Home » Archived » GMT (Generative Modeling Technologies) » [oaw] metamodel referencing
[oaw] metamodel referencing [message #375957] Fri, 16 February 2007 15:20 Go to next message
We have a metamodel for our DSL that references the UML2 metamodel.
When we refer to a UML2 metamodel element like this
http://www.eclipse.org/uml2/2.0.0/UML#//Property
It works fine when using a model based on this metamodel in a oaw workflow.
The standard ecore editor saves the UML2 references like this however:
.../../../plugin/org.eclipse.uml2.uml/model/UML.ecore#//Prop erty
and that trips up the oaw workflow with an exception like stated below.
Is there a way to make these relative metamodel references work in oaw?
I did put my vote up in bugzilla for emf to have a choice between relative
or absolute referencing registered plugin models, but in the mean time it
would be great if you could support the relative referencing as well.
Hans
1663 ERROR WorkflowRunner -
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Value
'MyElementName' is not legal.
(file:/C:/Documents%20and%20Settings/Hans/Eclipse%203.3%20pr ojects/my.generator.project/bin/model/test.model,
3, 105)
at org.openarchitectureware.emf.XmiReader.invoke(XmiReader.java :83)
at
org.openarchitectureware.workflow.container.CompositeCompone nt.internalInvoke(CompositeComponent.java:81)
at
org.openarchitectureware.workflow.container.CompositeCompone nt.invoke(CompositeComponent.java:69)
at
org.openarchitectureware.workflow.WorkflowRunner.executeWork flow(WorkflowRunner.java:236)
at
org.openarchitectureware.workflow.WorkflowRunner.run(Workflo wRunner.java:177)
at
org.openarchitectureware.workflow.WorkflowRunner.main(Workfl owRunner.java:126)
Re: [oaw] metamodel referencing [message #375960 is a reply to message #375957] Tue, 20 February 2007 14:27 Go to previous message
Hi Hans,
this is a known bug.
Sven
> ../../../plugin/org.eclipse.uml2.uml/model/UML.ecore#//Prope rty
> Regards,
> Hans
> 3, 105)
> at
> at
> at
> at
> at
Re: [oaw] metamodel referencing [message #562643 is a reply to message #375957] Tue, 20 February 2007 14:27 Go to previous message
Hi Hans,
Sven
> Regards,
> Hans
> 3, 105)
> at
> at
> at
> at
> at
Previous Topic:[Announce] A Proposal and Prototype for an Eclipse Model Registry
Next Topic:xText Startup Questions
Current Time: Sun Jul 27 03:56:47 EDT 2025
Powered by FUDForum. Page generated in 0.26054 seconds
