Home » Eclipse Projects » GEF » Prevent users from reconnecting a connection to a component
Prevent users from reconnecting a connection to a component [message #37583] |
Wed, 30 October 2002 11:26  |
Originally posted by: sy_cheung2.yahoo.com
I would like to know how I can prevent users from reconnecting an existing
connection to a component?
I return NULL in the getTargetConnectionAnchor() method of the component so
that user can NOT draw a connection connecting the the component. But user
can still reconnect an *existing* connection to that component. I would like
to know
what else I need to do so that users can *not* do that as well.
So user can not draw any connection to that component either using the
creation tool or re-connecting an existing connection to that new component.
Thank you.
Re: Prevent users from reconnecting a connection to a component [message #38052 is a reply to message #37822] |
Thu, 31 October 2002 03:47   |
i believe i did something like that in graphicalnodeeditpolicy, in one parts
policy, create returns null, which means you can not start a connection from
this part, in other part, complete returns null, which means you can not
complete a connection on it...
protected Command getConnectionCompleteCommand(CreateConnectionRequest
request)
return null;
protected Command getConnectionCreateCommand(CreateConnectionRequest
request)
ConnectionCommand command = new ConnectionCommand();
command.setWire(new Wire());
command.setSource(getModel());
ConnectionAnchor ctor = getPart().getSourceConnectionAnchor(request);
command.setSourceTerminal(getPart().mapConnectionAnchorToTer minal(ctor));
request.setStartCommand(command);
return command;
"Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
news:appf3g$imq$1@rogue.oti.com...
> OK. You would do this in your component's GraphicalNodeEditPolicy.
> Override getTargetEditPart(Request) to return NULL if the Request is a
> REQ_RECONNECT_SOURCE, or REQ_CONNECTION_START.
> "Sam Cheung" <sy_cheung2@yahoo.com> wrote in message
> news:app7c4$dbs$1@rogue.oti.com...
> > Thanks Randy,
> > But i want that component to allow incoming connection only, not
outgoing
> > connection.
> > So I can't follow the LabelEditPart (which does not allow *ANY*
> connection),
> > can I?
> > news:app703$d3h$1@rogue.oti.com...
> > > LabelEditPart in Logic example does not support connections. Notice
how
> > it
> > > also does not have any Node*EditPolicies either.
> > > news:apoved$835$1@rogue.oti.com...
> > > > Hi,
> > existing
> component
> > > so
But
> > > user
> would
> > > like
> > > > to know
the
> > > component.
> > > > Thank you.
Re: Prevent users from reconnecting a connection to a component [message #38246 is a reply to message #38052] |
Thu, 31 October 2002 08:49   |
Originally posted by: hudsonr.us.eye-bee-em.com
You will need to handle reconnecting as well. Command
getReconnectIForgetTheRest(Request)
Also, NULL does not guarantee that the operation is prevented. You should
return an UnexecutableCommand
Either way works. In Ozgur's case, the Node is targeted, and it rejects the
connection. In my case, the node is not target, and whatever is under the
node is targeted. This gives good results if the part under the node is the
"Diagram", which doesn't support connections. If you have additional
containers in your application that are also nodes (like Logic Circuits),
then maybe this isn't ideal. To get a feel for this, drop a Label inside a
Circuit, and try to create a connection to the Label. The Circuit is
targeted.
"Ozgur Kurt" <ozgurkurt@hotmail.com> wrote in message
news:apqotu$6s8$1@rogue.oti.com...
parts
from
> request)
> return null;
> request)
> return command;
> > > Thanks Randy,
> outgoing
> > > connection.
> > connection),
> > > can I?
> how
> > > it
> > > > > Hi,
> > > existing
> > component
> > > > so
> But
> > > > user
> > would
> > > > like
> > > > > to know
> the
> > > > component.
> > > > > Thank you.
Re: Prevent users from reconnecting a connection to a component [message #38343 is a reply to message #38246] |
Thu, 31 October 2002 10:13  |
thanx Randy, should i return this UnexecutableCommand for every request to a
command that shouldn't be ran?
news:apran4$h6k$1@rogue.oti.com...
the
the
a
> targeted.
> parts
> from
> > request)
> > return null;
> > request)
> > return command;
> > > > Thanks Randy,
> > outgoing
> > > > connection.
> > > connection),
> > > > can I?
Notice
> > how
> > > > it
> > > > > > Hi,
an
> > > > existing
> > > component
> > > > > so
component.
> > But
> > > > > user
I
> > > would
> > > > > like
> > > > > > to know
using
> > the
new
> > > > > component.
> > > > > > Thank you.
Current Time: Fri Jul 18 21:48:15 EDT 2025
Powered by FUDForum. Page generated in 0.04468 seconds
