thread(Thread[main,5, main])--Begin predeploying Persistence Unit
stestPU; state Predeployed; factoryCount 1
[EL Finest]: 2008.07.17 08:09:21.330--ServerSession(26435810)--Thread(Thread[main,5, main])--Begin deploying Persistence Unit
[EL Finest]: 2008.07.17 08:09:21.377--ServerSession(26435810)--Thread(Thread[main,5, main])--property=eclipselink.logging.level;
value=FINEST; translated value=FINEST
[EL Finest]: 2008.07.17 08:09:21.377--ServerSession(26435810)--Thread(Thread[main,5, main])--property=eclipselink.jdbc.user; value=app
[EL Finest]: 2008.07.17 08:09:21.377--ServerSession(26435810)--Thread(Thread[main,5, main])--property=eclipselink.jdbc.password;
value=xxxxxx
[EL Finest]: 2008.07.17 08:09:31.487--ServerSession(26435810)--Thread(Thread[main,5, main])--property=eclipselink.jdbc.driver;
value=org.apache.derby.jdbc.ClientDriver
[EL Finest]: 2008.07.17 08:09:31.487--ServerSession(26435810)--Thread(Thread[main,5, main])--property=eclipselink.jdbc.url;
value=jdbc:derby://localhost:1527/sample
[EL Info]: 2008.07.17 08:09:31.487--ServerSession(26435810)--Thread(Thread[main,5, main])--EclipseLink, version: Eclipse Persistence
Services - 1.0 (Build 1.0 - 20080707)
[EL Finest]: 2008.07.17 08:09:31.893--Thread(Thread[main,5,main])--DBPlatform:
org.eclipse.persistence.platform.database.InformixPlatform, RegularExpression: (?i)informix.*.
org.eclipse.persistence.platform.database.PointBasePlatform, RegularExpression: (?i)pointbase.*.
org.eclipse.persistence.platform.database.DB2Platform, RegularExpression: (?i).*db2.*.
org.eclipse.persistence.platform.database.SQLServerPlatform, RegularExpression: (?i)microsoft.*.
org.eclipse.persistence.platform.database.PostgreSQLPlatform , RegularExpression: (?i)postgresql.*.
org.eclipse.persistence.platform.database.SybasePlatform, RegularExpression: (?i)(sybase.*)|(adaptive server enterprise.*)|(SQL Server).
org.eclipse.persistence.platform.database.JavaDBPlatform, RegularExpression: (?i).*derby.
[EL Fine]: 2008.07.17 08:09:31.893--Thread(Thread[main,5,main])--Detected Vendor platform:
08:09:31.924--ServerSession(26435810)--Connection(25218858)- -Thread(Thread[main,5,main])--connecting(DatabaseLogin(
platform=>JavaDBPlatform
user name=> "app"
datasource URL=> "jdbc:derby://localhost:1527/sample"
[EL Config]: 2008.07.17 08:09:31.924--ServerSession(26435810)--Connection(15612583)- -Thread(Thread[main,5,main])--Connected:
User: app
Database: Apache Derby Version: 10.2.2.0 - (485682)
Driver: Apache Derby Network Client JDBC Driver Version: 10.4.1.3 - (648739)
08:09:31.924--ServerSession(26435810)--Connection(5035392)-- Thread(Thread[main,5,main])--connecting(DatabaseLogin(
user name=> "app"
[EL Config]: 2008.07.17 08:09:31.940--ServerSession(26435810)--Connection(5569009)-- Thread(Thread[main,5,main])--Connected:
User: app
08:09:31.940--ServerSession(26435810)--Connection(15038164)- -Thread(Thread[main,5,main])--connecting(DatabaseLogin(
user name=> "app"
[EL Config]: 2008.07.17 08:09:31.940--ServerSession(26435810)--Connection(14452459)- -Thread(Thread[main,5,main])--Connected:
User: app
08:09:31.940--ServerSession(26435810)--Connection(1947116)-- Thread(Thread[main,5,main])--connecting(DatabaseLogin(
user name=> "app"
[EL Config]: 2008.07.17 08:09:31.940--ServerSession(26435810)--Connection(9613729)-- Thread(Thread[main,5,main])--Connected:
User: app
08:09:31.940--ServerSession(26435810)--Connection(13367741)- -Thread(Thread[main,5,main])--connecting(DatabaseLogin(
user name=> "app"
[EL Config]: 2008.07.17 08:09:31.940--ServerSession(26435810)--Connection(24713456)- -Thread(Thread[main,5,main])--Connected:
User: app
08:09:31.940--ServerSession(26435810)--Connection(22310332)- -Thread(Thread[main,5,main])--connecting(DatabaseLogin(
user name=> "app"
[EL Config]: 2008.07.17 08:09:31.955--ServerSession(26435810)--Connection(32542424)- -Thread(Thread[main,5,main])--Connected:
User: app
08:09:31.955--ServerSession(26435810)--Connection(3288014)-- Thread(Thread[main,5,main])--connecting(DatabaseLogin(
user name=> "app"
[EL Config]: 2008.07.17 08:09:31.955--ServerSession(26435810)--Connection(31056514)- -Thread(Thread[main,5,main])--Connected:
User: app
[EL Finest]: 2008.07.17 08:09:31.971--ServerSession(26435810)--Thread(Thread[main,5, main])--sequencing connected, state is
NoPreallocation_State
[EL Finest]: 2008.07.17 08:09:31.971--ServerSession(26435810)--Thread(Thread[main,5, main])--sequence SEQ_GEN_IDENTITY: preallocation
size 1
[EL Info]: 2008.07.17 08:09:32.033--ServerSession(26435810)--Thread(Thread[main,5, main])--file:/C:/src/stest/build/classes/-stestPU
login successful
[EL Finest]: 2008.07.17 08:09:32.049--ServerSession(26435810)--Thread(Thread[main,5, main])--Execute query DataModifyQuery()
[EL Fine]: 2008.07.17 08:09:32.065--ServerSession(26435810)--Connection(5569009)-- Thread(Thread[main,5,main])--ALTER TABLE CHILD
DROP CONSTRAINT FK_CHILD_PARENT_ID
[EL Finest]: 2008.07.17 08:09:32.190--ServerSession(26435810)--Thread(Thread[main,5, main])--Execute query DataModifyQuery()
[EL Fine]: 2008.07.17 08:09:32.190--ServerSession(26435810)--Connection(15612583)- -Thread(Thread[main,5,main])--DROP TABLE CHILD
[EL Finest]: 2008.07.17 08:09:32.237--ServerSession(26435810)--Thread(Thread[main,5, main])--Execute query DataModifyQuery()
[EL Fine]: 2008.07.17 08:09:32.237--ServerSession(26435810)--Connection(5569009)-- Thread(Thread[main,5,main])--CREATE TABLE CHILD
(ID INTEGER GENERATED ALWAYS AS IDENTITY NOT NULL, VERSION INTEGER, CREATEDON TIMESTAMP, PARENT_ID INTEGER, PRIMARY KEY (ID))
[EL Finest]: 2008.07.17 08:09:32.268--ServerSession(26435810)--Thread(Thread[main,5, main])--Execute query DataModifyQuery()
[EL Fine]: 2008.07.17 08:09:32.268--ServerSession(26435810)--Connection(15612583)- -Thread(Thread[main,5,main])--DROP TABLE PARENT
[EL Finest]: 2008.07.17 08:09:32.408--ServerSession(26435810)--Thread(Thread[main,5, main])--Execute query DataModifyQuery()
[EL Fine]: 2008.07.17 08:09:32.408--ServerSession(26435810)--Connection(5569009)-- Thread(Thread[main,5,main])--CREATE TABLE PARENT
(ID INTEGER GENERATED ALWAYS AS IDENTITY NOT NULL, VERSION INTEGER, SERIALNUMBER VARCHAR(255), PRIMARY KEY (ID))
[EL Finest]: 2008.07.17 08:09:32.502--ServerSession(26435810)--Thread(Thread[main,5, main])--Execute query DataModifyQuery()
[EL Fine]: 2008.07.17 08:09:32.502--ServerSession(26435810)--Connection(15612583)- -Thread(Thread[main,5,main])--ALTER TABLE CHILD
ADD CONSTRAINT FK_CHILD_PARENT_ID FOREIGN KEY (PARENT_ID) REFERENCES PARENT (ID)
[EL Finest]: 2008.07.17 08:09:32.549--ServerSession(26435810)--Thread(Thread[main,5, main])--End deploying Persistence Unit stestPU;
state Deployed; factoryCount 1
[EL Finer]: 2008.07.17 08:09:32.580--ServerSession(26435810)--Thread(Thread[main,5, main])--client acquired
[EL Finest]: 2008.07.17 08:09:32.580--UnitOfWork(4573563)--Thread(Thread[main,5,main ])--PERSIST operation called on:
stest.Parent@1c7865b.
stest.Child@1412e75.
[EL Finer]: 2008.07.17 08:09:32.612--ClientSession(18206828)--Connection(14452459)- -Thread(Thread[main,5,main])--begin transaction
[EL Finest]: 2008.07.17 08:09:32.612--UnitOfWork(4573563)--Thread(Thread[main,5,main ])--Execute query
InsertObjectQuery(stest.Parent@1c7865b)
[EL Fine]: 2008.07.17 08:09:32.627--ClientSession(18206828)--Connection(14452459)- -Thread(Thread[main,5,main])--INSERT IGNORE INTO PARENT
(VERSION, SERIALNUMBER) VALUES (?, ?)
bind => [1, null]
[EL Finest]: 2008.07.17 08:09:32.643--ClientSession(18206828)--Thread(Thread[main,5, main])--Execute query ValueReadQuery()
[EL Fine]: 2008.07.17 08:09:32.643--ClientSession(18206828)--Connection(14452459)- -Thread(Thread[main,5,main])--values
IDENTITY_VAL_LOCAL()
[EL Finest]: 2008.07.17 08:09:32.674--UnitOfWork(4573563)--Thread(Thread[main,5,main ])--assign sequence to the object (1 ->
[EL Finest]: 2008.07.17 08:09:32.674--UnitOfWork(4573563)--Thread(Thread[main,5,main ])--Execute query
InsertObjectQuery(stest.Child@1412e75)
WriteObjectQuery(stest.Parent@1c7865b)
[EL Fine]: 2008.07.17 08:09:32.674--ClientSession(18206828)--Connection(14452459)- -Thread(Thread[main,5,main])--INSERT IGNORE INTO CHILD
(VERSION, CREATEDON, PARENT_ID) VALUES (?, ?, ?)
bind => [1, 2008-07-17 08:09:32.58, 1]
[EL Finest]: 2008.07.17 08:09:32.690--ClientSession(18206828)--Thread(Thread[main,5, main])--Execute query ValueReadQuery()
[EL Fine]: 2008.07.17 08:09:32.690--ClientSession(18206828)--Connection(14452459)- -Thread(Thread[main,5,main])--values
[EL Finest]: 2008.07.17 08:09:32.690--UnitOfWork(4573563)--Thread(Thread[main,5,main ])--assign sequence to the object (1 ->
[EL Finest]: 2008.07.17 08:09:32.690--UnitOfWork(4573563)--Thread(Thread[main,5,main ])--Execute query ReadObjectQuery(stest.Parent)
[EL Finest]: 2008.07.17 08:09:32.690--UnitOfWork(4573563)--Thread(Thread[main,5,main ])--PERSIST operation called on: stest.Child@4d2af2.
UpdateObjectQuery(stest.Parent@1c7865b)
[EL Fine]: 2008.07.17 08:09:32.690--ClientSession(18206828)--Connection(14452459)- -Thread(Thread[main,5,main])--UPDATE PARENT SET
SERIALNUMBER = ?, VERSION = ? WHERE ((ID = ?) AND (VERSION = ?))
bind => [12345678, 2, 1, 1]
[EL Finest]: 2008.07.17 08:09:32.705--UnitOfWork(4573563)--Thread(Thread[main,5,main ])--Execute query
InsertObjectQuery(stest.Child@4d2af2)
[EL Fine]: 2008.07.17 08:09:32.705--ClientSession(18206828)--Connection(14452459)- -Thread(Thread[main,5,main])--INSERT IGNORE INTO CHILD
bind => [1, 2008-07-17 08:09:32.69, 1]
[EL Finest]: 2008.07.17 08:09:32.705--ClientSession(18206828)--Thread(Thread[main,5, main])--Execute query ValueReadQuery()
[EL Fine]: 2008.07.17 08:09:32.705--ClientSession(18206828)--Connection(14452459)- -Thread(Thread[main,5,main])--values
[EL Finest]: 2008.07.17 08:09:32.705--UnitOfWork(4573563)--Thread(Thread[main,5,main ])--assign sequence to the object (2 ->
stest.Child@4d2af2)
[EL Finest]: 2008.07.17 08:09:32.705--UnitOfWork(4573563)--Thread(Thread[main,5,main ])--PERSIST operation called on:
stest.Child@14e45b3.
InsertObjectQuery(stest.Child@14e45b3)
bind => [1, 2008-07-17 08:09:32.705, 1]
[EL Finest]: 2008.07.17 08:09:32.721--ClientSession(18206828)--Thread(Thread[main,5, main])--Execute query ValueReadQuery()
[EL Fine]: 2008.07.17 08:09:32.721--ClientSession(18206828)--Connection(14452459)- -Thread(Thread[main,5,main])--values
[EL Finest]: 2008.07.17 08:09:32.721--UnitOfWork(4573563)--Thread(Thread[main,5,main ])--assign sequence to the object (3 ->
[EL Finest]: 2008.07.17 08:09:32.721--UnitOfWork(4573563)--Thread(Thread[main,5,main ])--Execute query ReadObjectQuery(stest.Parent)
[EL Finest]: 2008.07.17 08:09:32.721--UnitOfWork(4573563)--Thread(Thread[main,5,main ])--PERSIST operation called on:
stest.Child@1700391.
InsertObjectQuery(stest.Child@1700391)
[EL Fine]: 2008.07.17 08:09:32.721--ClientSession(18206828)--Connection(14452459)- -Thread(Thread[main,5,main])--INSERT IGNORE INTO CHILD
bind => [1, 2008-07-17 08:09:32.721, 1]
[EL Finest]: 2008.07.17 08:09:32.721--UnitOfWork(4573563)--Thread(Thread[main,5,main ])--assign sequence to the object (4 ->
[EL Finer]: 2008.07.17 08:09:32.721--UnitOfWork(4573563)--Thread(Thread[main,5,main ])--begin unit of work commit
[EL Finer]: 2008.07.17 08:09:32.721--ClientSession(18206828)--Connection(14452459)- -Thread(Thread[main,5,main])--commit transaction
[EL Finer]: 2008.07.17 08:09:32.737--UnitOfWork(4573563)--Thread(Thread[main,5,main ])--end unit of work commit
[EL Finer]: 2008.07.17 08:09:32.737--UnitOfWork(4573563)--Thread(Thread[main,5,main ])--resume unit of work
[EL Finer]: 2008.07.17 08:09:32.737--UnitOfWork(4573563)--Thread(Thread[main,5,main ])--release unit of work
[EL Finer]: 2008.07.17 08:09:32.737--ClientSession(18206828)--Thread(Thread[main,5, main])--client released
[EL Finest]: 2008.07.17 08:09:32.737--ServerSession(26435810)--Thread(Thread[main,5, main])--Begin predeploying Persistence Unit
stestPU; state Deployed; factoryCount 1
[EL Finest]: 2008.07.17 08:09:32.737--ServerSession(26435810)--Thread(Thread[main,5, main])--End predeploying Persistence Unit
stestPU; state Deployed; factoryCount 2
[EL Finest]: 2008.07.17 08:09:32.737--ServerSession(26435810)--Thread(Thread[main,5, main])--Begin deploying Persistence Unit
[EL Finest]: 2008.07.17 08:09:32.737--ServerSession(26435810)--Thread(Thread[main,5, main])--End deploying Persistence Unit stestPU;
[EL Finer]: 2008.07.17 08:09:32.737--ServerSession(26435810)--Thread(Thread[main,5, main])--client acquired
[EL Finest]: 2008.07.17 08:09:32.737--UnitOfWork(19902639)--Thread(Thread[main,5,mai n])--Execute query ReadObjectQuery(stest.Parent)
[EL Finest]: 2008.07.17 08:09:32.737--UnitOfWork(19902639)--Thread(Thread[main,5,mai n])--Register the existing object stest.Child@e99ce5
stest.Parent@186dda3
[EL Finest]: 2008.07.17 08:09:32.737--UnitOfWork(19902639)--Thread(Thread[main,5,mai n])--Register the existing object stest.Child@510e39
stest.Child@164debb
Child 3 present
Child 1 present
Child 2 present
config set count is 3
[EL Finer]: 2008.07.17 08:09:32.752--UnitOfWork(19902639)--Thread(Thread[main,5,mai n])--begin unit of work commit
[EL Finer]: 2008.07.17 08:09:32.752--UnitOfWork(19902639)--Thread(Thread[main,5,mai n])--end unit of work commit
[EL Finer]: 2008.07.17 08:09:32.752--UnitOfWork(19902639)--Thread(Thread[main,5,mai n])--resume unit of work
[EL Finer]: 2008.07.17 08:09:32.752--UnitOfWork(19902639)--Thread(Thread[main,5,mai n])--release unit of work
[EL Finer]: 2008.07.17 08:09:32.752--ClientSession(22562823)--Thread(Thread[main,5, main])--client released
BUILD SUCCESSFUL (total time: 14 seconds)
James wrote:
> Very odd issue.
> If removing the version or serialNumber makes the issue go away, it
> sounds like your commit must be failing somehow (or perhaps the merge).
> Ensure that you do not get any errors in any of the flush or the commit.
> In you test code the find for the parent should return the identical
> object in each case, verify that the find return is == p0. Also try
> removing the flushes to see if they issue goes away.
> Your could is using application managed entity managers and
> transactions. Ensure that you are not using a JTA DataSource.
> Also enable logging to finest and include the log.
> -- James
Current Time: Sat Jul 26 11:39:48 EDT 2025
Powered by FUDForum. Page generated in 0.05948 seconds
