Home » Archived » Buckminster » Materializing multiple versions of a plugin
Materializing multiple versions of a plugin [message #375822] |
Thu, 01 May 2008 08:41  |
In the Eclipse STP build, I need to materialize two versions of the javax.wsdl
plugin from Orbit - 1.5.1 for STP and 1.4.0 for parts of WTP upon which STP
depends.
Watching the build log, I see:
javax.wsdl:osgi.bundle/[1.5.0,1.6.0)#OSGi: Found match
1.5.1.v200803061910
a little later I see
[java] WARN: Component request javax.wsdl:osgi.bundle/[1.5.0,1.6.0)#OSGi is
inconflict with request javax.wsdl:osgi.bundle/[1.4.0,1.5.0)#OSGi
and finally, I get compilation failures in the STP code that
uses javax.wsdl.
When I check the workspace/plugins, I see an exploded javax.wsdl
directory, which contains the 1.4.0 jar only.
I'm using the eclipse.import reader to pull the orbit bundles map
file.
How can I materialize both of these bundles and complete the
build?
best regards
Oisin
Oisin Hurley at IONA
http://blogs.iona.com/ohurley/
Re: Materializing multiple versions of a plugin [message #375826 is a reply to message #375822] |
Fri, 02 May 2008 02:57   |
Hi Oisin,
this is an unwanted limitation in Buckminster. Perhaps its OK to report
a conflict as a default behavior but it should be configurable. Can you
please enter an enhancement request for this in our bugzilla?
Thomas Hallgren
> depends.
> 1.5.1.v200803061910
> uses javax.wsdl.
> file.
> build?
> best regards
> Oisin
Re: Materializing multiple versions of a plugin [message #375829 is a reply to message #375826] |
Fri, 02 May 2008 08:48   |
Hi Thomas and Oisin,
I have similar problem, but the difference is that Buckminster does
materialization of two different versions of the same component for me.
I can see a warning in the log, however both versions are visible in the
bom tree and both are materialized:
Component request junit/[3.8.1,3.9.0.a)#Triplet is inconflict with
request junit/[3.7,3.8.0.a)#Triplet
The components are of type 'maven'.
How to test it: Try to resolve & materialize this cquery (a small RCP
demo application built by buckminster):
http://eclipsesvn.cloudsmith.com/com.cloudsmith.demo/trunk/c om.cloudsmith.presentation2.feature/buckminster/com.cloudsmi th.presentation2.feature.cquery
I got another problem when I wanted to skip the 'junit' completely. I
added an advisor node telling buckminster to skip the component. The bom
looked ok. However, materialization fails on this:
Component commons-httpclient$3.0.1#Triplet has no declared dependency to
component junit
Am I doing anything wrong? If not, should I post these as separate issues?
Filip
Thomas Hallgren napsal(a):
> Hi Oisin,
> Regards,
> Thomas Hallgren
>> javax.wsdl
>> which STP
>> depends.
>> 1.5.1.v200803061910
>> uses javax.wsdl.
>> file.
>> build?
>> best regards
>> Oisin
Re: Materializing multiple versions of a plugin [message #375830 is a reply to message #375829] |
Fri, 02 May 2008 13:01  |
Hi Filip,
Please add the information regarding multiple versions to the bugzilla
that Oising entered. The skipping junit thing sounds like another issue
so it deserves a separate bugzilla entry.
Thomas Hallgren
> component junit
> Filip
>> Hi Oisin,
>> report a conflict as a default behavior but it should be configurable.
>> Can you please enter an enhancement request for this in our bugzilla?
>> Regards,
>> Thomas Hallgren
>>> javax.wsdl
>>> which STP
>>> depends.
>>> 1.5.1.v200803061910
>>> uses javax.wsdl.
>>> file.
>>> build?
>>> best regards
>>> Oisin
Current Time: Fri Jul 18 17:50:44 EDT 2025
Powered by FUDForum. Page generated in 0.03250 seconds
