Home » Archived » GMT (Generative Modeling Technologies) » Invoking Java from Moscript problems ...
Invoking Java from Moscript problems ... [message #375657] Thu, 09 November 2006 08:49 Go to next message
Originally posted by: iscrquinter.gmail.com
I am trying to invoke a Java class method using the the following code:
psmSM.ESStubGenerator::generateAxisStub(){
var wsdlAddress : String = self.wsdlAddress;
var cp : String = "c:/Documents and Settings/Ricardo Quintero/Mis
documentos/Doctorado/Tesis/New
Tesis/Tesis/wsEclipseTest/JavaAdapters2AXIS/bin;" +
"c:/axis/lib/activation.jar;" +
"c:/axis/lib/axis.jar;" +
"c:/axis/lib/axis-ant.jar;" +
"c:/axis/lib/commons-discovery-0.2.jar;" +
"c:/axis/lib/commons-logging-1.0.4.jar;" +
"c:/axis/lib/jaxrpc.jar;" +
"c:/axis/lib/log4j-1.2.8.jar;" +
"c:/axis/lib/saaj.jar;" +
"c:/axis/lib/wsdl4j-1.5.1.jar;" +
"c:/axis/lib/xercesImpl.jar;" +
"c:/axis/lib/xml-apis.jar";
java("adapters.wsdl2java.WSDL2JavaAdapter","generateStubfrom ",wsdlAddress,cp)
The method adapters.wsdl2Java.WSDLJavaAdapter (that is defined in anotoher
project in the same workspace) calls the org.apache.wsdl.WSDLJava.main
method (of the AXIS framework), but Eclipse stops running and crash-down
....(boom !!!)
I tested on Eclipse 3.1 and 3.2 ...and with Mofscript 1.1.11 ... and the
results are the same ...
What can I do ? What am I doing wrong ? Some suggestion ?
Re: Invoking Java from Moscript problems ... [message #375660 is a reply to message #375657] Tue, 28 November 2006 04:12 Go to previous messageGo to next message
Hi Ricardo,
It is not obvious why this Java call dumps the entire Eclipse environment,
but it probably related to the process(es) spawned by the Axis Java2WSDL
main execution. I tried to execute the same process and it fails in the same
way, also when running in debug mode - I am not able to catch any exceptions
from this invocation. Perhaps it would be better to use a non-command line
API of the Axis framework when executing from another Java process?
/ Jon Oldevik
"Ricardo Quintero" <iscrquinter@gmail.com> wrote in message
news:eivbl3$gs4$1@utils.eclipse.org...
> anotoher project in the same workspace) calls the
> org.apache.wsdl.WSDLJava.main method (of the AXIS framework), but Eclipse
> stops running and crash-down ...(boom !!!)
Re: Invoking Java from Moscript problems ... [message #375663 is a reply to message #375660] Wed, 29 November 2006 01:01 Go to previous message
Thanks for your advice John ...I will try a non-command line API of Axis
Ricardo
"Jon Oldevik" <jon.oldevik@sintef.no> escribi
Re: Invoking Java from Moscript problems ... [message #560522 is a reply to message #375657] Tue, 28 November 2006 04:12 Go to previous message
Hi Ricardo,
/ Jon Oldevik
Re: Invoking Java from Moscript problems ... [message #560530 is a reply to message #375660] Wed, 29 November 2006 01:01 Go to previous message
Ricardo
Previous Topic:Invoking Java from Moscript problems ...
Next Topic:Using user specified MetaModels
Current Time: Sat Jul 19 14:23:00 EDT 2025
Powered by FUDForum. Page generated in 0.04470 seconds
